Forum Index : Microcontroller and PC projects : MicroChip Direct Free Shipping
Hi All, MicroChip Direct have FREE Shipping until 19-Feb to celebrate the merger with ATMEL Just use the promotion code HIATMEL when you check out. NOTE!! You do NOT have to buy any ATMEL products to qualify. I don't think there is a minimum order but certainly my $130US order went through with free freight. Kind Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Nice one, my son. ![]() Thanks for that heads up, as I am going to order from them shortly. Smoke makes things work. When the smoke gets out, it stops! |
Top tip!!! cheers. I got the email today about this... I can see I'll be busy at the weekend |
Hi All, If no minimum it might be the time to buy a single EXTREME chip The two to look for are I believe: PIC32MZ2048EFH100-250I/PF (14mm) 100pin PIC32MZ2048EFH144-250I/PL (20mm) 144pin There is a smaller version for each of the above chips but I think all current boards out there use the larger footprint versions listed above. Please check this before you place your order. Kind Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Odd that the blurb gives a UK address for Microchip instead of USA . Is Microchip sending us downriver ? |
