Local Time 12:41 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - sun rise and set
cdeagle
Posted: 08:23am 17 Mar 2017
This post provides an MMBASIC program for the MicroMite eXtreme that predicts rise and set conditions of the sun. The software includes a simple algorithm for refraction.
Here's a typical user interaction with the software and some results.
rise and set of the sun
please input the calendar date
(month [1 - 12], day [1 - 31], year [yyyy])
< for example, october 21, 1986 is input as 10,21,1986 >
< b.c. dates are negative, a.d. dates are positive >
< the day of the month may also include a decimal part >
? 3,16,2017
please input the geographic latitude of the observer
(degrees [-90 to +90], minutes [0 - 60], seconds [0 - 60])
(north latitudes are positive, south latitudes are negative)
? 39,45...
please input the geographic longitude of the observer
(degrees [0 - 360], minutes [0 - 60], seconds [0 - 60])
(east longitude is positive, west longitude is negative)
> run
? 3,16,2017
? 39,40,36
? -104,57,12
please input the altitude of the observer (meters)
(positive above sea level, negative below sea level)
? 1644
please input the number of days to simulate
? 5
searching for rise and set conditions ...
rise conditions
calendar date March 16 2017
UTC time 0 hours 0 minutes 0.00 seconds
UTC julian day 2457828.50000000
topocentric coordinates
solar azimuth angle 257 deg 30 min 51.88 sec
solar elevation angle 11 deg 56 min 57.91 sec
maximum elevation conditions
set conditions
UTC time 1 hours 6 minutes 23.31 seconds
UTC julian day 2457828.54610312
solar azimuth angle 268 deg 19 min 35.69 sec
solar elevation angle 0 deg -42 min 2.38 sec
event duration 1 hours 6 minutes 23.31 seconds
rise conditions
UTC time 13 hours 9 minutes 49.17 seconds
UTC julian day 2457829.04848581
solar azimuth angle 91 deg 24 min 55.96 sec
solar elevation angle 0 deg -42 min 2.31 sec
UTC time 19 hours 12 minutes 0.00 seconds
UTC julian day 2457829.30000001
solar azimuth angle 181 deg 24 min 36.48 sec
solar elevation angle 48 deg 52 min 37.70 sec
set conditions
calendar date March 17 2017
UTC time 1 hours 7 minutes 24.83 seconds
UTC julian day 2457829.54681520
solar azimuth angle 268 deg 50 min 25.12 sec
solar elevation angle 0 deg -42 min 2.24 sec
event duration 11 hours 57 minutes 35.66 seconds
rise conditions
UTC time 13 hours 8 minutes 13.32 seconds
UTC julian day 2457830.04737634
solar azimuth angle 90 deg 54 min 9.52 sec
solar elevation angle 0 deg -42 min 2.17 sec
UTC time 19 hours 8 minutes 12.88 seconds
UTC julian day 2457830.29737126
solar azimuth angle 180 deg 4 min 54.17 sec
solar elevation angle 49 deg 16 min 48.39 sec
set conditions
calendar date March 18 2017
UTC time 1 hours 8 minutes 26.19 seconds
UTC julian day 2457830.54752533
solar azimuth angle 269 deg 21 min 15.19 sec
solar elevation angle 0 deg -42 min 2.11 sec
event duration 12 hours 0 minutes 12.87 seconds
Here's the source code listing followed by a link to the PDF explanation/user's manual for the MATLAB version of the code.
