Local Time 21:32 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite EXTREME MMBasic V5.3b3
Posted: 06:39am 23 Nov 2016
This just brings the 5.2b5 code up to Geoff's latest 5.3 beta release.
I've done very limited testing (e.g. ILI9341 + touch) but most of Geoff's code changes are MMBasic internals and application changes which are not chip specific so hopefully not too much to go wrong.
I know, WW you are up and running with the MZ so would appreciate your feedback - anyone else?
2016-11-23_170839_MicromiteEXTREMEV5.3b3.zip Edited by matherp 2016-11-24
Posted: 07:27am 23 Nov 2016
Loading it now . . . .
Will report back any issues I uncover
f1fco
Posted: 06:22am 24 Nov 2016
hello Peter,
I have received today from Mounir a snadPic with PIC32MZ2048EFH 100
and a xtal of 24 MHz
can you post a version of HEX for this frequency ?
thank you very much
Pierre, from Nimes, south of France
73s de F1FCO
Posted: 06:31am 24 Nov 2016
Hi Pierre,
Do let us know how it goes once Peter has got the HEX to you.
If you don't mind me asking, how long did it take from the time you ordered the snadPic to it arriving? Thanks.
WW
f1fco
Posted: 08:55am 24 Nov 2016
Hi WW,
I have ordered the SnadPic the 17 november and I receive it today
about 1 week : it's OK
I wait from Peter for the 24 MHz version to try it !!!
Pierre
73s de F1FCO
Posted: 09:59am 24 Nov 2016
New version with a couple of tweaks
Load image now displays a 800*480 full colour .BMP file on an SSD1963 in:
1.5 seconds
and a 320x240 full colour .BMP file on an ILI9341 in:
0.4 seconds
underlying SSD1963 performance issue solved
Migrated to Harmony V2.01b
correct RTC after "CPU SLEEP n"
12 Mhz version
2016-11-24_192826_MicromiteEX5.3b3-1.12MHz.zip
24MHz version - completely untested!!!!
2016-11-24_192848_MicromiteEX5.3b3-1.24MHz.zip
Posted: 11:45am 24 Nov 2016
With the 'underlying SSD1963 performance issue solved', what will we notice (if anything)? For example, will all/some graphical commands be visually quicker?
Posted: 11:56am 24 Nov 2016
  Quote  what will we notice (if anything)?
Just it will work like it should have in the first place. You probably noticed some flicker on the display - that has gone now. A trivial timing issue with the faster chip.
UPDATE
I can also now confirm the MZ can be programmed using PIC32PROG with the PIC16F1454 and presumably the Arduino and PicKit2Edited by matherp 2016-11-26
f1fco
Posted: 01:07am 25 Nov 2016
I have a "hole in my memory" (un trou de memoire, in french)
what tension on the power connector of the SnadPic ?
more of +5V ?
I do not want to destroy my new PIC32MZ
thank you for answer
Pierre.
73s de F1FCO
f1fco
Posted: 01:09am 25 Nov 2016
I have forget :
THANK YOU Peter for the 24 MHz version of the HEX
I wait for power voltage before to try it
Pierre.
73s de F1FCO
Posted: 01:37am 25 Nov 2016
Is it the one with the 5.5/2.1mm barrel jack? If so I think it's 7-12V DC
f1fco
Posted: 04:18am 25 Nov 2016
ok, thank you John
it's right
I power my SnadPic with 12V and led light
I have programmed it with MPLABIPE v3.45 with the HEX for 24 MHz
no problem to load the file
does it exist à "pin map" for the SnadPic 100 pins ?
I dont know how to connect the console (tx and rx) to try my board
Pierre.
73s de F1FCO
Posted: 04:37am 25 Nov 2016
You'll laugh but I did a web search for
snadpic user manual
or
snadpic PDF
Try :)
f1fco
Posted: 04:53am 25 Nov 2016
not for the SnadPic 32MZ but for the PIC32MX470
http://www.microcontroller-board.com/snadpic-board-32-bit/14-snadpic-pic32mx470f512l-development-board.html#/crystal_osc illator-20mhz/crystal_rtcc-no_without_crystal_r
the download in PDF is in the bottom of the page
Pierre.
73s de F1FCO
Posted: 05:16am 25 Nov 2016
  f1fco said  I dont know how to connect the console (tx and rx) to try my board
On the 64pin MZ, the Console Rx was pin 6 which is RG8. Likewise, Tx was pin 56 = RF0.
On that basis (and while waiting for Peter to confirm otherwise) I would simply try (on the 100pinner MZ) Pin 12 as Rx (RG8) and Pin 85 as Tx (RF0)
Do let us know if this works . . .
Posted: 06:07am 25 Nov 2016
  Quote  12 as Rx (RG8) and Pin 85 as Tx (RF0)
Correct - but remember the USB should work as a console as well
f1fco
Posted: 06:15am 25 Nov 2016
it WORKS !!!
rx on pin 12, tx on pin 85
at the first power, I have the message :
Option error - Cleared OPTION
Processor restarted
and now, all is ok :
Micromite EXTREME MMBasic Ver 5.3 Beta 3b1
Copyright ...
and a small programm
do
? "hello ";
loop
RUN !!!
thank you Peter, and Geoff
Pierre.
73s de F1FCO
f1fco
Posted: 06:28am 25 Nov 2016
a little...
OPTION SDCARD 4,81,59
and the SDcard run also !
73s de F1FCO
Posted: 06:39am 25 Nov 2016
@f1fco
Good progress there!
Do you have a TFT you can connect up? Ideally a SSD...
f1fco
Posted: 06:52am 25 Nov 2016
I am buzy with family this evening and tomorrow
but I try sunday...
I own two SSD1963 : a 7" and a 5", no problem for test
in a near future, I will have a SnadPic with PIC32MX470 for sale...
Pierre.
73s de F1FCO
