paceman Guru Joined: 07/10/2011 Location: AustraliaPosts: 1329
Posted: 02:55am 24 Jan 2017
Has anyone noticed this before? I have an ILI9341 LCD panel set up in LANDSCAPE mode (320x240). If I do:
LINE 0,0,100,0 I get the expected top row horizontal line (along the screens long axis).
Now, trying out the GUI BITMAP command which has the format: GUI BITMAP X, Y, BITS, WIDTH, HEIGHT, SCALE, C, BC (the last five parameters can be defaulted)
If I do:
x% = 1 GUI BITMAP 0,0,x% I get the expected single pixel in the 8th position on the top row. Note that the width and height parameters are defaulted, i.e. 8,8 i.e. a square region.
If I do as above but change the width and height parameters to 32,1 i.e. GUI BITMAP 0,0,x%,32,1 I get a single pixel in the 8th position down the screen (along the short screen direction).
Question is - should the WIDTH and HEIGHT parameters be swapped in landscape mode or is this a bug? If the former, then we need a note to that effect on page 22 of the Manual and the same in the command definition table.
Greg
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11890
Posted: 05:01am 25 Jan 2017
Greg
This is definitely a bug - I've reported it to Geoff offline
Posted: 09:02pm 28 Jan 2017
Thanks for that Peter - sorry I took three days to get back to you, I missed your post somehow.
