Local Time 21:31 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite EXTREME b5: SnadPic support
Posted: 06:31am 22 Nov 2016
Please find attached the latest beta of the Hex file for the MZ chips.
2016-11-22_161652_MicromiteEXTREMEb5.zip
The changes are as follows:
* Implemented choice of SPI channel for SDcard connection
* Implemented new commands and functions for SPI3 and SPI4 (same syntax as SPI and SPI2) - see pinout for pin usage on the 64 pin chip. These may not be necessary but were basically free in order to allow flexible SDcard connection
* Fixed bug in "CPU SLEEP" and "CPU SLEEP time" commands
* Completed conversion to Harmony Plib calls.
I haven't received my Snadpic board yet and will publish the full pinout for the 100-pin chip when it arrives and has been tested.
The current hex is configured for a 12MHz oscillator. I will post a hex for the 24MHz oscillator when tested on a my Snadpic.
If you already have a Snadpic with a 24MHz oscillator, let me know by PM and I'll send you a hex to test.
There is a slightly modified syntax for OPTION SDCARD with an additional mandatory parameter "channel"
OPTION SDCARD channel,CS,[CD],[WP]
so to use the SD card as normal on SPI2 with card select connected to pin 1 and no card detect type
"OPTION SDCARD 2,1"
The reason for the change is that the SnadPic PCB has the on-board SD slot connected to SPI channel 4 so rather than create a dedicated file for this I have added support for choosing the channel.
The SnadPic wiring is:
Pin 81 = RD4-------------------->CS
Pin 67 = RA15------------------->SDO4
Pin 69 = RD10------------------->SCK4
Pin 70 = RD11------------------->SDI4
Pin 59 = RA2-------------------->CARD DETECT
so the command on the SnadPic will be:
"OPTION SDCARD 4,81,59"
SDcard usage has been tested on all 4 SPI channels on the 64-pin MZ chip
The pinout for the 64-pin chip is the same as b2 with the exception that SPI3 and 4 connections have been specified as additional options.
E5 : 1 Analog / Digital / SSD1963-D5
E6 : 2 Analog / Digital / SSD1963-D6
E7 : 3 Analog / Digital / SSD1963-D7
G6 : 4 Analog / Digital / SPI2-CLK
G7 : 5 Analog / Digital / SPI2-OUT
G8 : 6 Console-RX / COM4-RX
7 VSS
8 3.3V
9 MCLR / 5V
G9 : 10 Analog / Digital / PWM-1C
B5 : 11 Analog / Digital / COM2-TX / SPI3-OUT
B4 : 12 Analog / Digital
B3 : 13 Analog / Digital / COM2-RX / SPI4-IN
B2 : 14 Analog / Digital / COM1-EN / SPI4-OUT
B1 : 15 Analog / Digital / COM1-TX
B0 : 16 Analog / Digital / COM3-TX
B6 : 17 Analog / Digital / COM3-RX
B7 : 18 Analog / Digital
19 : AVDD
20 : AVSS
B8 : 21 Analog / Digital
B9 : 22 Analog / Digital /SPI3-IN
B10 : 23 Analog / Digital / COUNT
B11 : 24 Analog / Digital / SSD1963-WR
25 VSS
26 VDD
B12 : 27 Analog / Digital / SSD1963-RS
B13 : 28 Analog / Digital / SSD1963-RESET
B14 : 29 Analog / Digital / PWM-1B / SPI3-CLK
B15 : 30 Analog / Digital / PWM-2B
31 Oscillator 12MHz
C15 : 32 Digital
33 USB-VBUS
34 USB-VUSB
35 VSS
36 USB-D-
37 USB-D+
F3 : 38 Digital
39 VDD
40 VSS
F4 : 41 Digital / 5V / KYBD-CLK
F5 : 42 Digital / 5V / KYBD-DAT
D9 : 43 Digital / 5V / I2C-SDA
D10 : 44 Digital / 5V / I2C-SCK / SPI4-CLK
D11 : 45 Digital / 5V / SPI1-OUT
D0 : 46 Digital / 5V / COUNT
C13 : 47 Digital / SPI2-IN
C14 : 48 Digital / PWM-1A
D1 : 49 Digital / 5V / SPI1-CLK
D2 : 50 Digital / 5V / SPI1-IN
D3 : 51 Digital / 5V / COUNT
D4 : 52 Digital / 5V / COUNT
D5 : 53 Digital / 5V / PWM-2A
54 VDD
55 VSS
F0 : 56 5V / Console-TX / COM4-TX
F1 : 57 Digital / 5V / COM1-RX
E0 : 58 Digital / 5V / SSD1963-D0
59 VSS
60 VDD
E1 : 61 Digital / 5V / SSD1963-D1
E2 : 62 Digital / 5V / SSD1963-D2
E3 : 63 Digital / 5V / SSD1963-D3
E4 : 64 Digital / 5V / SSD1963-D4
Posted: 06:53am 22 Nov 2016
Thanks Peter, this is brilliant progress
In the future, will it be possible to have one HEX file that somehow 'auto-detects' whether 12MHz or 24MHz, OR will you have two hex files from which the 'user' has to select the correct one?