' sun_riseset.bas March 17, 2017
' rise and set of the sun
' Micromite eXtreme version
option default float
option base 1
' dimension global arrays and variables
dim xsl(50), xsr(50), xsa(50), xsb(50)
dim jdleap(28), leapsec(28)
dim month$(12) as string
dim xnut(11, 13), trr, elev_minima
dim jdsaved, jdprint, obslat, obslong, obsalt
dim jdtdbi, i as integer, j as integer
dim cmonth, cday, cyear, ndays
dim rootflag% as integer
' global constants
const pi2 = 2.0 * pi, pidiv2 = 0.5 * pi, dtr = pi / 180.0, rtd = 180.0 / pi
const atr = pi / 648000.0, seccon = 206264.8062470964
' astronomical unit (kilometers)
const aunit = 149597870.691
' equatorial radius of the earth (kilometers)
const reqm = 6378.14
' earth flattening factor (nd)
const flat = 1.0 / 298.257
' read solar ephemeris data
for i = 1 to 50
read xsl(i), xsr(i), xsa(i), xsb(i)
next i
data 403406, 0, 4.721964, 1.621043
data 195207, -97597, 5.937458, 62830.348067
data 119433, -59715, 1.115589, 62830.821524
data 112392, -56188, 5.781616, 62829.634302
data 3891, -1556, 5.5474 , 125660.5691
data 2819, -1126, 1.5120 , 125660.9845
data 1721, -861, 4.1897 , 62832.4766
data 0, 941, 1.163 , 0.813
data 660, -264, 5.415 , 125659.310
data 350, -163, 4.315 , 57533.850
data 334, 0, 4.553 , -33.931
data 314, 309, 5.198 , 777137.715
data 268, -158, 5.989 , 78604.191
data 242, 0, 2.911 , 5.412
data 234, -54, 1.423 , 39302.098
data 158, 0, 0.061 , -34.861
data 132, -93, 2.317 , 115067.698
data 129, -20, 3.193 , 15774.337
data 114, 0, 2.828 , 5296.670
data 99, -47, 0.52 , 58849.27
data 93, 0, 4.65 , 5296.11
data 86, 0, 4.35 , -3980.70
data 78, -33, 2.75 , 52237.69
data 72, -32, 4.50 , 55076.47
data 68, 0, 3.23 , 261.08
data 64, -10, 1.22 , 15773.85
data 46, -16, 0.14 , 188491.03
data 38, 0, 3.44 , -7756.55
data 37, 0, 4.37 , 264.89
data 32, -24, 1.14 , 117906.27
data 29, -13, 2.84 , 55075.75
data 28, 0, 5.96 , -7961.39
data 27, -9, 5.09 , 188489.81
data 27, 0, 1.72 , 2132.19
data 25, -17, 2.56 , 109771.03
data 24, -11, 1.92 , 54868.56
data 21, 0, 0.09 , 25443.93
data 21, 31, 5.98 , -55731.43
data 20, -10, 4.03 , 60697.74
data 18, 0, 4.27 , 2132.79
data 17, -12, 0.79 , 109771.63
data 14, 0, 4.24 , -7752.82
data 13, -5, 2.01 , 188491.91
data 13, 0, 2.65 , 207.81
data 13, 0, 4.98 , 29424.63
data 12, 0, 0.93 , -7.99
data 10, 0, 2.21 , 46941.14
data 10, 0, 3.59 , -68.29
data 10, 0, 1.50 , 21463.25
data 10, -9, 2.55 , 157208.40
' read subset of IAU2000 nutation data
for j = 1 to 13
for i = 1 to 11
read xnut(i, j)
next i
next j
data 0, 0, 0, 0, 1, -172064161, -174666, 92052331, 9086, 33386, 15377
data 0, 0, 2, -2, 2, -13170906, -1675, 5730336, -3015, -13696, -4587
data 0, 0, 2, 0, 2, -2276413, -234, 978459, -485, 2796, 1374
data 0, 0, 0, 0, 2, 2074554, 207, -897492, 470, -698, -291
data 0, 1, 0, 0, 0, 1475877, -3633, 73871, -184, 11817, -1924
data 0, 1, 2, -2, 2, -516821, 1226, 224386, -677, -524, -174
data 1, 0, 0, 0, 0, 711159, 73, -6750, 0, -872, 358
data 0, 0, 2, 0, 1, -387298, -367, 200728, 18, 380, 318
data 1, 0, 2, 0, 2, -301461, -36, 129025, -63, 816, 367
data 0, -1, 2, -2, 2, 215829, -494, -95929, 299, 111, 132
data 0, 0, 2, -2, 1, 128227, 137, -68982, -9, 181, 39
data -1, 0, 2, 0, 2, 123457, 11, -53311, 32, 19, -4
data -1, 0, 0, 2, 0, 156994, 10, -1235, 0, -168, 82
' read leap second data
for i = 1 to 28
