Local Time 15:04 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : arrays of strings
Posted: 02:40am 28 Feb 2017
page 55 of the micromite manual gives several examples of using the DIM statement, including:
DIM name AS STRING
DIM strn$(200) LENGTH 20
these two examples suggest to me that the following should work:
DIM info(200) AS STRING LENGTH 16
it does not:
Error: Not enough memory
the specified length is ignored. whereas:
Dim STRING info(200) LENGTH 16
behaves as expected:
> memory
Flash:
1K ( 0%) Program (47 lines)
59K (100%) Free
RAM:
4K ( 7%) 1 Variable
0K ( 0%) General
46K (93%) Free
is this (DIM info(200) AS STRING LENGTH 16) the sign of a bug?
rob :-)Edited by robert.rozee 2017-03-01
Posted: 03:01am 28 Feb 2017
as an aside to this, what is the material difference between a$ and b$ below:
> dim string a$="line one"
> dim b$="line two"
> ? a$
line one
> ? b$
line two
> ? a
line one
> ? b
Error: B already declared
ie, if we were to examine the variable tables in memory, what would be different between the two variables to cause the differing behaviour? is there a need for them to be different or to behave differently?
rob :-)
MicroBlocks
Posted: 03:26am 28 Feb 2017
I have always have problem remembering the syntax for fixed length string arrays.
The manual does not make it easier.
It is the only statement in the manual that i somehow can not get into my head. :)
The rest of the manual is easy to follow, but that DIM statement for arrays .... i just copy and paste a working snippet, but that does not help to remember also.