Thanks . . ..
Posted: 07:09am 22 Nov 2016
  Quote  In the future, will it be possible to have one HEX file that somehow 'auto-detects' whether 12MHz or 24MHz, OR will you have two hex files from which the 'user' has to select the correct one?
I can't think of a way of doing this but am open to any suggestions. I've posted a question on the Microchip forum.
Posted: 12:58pm 22 Nov 2016
Thanks to help on the Microchip forum I think I've found a way of doing this but need to wait for my 24MHz Snadpic to prove it.
Posted: 01:04pm 22 Nov 2016
@matherp
That is really good to hear if that is the case.
Only thing now is something I recollect kiiid mentioned about only being able to get the full 200MHz speed with the 12MHz and not the 24MHz?? I may have this wrong, but will ask if you think 200MHz is achievable regardless of oscillator used.
Also, what is the MZ running at now with a 12MHz osc, and with your port?
Posted: 01:26pm 22 Nov 2016
JUST NOTICED on b5 that CPU accepts any value - probably an area you're working on?Edited by WhiteWizzard 2016-11-23
Posted: 01:35pm 22 Nov 2016
Is there a way to find out the current CPU setting without resorting to a C-Function?
Thinking that something along the lines of Print MM.CPU could be useful maybe
Posted: 09:52pm 22 Nov 2016
  Quote  Only thing now is something I recollect kiiid mentioned about only being able to get the full 200MHz speed with the 12MHz and not the 24MHz?? I may have this wrong, but will ask if you think 200MHz is achievable regardless of oscillator used.
12MHz can only be used up to 198MHz CPU speed
24MHz can be used up to 200MHz
To make the code work with either it makes sense to limit the 24MHz also to 198MHz which is what kiiid has standardised on. Hardly a big difference.
I haven't implemented changing the CPU clock speed it is fixed at 198MHz. I'm not sure what the advantage is of having slower speeds on a high end chip - views?
palcal
Posted: 10:44pm 22 Nov 2016
What kiid actually posted was
  Quote  I would strongly suggest staying with 12MHz oscillator. The reason for that is because the new series of MZ/EF go up to 252MHz, not 200, so with 12MHz the frequency adjustment can be made better. At least my plans for now are to have 12MHz on the MZEF64 boards
Paul
Posted: 10:55pm 22 Nov 2016
  matherp said   I haven't implemented changing the CPU clock speed it is fixed at 198MHz. I'm not sure what the advantage is of having slower speeds on a high end chip - views?
Maybe lower clock uses less power?
(I'm thinking even users of MZ may sometimes need that, if it does.)
JohnEdited by JohnS 2016-11-24
Posted: 11:11pm 22 Nov 2016
  Quote  Maybe lower clock uses less power?
Not sure it is going to make much difference. This device will never be suitable for long-term battery power
power usage is 135mA at full speed. In sleep mode (clock = 32KHz) it is still 55mA
  Quote  What kiid actually posted was
I never understood that post 24MHz can be made to act just like a 12MHz by doubling the clock input divider PLLDIV=2 vs PLLDIV=1. So it can do everything a 12MHz clock can do and things (like 200MHz) that it can't
Posted: 11:44pm 22 Nov 2016
Oh, that's a lot of power (much more than I would have guessed) so probably not then!!
Thanks,
Posted: 12:55am 23 Nov 2016
Update: the answer is no
I can make it work for everything except USB.
I can measure the raw oscillator frequency against the 32Khz internal RTC and then configure the main oscillator PLL to give the correct output frequency but there is one configuration parameter UPLLFSEL which tells the USB PLL what input frequency it is receiving and that cannot be altered in software.
I've tried briefly re-programming the configuration words from within the program but that doesn't seem to do anything but lock up the processor
Oh well, I tried
Posted: 01:21am 23 Nov 2016
Shame about the oscillator auto detect but thanks for trying.
By the way, isn't 55mA in sleep mode a bit excessive? Is it maybe because an inbuilt 'thing' inside the PIC is still turned on? I am 1000% sure you have done all that is necessary, but it just seems a bit too high (would have thought sub 2mA is more realistic).
It is not an issue regarding the sleep current - just curious . . .
b5 holding out well here - have you come across any known issues yourself with it? Thanks
HankR
Posted: 11:00pm 12 Dec 2016
  matherp said
  Quote  power usage is 135mA at full speed. In sleep mode (clock = 32KHz) it is still 55mA
This is probably for Peter:
I'd like more explanation on the MZ sleep mode.
The MZ datasheet shows a sleep current of way less than 55mA (for no clock).
The MX Micromite attains a sleep current that matches its datasheet.
Couldn't the MZ work the same way with a proper low sleep current?
HankEdited by HankR 2016-12-14
