| Author |
Message |
 Joined: 31/12/2012 Location: New ZealandPosts: 10043 |
| Posted: 11:24pm 12 Dec 2016 |
Copy link to clipboard |
 Print this post |
Hi folks - what gives?
I've checked this a couple of times, but the syntax matches the manual, but it won't accept it.
EDIT: I checked the version of the MM+ manual on Geoff's site, but the syntax for this command is the same in that manual, so I guess it is right?Edited by Grogster 2016-12-14 Smoke makes things work. When the smoke gets out, it stops! |
MM_Wombat Senior Member
| Posted: 12:19am 13 Dec 2016 |
 Print this post |
I checked the syntax and the command is missing the (Top,Middle,Bottom) character for the justification.
ie:
GUI caption #1,"Main Menu:",85,15,LT,RGB(magenta)
MM_Wombat Keep plugging away, it is fun learning
But can be expensive (if you keep blowing things up).
Maximite, ColourMaximite, MM+
panky
| Posted: 12:32am 13 Dec 2016 |
 Print this post |
G,
I can confirm this on 5.2 on a 470 driving a 7" screen.
If you omit the justify and colour arguments, it works; If you omit the justify and do use colour it also works.
eg. GUI CAPTION #1,"Test",85,15 .... works GUI CAPTION #4,"Test2",185,45,,RGB(BLUE) .... works but using l(lower case) or L or LEFT or LT fails as you indicate
panky
Wrong!!! As mentioned, you need both x and y justification even though the manual says 1 or 2 characters. So LT works! Edited by panky 2016-12-14 ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
| Posted: 08:37am 13 Dec 2016 |
 Print this post |
Yeah, manual says justification can be one or two letters, so I only tried one.
I will play with this some more when I get back at the end of the day. Right now, I am off to a day-long job, but will check this thread again later. I will use LT if that works.  Smoke makes things work. When the smoke gets out, it stops! |
