Forum Index : Microcontroller and PC projects : play wav problem on 5.3 with touch
| plasma Guru Joined: 08/04/2012 Location: GermanyPosts: 437 |
mm+64 , mmb vers.:5.3 the touch use pin 47 , so i cant use play and use the touch together. any help here ? thx |
Watch this space..... ![]() IE: Geoff knows about this, as I reported it to him. It is my understanding he will correct this in the final release due out any time now, so - watch this space! ![]() Smoke makes things work. When the smoke gets out, it stops! |
ok , thx |
I plan to move PWM2B (to pin 32. See this thread: http://www.thebackshed.com/forum/forum_posts.asp?TID=9310&PN=1 Geoff Geoff Graham - http://geoffg.net |