read jdleap(i), leapsec(i)
next i
data 2441317.5, 10.0
data 2441499.5, 11.0
data 2441683.5, 12.0
data 2442048.5, 13.0
data 2442413.5, 14.0
data 2442778.5, 15.0
data 2443144.5, 16.0
data 2443509.5, 17.0
data 2443874.5, 18.0
data 2444239.5, 19.0
data 2444786.5, 20.0
data 2445151.5, 21.0
data 2445516.5, 22.0
data 2446247.5, 23.0
data 2447161.5, 24.0
data 2447892.5, 25.0
data 2448257.5, 26.0
data 2448804.5, 27.0
data 2449169.5, 28.0
data 2449534.5, 29.0
data 2450083.5, 30.0
data 2450630.5, 31.0
data 2451179.5, 32.0
data 2453736.5, 33.0
data 2454832.5, 34.0
DATA 2456109.5, 35.0
data 2457204.5, 36.0
data 2457754.5, 37.0
' calendar months
month$(1) = "January"
month$(2) = "February"
month$(3) = "March"
month$(4) = "April"
month$(5) = "May"
month$(6) = "June"
month$(7) = "July"
month$(8) = "August"
month$(9) = "September"
month$(10) = "October"
month$(11) = "November"
month$(12) = "December"
' begin simulation
print " "
print "rise and set of the sun"
print "======================="
print " "
' request initial calendar date (month, day, year)
getdate(cmonth, cday, cyear)
' request observer coordinates
print " "
observer(obslat, obslong, obsalt)
' initial utc julian day
julian(cmonth, cday, cyear, jdutc)
' compute initial tdb julian date
utc2tdb(jdutc, jdtdb)
jdtdbi = jdtdb
' search duration (days)
print " "
print "please input the number of days to simulate"
input ndays
print " "
print "searching for rise and set conditions ..."
print " "
' define search parameters
ti = 0.0
tf = ndays
dt = 0.1
dtsml = 0.01
rootflag% = 0
' find sun rise/set conditions
rs_event(ti, tf, dt, dtsml)
end
sub rsfunc(x, fx)
' rise/set objective function
local jdtdb, rsun(3), gast, azim, elev
local dis, dref, sdia
' current TDB julian day
jdtdb = jdtdbi + x
' compute eci position vector and distance of the sun
sun(jdtdb, rsun())
dis = vecmag(rsun()) / aunit
' compute topocentric coordinates of the sun
tdb2utc(jdtdb, jdutc)
gast2(jdutc, gast)
eci2topo(gast, rsun(), azim, elev)
if (rootflag% = 1) then
' correct for horizontal refraction
dref = (34.0 / 60.0)
' correct for semidiameter of the sun
tsdia = rtd * asin((0.5 * 696000.0 / aunit) / dis)
else
dref = 0.0
tsdia = 0.0
end if
' evaluate objective function
fx = -(rtd * elev + tsdia + dref)
end sub
sub rs_event (ti, tf, dt, dtsml)
' predict rise/set events
' input
' ti = initial simulation time
' tf = final simulation time
' dt = step size used for bounding minima
' dtsml = small step size used to determine whether
' the function is increasing or decreasing
LOCAL tolm, iend as integer
local fmin1, tmin1
LOCAL ftemp, df, dflft
local el, er
LOCAL t, ft
local iter1 as integer, iter2 as integer
local iter3 as integer
' initialization
tolm = 1.0e-8
iend = 0
' check the initial time for a minimum
rsfunc(ti, fmin1)
tmin1 = ti
rsfunc(ti + dtsml, ftemp)
df = ftemp - fmin1
dflft = df
el = ti
er = el
t = ti
' if the slope is positive and the minimum is
' negative, calculate event conditions at the initial time
if (df > 0.0 and fmin1 < 0.0) then
events1(ti, tf, tmin1)
end if
for iter1 = 1 to 1000
' find where function first starts decreasing
for iter2 = 1 to 1000
if (df <= 0.0) then
exit for
end if
t = t + dt
if (t >= tf) then
' check final time for a minimum
if (iend = 1) then exit sub
rsfunc(tf, fmin1)
rsfunc(tf - dtsml, ftemp)
df = fmin1 - ftemp
