Local Time 13:29 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX- lunar eclipse
cdeagle
Posted: 07:18am 15 Mar 2017
This post is an MMBASIC computer program for the MicroMite eXtreme which can be used to predict the local circumstances of lunar eclipses. The software uses a combination of one-dimensional minimization and root-finding to calculate these conditions.
Here's a typical user interaction with the software. The program will take a minute or so to run to completion. Be patient, it's performing thousands of hardware-based, double precision calculations looking for the answer. The source code listing is 3200+ lines of comments, data statements, white space and actual code.
program lunar_eclipse
please input the initial calendar date
(month [1 - 12], day [1 - 31], year [yyyy])
< for example, october 21, 1986 is input as 10,21,1986 >
< b.c. dates are negative, a.d. dates are positive >
< the day of the month may also include a decimal part >
? 12,1,2000
please input the geographic latitude of the observer
(degrees [-90 to +90], minutes [0 - 60], seconds [0 - 60])
(north latitudes are positive, south latitudes are negative)
? 39,40,36
please input the geographic longitude of the observer
(degrees [0 - 360], minutes [0 - 60], seconds [0 - 60])
(east longitude is positive, west longitude is negative)
? -104,57,12
please input the altitude of the observer (meters)
(positive above sea level, negative below sea level)
? 1644
please input the search duration in days
? 30
searching for lunar eclipse ...
Here's the program output for this example.
total lunar eclipse
begin penumbral phase of lunar eclipse
calendar date January 21 2000
UTC time 2 hours 2 minutes 51.52 seconds
UTC julian day 2451564.58531852
topocentric coordinates
lunar azimuth angle 83 deg 3 min 50.49 sec
lunar elevation angle 22 deg 43 min 45.01 sec
greatest eclipse conditions
UTC time 4 hours 43 minutes 27.56 seconds
UTC julian day 2451564.69684679
lunar azimuth angle 111 deg 22 min 33.61 sec
lunar elevation angle 52 deg 6 min 11.99 sec
end penumbral phase of lunar eclipse
UTC time 7 hours 24 minutes 8.60 seconds
UTC julian day 2451564.80843287
lunar azimuth angle 184 deg 39 min 40.61 sec
lunar elevation angle 69 deg 27 min 51.25 sec
event duration 5.35474459 hours
Here's a zip archive of the MMBASIC source code and MATLAB PDF file for the lunar eclipse computer program.
2017-03-15_171630_lunar_eclipse.zip
Posted: 11:06am 15 Mar 2017
Amazing program and a great demo of the value of double precision floating point.
Frank N. Furter
Posted: 11:57pm 15 Mar 2017
Hi Cdeagle,
thank you very much for your code!
(I'm very curious about your code for calculating the planet positions... )
Frank
