Local Time 13:32 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM, + and X - linear interpolation
cdeagle
Posted: 08:18am 07 Mar 2017
This post describes a MMBASIC program that can be used to linearly interpolate tabular data provided by the user. Although written and checked out on the MMX, it should work for all versions of the Micromite.
Here's a typical user interaction with a demo program that shows how to interact with the subroutine that actually performs the interpolation. Please note the x data values must be provided in ascending order.
program demo_lnt1
this program demonstrates the procedure for calling
the subroutine interp1 which performs a linear
interpolation of tabular data input by the user.
subroutine interp1 performs linear interpolation of
data of the form y = f(x).
note: the data must be ordered as follows:
x(1) < x(2) < x(3) < .... < x(n)
please input the number of x and y data points
(a minimum of two x and y data points must be input)
? 4
please input the x data for point # 1
? 1
please input the y data for point # 1
? 1
please input the x data for point # 2
? 2
please input the y data for point # 2
? 4
please input the x data for point # 3
? 3
please input the y data for point # 3
? 9
please input the x data for point # 4
? 4
please input the y data for point # 4
? 16
please input the x value to interpolate
? 3.3
program demo_lnt1
<linear interpolation of y = f(x)>
interpolated value = 3.3
function value = 11.1
Here's the source code listing.
' program demo_lnt1.bas March 7, 2017
' this program demonstrates the procedure for calling
' the subroutine interp1 which performs a linear
' interpolation of tabular data input by the user.
' subroutine interp1 performs linear interpolation of
' data of the form y = f(x).
' note: the data must be ordered as follows:
' x(1) < x(2) < x(3) < .... < x(n)
print " "
print "program demo_lnt1"
print " "
print "this program demonstrates the procedure for calling"
print "the subroutine interp1 which performs a linear"
print "interpolation of tabular data input by the user."
print " "
print "subroutine interp1 performs linear interpolation of"
print "data of the form y = f(x)."
print " "
print "note: the data must be ordered as follows:"
print " "
print "x(1) < x(2) < x(3) < .... < x(n)"
do
print " "
print "please input the number of x and y data points"
print "(a minimum of two x and y data points must be input)"
input npts%
loop until (npts% >= 2)
' dimension arrays
dim x(npts%) as float, y(npts%) as float
for i% = 1 to npts%
print " "
print "please input the x data for point #"; i%
input x(i%)
print " "
print "please input the y data for point #"; i%
input y(i%)
next i%
do
print " "
print "please input the x value to interpolate"
input xval
loop until (xval >= x(1) and xval <= x(npts%))
' perform linear interpolation
interp1(npts%, xval, fval)
print " "
print " "
print "<linear interpolation of y = f(x)>"
print " "
print "interpolated value = ", xval
print " "
print "function value = ", fval
print " "
end
sub interp1(n%, xval, fval)
' linear interpolation subroutine
' y = f(x)
' input
' n = number of x and y data points (n >= 2)
' x() = vector of x data (n rows)
' y() = vector of y data (n rows)
' xval = x argument
' output
' fval = interpolated function value at xval
local xinfac, y1, y2
' compute index and interpolation factor
for i% = 1 to n%
if (xval <= x(i%)) then
if (i% = 1) then
xinfac = 0.0
index& = 1
else
j% = i% - 1
xinfac = (xval - x(j%)) / (x(i%) - x(j%))
index% = j%
end if
exit for
end if
next i%
y1 = y(index%)
y2 = y(index% + 1)
fval = y1 + xinfac * (y2 - y1)
end sub
Posted: 08:51am 07 Mar 2017
Hi David,
Thanks for sharing all your code recently - I can see your having fun with your MMX144 Module
Hopefully others will find something useful from your posts over the last few days.
Do let us know if you come across any 'strange' behaviour in your usage of double-precision calculations.
WW