' set minimum time to final simulation time
tmin1 = tf
if (df < 0.0) then
' if both the slope and minimum are negative,
' calculate the event conditions at the final
' simulation time
if (fmin1 < 0.0) then
end if
' otherwise, we're finished
exit sub
end if
if (dflft > 0.0) then exit sub
er = tf
iend = 1
end if
rsfunc(t, ft)
rsfunc(t - dtsml, ftemp)
df = ft - ftemp
next iter2
' function decreasing - find where function
' first starts increasing
for iter3 = 1 to 1000
el = t
dflft = df
t = t + dt
if (t >= tf) then
rsfunc(tf, fmin1)
df = fmin1 - ftemp
tmin1 = tf
if (df < 0.0) then
' simulation time
end if
exit sub
end if
er = tf
iend = 1
end if
rsfunc(t, ft)
df = ft - ftemp
if (df > 0.0) then exit for
next iter3
er = t
' calculate minimum using Brent's method
minima(el, er, tolm, tmin1, fmin1)
el = er
dflft = df
' if the minimum is negative,
' calculate event conditions for this minimum
t = trr
end if
next iter1
end sub
sub events1 (ti, tf, topt)
' compute and display rise/set events
' input
' topt = extrema time
' define root-bracketing and root-finding control parameters
LOCAL factor = 0.25 ' geometric acceleration factor
LOCAL dxmax = 0.1 ' rectification interval
LOCAL rtol = 1.0e-8 ' root-finding convergence tolerance
LOCAL t1in, t2in
local t1out, t2out
LOCAL troot, froot, jdate
local iter as integer
' compute and display rise conditions
rootflag% = 1
t1in = topt
t2in = t1in - 0.05
broot(t1in, t2in, factor, dxmax, t1out, t2out)
realroot1(t1out, t2out, rtol, troot, froot)
' set to initial time if before ti
if (troot < ti) then
troot = ti
rsfunc(ti, froot)
end if
jdate = jdtdbi + troot
rsprint(1, jdate)
' display maximum elevation conditions
rootflag% = 0
jdate = jdtdbi + topt
rsprint(2, jdate)
' compute and display set conditions
rootflag% = 1
t2in = t1in + 0.05
' set to final time if after tf
if (troot > tf) then
troot = tf
rsfunc(tf, froot)
end if
trr = troot
rsprint(3, jdate)
rootflag% = 0
END sub
sub rsprint(iflag, jdtdb)
' print rise and set conditions
local rsun(3)
LOCAL jdutc, dms$ as string
local deltat, gast, azimuth, elevation
if (iflag = 1) then
print " "
print "rise conditions"
PRINT "---------------"
print " "
jdprint = jdtdb
end if
if (iflag = 2) then
print " "
print "maximum elevation conditions"
PRINT "----------------------------"
print " "
end if
if (iflag = 3) then
print " "
print "set conditions"
PRINT "--------------"
print " "
end if
' compute and display UTC julian date
jd2str(jdutc)
PRINT " "
print "UTC julian day ", str$(jdutc, 0, 8)
' compute and display topocentric coordinates of the sun
gast2(jdutc, gast)
sun(jdtdb, rsun())
eci2topo(gast, rsun(), azimuth, elevation)
PRINT " "
print "topocentric coordinates"
PRINT " "
deg2str(rtd * azimuth, dms$)
print "solar azimuth angle ", dms$
PRINT " "
deg2str(rtd * elevation, dms$)
print "solar elevation angle ", dms$
' determine and display event duration
if (iflag = 3) then
deltat = 24.0 * (jdtdb - jdprint)
PRINT " "
hrs2str(deltat)
print " "
end if
END sub
sub minima(a, b, tolm, xmin, fmin)
' one-dimensional minimization
' Brent's method
' input
' a = initial x search value
' b = final x search value
' tolm = convergence criterion
' output
' xmin = minimum x value
' note
' user-defined objective subroutine
' coded as usr_func(x, fx)
' remember: a maximum is simply a minimum
' with a negative attitude!
