Forum Index : Microcontroller and PC projects : Javascript Gauge
I really Love the gauges onPhil's page here They are available on Github Here Is there any way of converting these to MMBasic? Or could anyone be able to make any kind of gauge that looks kinda similar, it doesn't have to have such a fancy bevelled surround to the gauge Anyone know if this is possible? or anyone willing to have a go and see if they can get anything similar working? I did have a go at trying to make something similar with the info in this thread but I was unable to get it working, or even look good |
Drop Zonker a quick PM; I am sure he will send you a snippet of code for you to build upon |
Asked the same question when I first upgraded my weather site. Those gauges are hugely configurable, (have not tried), and there's also a variety of different types as demonstrated here. Developing a porting to basic is way beyond my capabilities. |
wow that is really amazing The vertical bargraph on the right hand side is exactly how I'd like the temperatures to show. it's a shame it's not possible to convert to MMBasic |
I have a new beta for the MM+ almost ready to post and it includes a BLIT command written by Peter Mather. This will enable you to load an image of a gauge (like the ones in the above demo) and then draw your own pointers over the image (like this demo https://youtu.be/NSOKTJQubxc). Not quite as easy to program as the standard GUI controls on the MM+ but it should look impressive. I hope to have the new beta out in a few days. Geoff Geoff Graham - http://geoffg.net |
That sounds ideal Geoff I'll definitely be giving it a try and in the meantime looking up what "BLIT" means Lewis |
| Zonker Guru Joined: 18/08/2012 Location: United StatesPosts: 772 |
Bit Block Transfer... Sweet.! This will help a lot with moving displays and should help make some awesome new on screen controls possible in the GUI... Can't wait... |
