Local Time 13:31 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - date calculations
cdeagle
Posted: 08:29am 02 Mar 2017
This post presents double precision calendar and Julian day subroutines for the Micromite eXtreme. The following is the output from an interactive program that converts a calendar date to its corresponding Julian day and vice versa.
The program also computes the number of days between two calendar dates which is simply the difference between their corresponding Julian days.
Many countries currently use the Gregorian calendar implemented by Pope Gregory XIII in the sixteenth century. Thanks to the pope, October 5, 1582 to October 14, 1582 are invalid calendar dates!
The Julian day is the number of continuous days that have elapsed since noon on January 1, 4712 B.C. The Julian day begins at noon because astronomers don't like to change their clocks during the night while they are observing. Also note that the Julian date, based on the calendar implemented by Julius Caesar, is not the same as the Julian day number.
program demo_dates - demonstrate date conversions
please input the calendar date
(month [1 - 12], day [1 - 31], year [yyyy])
< for example, october 21, 1986 is input as 10,21,1986 >
< b.c. dates are negative, a.d. dates are positive >
< the day of the month may also include a decimal part >
? 10,21,2017
please input the time
(hours [0 - 24], minutes [0 - 60], seconds [0 - 60])
? 10,20,30.4589
convert calendar date and time to julian day
calendar month = 10
calendar day = 21
calendar year = 2017
time = 10 hr 20 min 30.4589 sec
jday = 2458047.930908089
convert Julian day to Gregorian date and time
calendar month = 10
calendar day = 21
number of days between two dates
first date
? 3,30,2017
second date
? 10,21,2017
number of days between dates = 205
Here's the source code for the main program and subroutines;
' demo_dates.bas
' demonstrate date conversions
' March 2, 2017
print " "
print "program demo_dates - demonstrate date conversions"
print "================================================="
' request calendar date (month, day, year)
getdate(month1, day0, year1)
' request time (hours, minutes, seconds)
gettime(thr1, tmin1, tsec1)
' compute "complete" calendar day
day1 = day0 + thr1 / 24.0 + (tmin1 / 60.0) / 24.0 + (tsec1 / 3600.0) / 24.0
' compute corresponding Julian day
julian (month1, day1, year1, jday1)
' print results
print " "
print "convert calendar date and time to julian day"
print "--------------------------------------------"
print " "
print "calendar month = ", month1
print "calendar day = ", day0
print "calendar year = ", year1
print " "
print "time = ", str$(thr1) + " hr " + str$(tmin1) + " min " + str$(tsec1, 0, 4) + " sec"
print " "
print "jday = ", str$(jday1, 0, 9)
print " "
print "convert Julian day to Gregorian date and time"
print "---------------------------------------------"
print " "
' compute calendar date
gdate (jday1, month2, day2, year2)
print " "
print "calendar month = ", month2
print "calendar day = ", int(day2)
print "calendar year = ", year2
print " "
thr0 = 24.0 * (day2 - int(day2))
thr2 = int(thr0)
tmin0 = 60.0 * (thr0 - thr2)
tmin2 = int(tmin1)
tsec2 = 60.0 * (tmin0 - tmin2)
print "time = ", str$(thr2) + " hr " + str$(tmin2) + " min " + str$(tsec2, 0, 4) + " sec"
print " "
print "number of days between two dates"
print "--------------------------------"
print " "
print "first date"
getdate(month3, day3, year3)
julian (month3, day3, year3, jday3)
print " "
print "second date"
getdate(month4, day4, year4)
julian (month4, day4, year4, jday4)
delta_days = jday4 - jday3
print " "
print "number of days between dates = ", delta_days
print " "
end
sub julian (month, day, year, jday)
' Gregorian date to julian day subroutine
' input
' month = calendar month
' day = calendar day
' year = calendar year (all four digits)
' output
' jday = julian day
' special notes
' (1) calendar year must include all digits
' (2) will report October 5, 1582 to October 14, 1582
' as invalid calendar dates and exit
y = year
m = month
b = 0.0
c = 0.0
if (m <= 2.0) then
y = y - 1.0
m = m + 12.0
end if
if (y < 0.0) then c = -0.75.0
if (year < 1582.0) then
' null
elseif (year > 1582.0) then
a = fix(y / 100.0)
b = 2.0 - a + fix(a / 4.0)
elseif (month < 10.0) then
' null
elseif (month > 10.0) then
a = fix(y / 100.0)
elseif (day <= 4.0) then
' null
elseif (day > 14.0) then
a = fix(y / 100.0)
else
print "this date does not exist!!"
exit
end if
jday = fix(365.25 * y + c) + fix(30.6001 * (m + 1.0)) + day + b + 1720994.5
end sub
sub gdate (jday, month, day, year)
' Julian day to Gregorian date subroutine
' input
' jday = julian day
' output
z = fix(jday + 0.5)
f = jday + 0.5 - z
if (z < 2299161) then
a = z
else
alpha = fix((z - 1867216.25) / 36524.25)
a = z + 1.0 + alpha - fix(alpha / 4.0)
end if
b = a + 1524.0
c = fix((b - 122.1) / 365.25)
d = fix(365.25 * c)
e = fix((b - d) / 30.6001)
day = b - d - fix(30.6001 * e) + f
if (e < 13.5) then
month = e - 1.0
else
month = e - 13.0
end if
if (month > 2.5) then
year = c - 4716.0
else
year = c - 4715.0
end if
end sub
sub getdate (month, day, year)
' request calendar date subroutine
do
print " "
print "please input the calendar date"
print " "
print "(month [1 - 12], day [1 - 31], year [yyyy])"
print "< for example, october 21, 1986 is input as 10,21,1986 >"
print "< b.c. dates are negative, a.d. dates are positive >"
print "< the day of the month may also include a decimal part >"
print " "
input month, day, year
loop until (month >= 1 and month <= 12) and (day >= 1 and day <= 31)
end sub
sub gettime (thr, tmin, tsec)
' request time subroutine
do
print " "
print "please input the time"
print " "
print "(hours [0 - 24], minutes [0 - 60], seconds [0 - 60])"
print " "
input thr, tmin, tsec
loop until (thr >= 0.0 and thr <= 24.0 and tmin >= 0.0 and tmin <= 60.0 and tsec >= 0.0 and tsec <= 60.0)
end sub
panky
Posted: 01:25am 05 Mar 2017
@cdeagle
Nice work mate, hope to get a chance to play with this soon,
Well done,
Doug.
