Local Time 06:54 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : USBID / USB Hosting
isochronic
Posted: 12:36am 09 Jan 2017
Can I shoot some ideas in the breeze and check I have it right ..
A device (eg PC) can run USB hosting. A usb-client device can then connect,
it will enumerate on the USB host system which then sets it up for data flow.
EG a Windows PC runs as a USB host, a client device like mcp2221a or similar pic1455 connects, and the host then also runs Teraterm etc to display the data.
The Microchip USB stack can be set up as a client. A full MCU like an MZ can also be used to run the stack as a USB host, in fact there is "USB-to-go" which can switch between modes as required. So, to enable the MCU to determine whether host or client mode is necessary, there is a USBID line in the USB wiring and the connectors switch it to ground as required.
It follows that any MCU and board that has the USBID line in place should be able to run as a USB host instead of as a client (apart from several thousand other factors ).
I have put the USBID line in place on the sn-7x pcb so you see I have high
hopes for it .
Posted: 01:28am 09 Jan 2017
AFAIK you are correct.
The issue is if you want a device to be able to switch between being a host and a client. This is easy enough in the software (sort-of) but it seems all designs that do this use a USB transceiver between the processor and the physical USB connection. Nothing too bad about that but I have yet to find one that isn't in a tiny QFN package so not possible to hand solder.
Posted: 02:19am 09 Jan 2017
Being a host means supplying USB power as I recall.
OTG means doing that only when host, I think.
The good news is the USB specs seem freely available. The bad is they are not very readable and are also rather large.
(They may be even worse if trying to write software to work on crude hardware.)
Various things that seem reasonable are in fact banned, too...
isochronic
Posted: 03:04am 10 Jan 2017
Hmmm. That is quite a catch-22...a device in usb-client mode must not supply power
back to the usb host - but if it instead runs as a host it must be able
to supply power to client devices and that must be incorporated.
I think there is a base spec of supplying 200 mA as a default.
Posted: 04:15am 10 Jan 2017
This document has a good explanation of all this
Posted: 06:33am 10 Jan 2017
Might find LM3526 or SY6280 useful.
isochronic
Posted: 11:29am 10 Jan 2017
Thanks - much appreciated
Posted: 07:18pm 10 Jan 2017
for simplicity, one could just use a jumper to select between USB host and device modes:
1 (left) pin connected to a nominated mode pin on the PIC32 that has a 10k resistor to ground.
2 (centre) pin connected to board's 5v rail
3 (right) pin connected to USB connector's 5v pin
- when 1-2 is jumpered, the 'mode' pin will be pulled high and the PIC32 knows that it should be in device mode.
- when 2-3 is jumpered, the mode pin will be pulled low (via the 10k resistor to ground) and the PIC32 knows that it should be in host mode. at the same time, the board's 5v line is fed directly to any attached usb device.
- when no jumper is fitted, we are in host mode but without power supplied to any attached USB device (that could be useful in some applications).
there should also be a schottky diode fitted between the USB connector's 5v pin and the board's 5v rail, such that whenever 5v is fed into the USB connector it will power the board.
a second (optional) schottky diode in series with any 'external 5v power' connectors on the board with protect against backfeeding 5v from the USB connector into an attached external 5v power supply.
rob :-)
isochronic
Posted: 10:56am 12 Jan 2017
I am thinking, those connections could be in a powered cable.
(edit - I was thinking of using icsp pins for power somehow but that is not a good idea.)
The mode signal could be set with a pic port resistor. That might also be generically usable by other boards too.
Still cogitating...
Edited by chronic 2017-01-14
CaptainBoing
Posted: 01:20am 22 Jun 2017
I have a MMX144pin board with a USB connector (not the console, "USBMZ") what does it actually do? I have searched the MMX documentation but only find a reference to it in the pin descriptions.
Would it not be possible to have this as a USB Host (it is a female connector). This guy seems to have working HOST code for PIC32. This would then solve the problem of connecting HIDs (keyboards etc) it would be REALLY good it it handled hubs - so multiple HIDs.
I am currently playing with a mini usb host shield for arduino and I'm close to having a working USB to serial - remember this is the opposite way to USB-serial using ch340/pic/ftdi solutions because shield acts as a host (like your pc does) but i would like to plug USB devices in directly without this bit of hardware and then using a serial port to get the data (this makes it *very* easy but not like using INKEY$). Went this way because the arduino already has libraries for processing the MAX3421E and I didn't want to do all that mucking about in MMBasic.
Any ideas anyone?
isochronic
Posted: 03:54pm 23 Jun 2017
After looking at USB for some time, I think it is resource/maintenance hungry so probably not worth the hassle building it into code unless it is going to be used a lot.
The separate (ed - arduino) USB host chip/board works ok at least for serial but hits the uno resource limit and takes the spi pins, the serial can apparently be reused as another spi port but I haven't tried that yet. I have been using one as a black box for a while, it seems to be working ok..it is good to compartmentalize the usb away from the main processing, arduino has its own benefits and annoyances of course. Edited by chronic 2017-06-25
