Local Time 19:57 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Touch LCD Shield N10DP
Georgenicholls
Posted: 10:53pm 11 Jan 2017
Good day, I have purchased a micromite chip and a touch LCD shield N10DP.
There is no information about the pins on the screen.
J1, 8 pins J2, 8 pins J3, 6 pins J4, 6 pins and J 7, ?
I am trying to get the screen connected to the micromite.
Can you help?
Regards George Nicholls.
disco4now
Posted: 01:01am 12 Jan 2017
If this is the board then your jumpers probably match a shield.
Is this your board
J1 is D0-D7 on shield
J2 is D8-D13,GND,AREF
J3 is A0-A5
J4 is vin,gnd,gnd,5v,3.3v,rst
J7 seems to be ICSP header.
From the link ,the functions assigned for arduino should allow you to identify the pins.
If it uses the ILI9341 chip as it says the you should be able to make it work.
It may not have a touch controller IC so the touch panel may be not too easy to read, as the Micromite is expecting this to be available via SPI and not to have to read the four wires coming from the touch panel.
Gerry
Pins usage on Arduino
Pins Used for TFT Screen Control:
D4: TF_CS, SD card select input pin
D5: TFT_CS, TFT chip select input pin
D6: TFT_D/C, TFT Data/Command control pin
D7: BACKLIGHT, TFT backlight control pin
Pins Used for SPI Interface:
D10: SPI chip select
D11: SPI MOSI pin
D12: SPI MISO pin
D13: SPI serial clock pin
Pins Used for Touch Function:
A0 - Touch Screen Y- input pin.
A1 - Touch Screen X- input pin.
A2 - Touch Screen Y+ input pin.
A3 - Touch Screen X+ input pin.
Edited by disco4now 2017-01-13
F4 H7FotSF4xGT