' machine epsilon
LOCAL epsm = 2.23e-16
' golden number
LOCAL c = 0.38196601125
LOCAL iter as integer, d, e
LOCAL t2, p, q
local r, u, fu
LOCAL x, xm, w
local v, fx, fw
LOCAL tol1, fv
x = a + c * (b - a)
w = x
v = w
e = 0.0
p = 0.0
q = 0.0
r = 0.0
rsfunc(x, fx)
fw = fx
fv = fw
for iter = 1 to 100
if (iter > 50) then
print ("error in function minima!")
print ("(more than 50 iterations)")
end if
xm = 0.5 * (a + b)
tol1 = tolm * abs(x) + epsm
t2 = 2.0 * tol1
if (abs(x - xm) <= (t2 - 0.5 * (b - a))) then
xmin = x
fmin = fx
exit sub
end if
if (abs(e) > tol1) then
r = (x - w) * (fx - fv)
q = (x - v) * (fx - fw)
p = (x - v) * q - (x - w) * r
q = 2.0 * (q - r)
if (q > 0.0) then
p = -p
end if
q = abs(q)
r = e
e = d
end if
if ((abs(p) >= abs(0.5 * q * r)) or (p <= q * (a - x)) or (p >= q * (b - x))) then
if (x >= xm) then
e = a - x
else
e = b - x
end if
d = c * e
else
d = p / q
u = x + d
if ((u - a) < t2) or ((b - u) < t2) then
d = sgn(xm - x) * tol1
end if
end if
if (abs(d) >= tol1) then
u = x + d
else
u = x + sgn(d) * tol1
end if
rsfunc(u, fu)
if (fu <= fx) then
if (u >= x) then
a = x
else
b = x
end if
v = w
fv = fw
w = x
fw = fx
x = u
fx = fu
else
if (u < x) then
a = u
else
b = u
end if
if ((fu <= fw) Or (w = x)) then
v = w
fv = fw
w = u
fw = fu
elseif ((fu <= fv) Or (v = x) Or (v = w)) then
v = u
fv = fu
end if
end if
next iter
end sub
sub gsite (angle, rsite())
' ground site position vector
' input
' angle = local sidereal time or east longitude
' (radians; 0 <= angle <= 2*pi)
' input via global
' obslat = geodetic latitude (radians)
' (+north, -south; -pi/2 <= lat <= -pi/2)
' obsalt = geodetic altitude (meters)
' (+ above sea level, - below sea level)
' output
' rsite = ground site position vector (kilometers)
' special notes
' (1) eci coordinates if angle = local sidereal time
' (2) ecf coordinates if angle = east longitude
' (3) geocentric, equatorial coordinates
LOCAL slat, clat
local sangle, cangle
LOCAL b, c, d
slat = sin(obslat)
clat = cos(obslat)
sangle = sin(angle)
cangle = cos(angle)
' compute geodetic constants
b = sqr(1.0 - (2.0 * flat - flat * flat) * slat * slat)
c = reqm / b + 0.001 * obsalt
d = reqm * (1.0 - flat) * (1.0 - flat) / b + 0.001 * obsalt
' compute x, y and z components of position vector (kilometers)
rsite(1) = c * clat * cangle
rsite(2) = c * clat * sangle
rsite(3) = d * slat
END sub
sub gast2(jdate, gast)
' greenwich apparent sidereal time
' input
' jdate = julian date
' output
' gast = greenwich apparent sidereal time (radians)
LOCAL t, t2, t3, eqeq, dpsi, deps
LOCAL th, tl, obm, obt, st, x
local tjdh as integer, tjdl
tjdh = int(jdate)
tjdl = jdate - tjdh
th = (tjdh - 2451545.0) / 36525
tl = tjdl / 36525.0
t = th + tl
t2 = t * t
t3 = t2 * t
' obtain equation of the equinoxes
eqeq = 0.0
' obtain nutation parameters in seconds of arc
nut2000_lp(jdate, dpsi, deps)
' compute mean obliquity of the ecliptic in seconds of arc
obm = 84381.4480 - 46.8150 * t - 0.00059 * t2 + 0.001813 * t3
' compute true obliquity of the ecliptic in seconds of arc
obliq = obm + deps
' compute equation of the equinoxes in seconds of time
eqeq = (dpsi / 15.0) * cos(obliq / seccon)
st = eqeq - 6.2e-6 * t3 + 0.093104 * t2 + 67310.54841 + 8640184.812866 * tl + 3155760000.0 * tl + 8640184.812866 * th + 3155760000.0 * th
' modulo 24 hours
x = st / 3600.0
gast = x - 24.0 * fix(x / 24.0)
if (gast < 0.0) then
gast = gast + 24.0
end if
' convert to radians
gast = pi2 * (gast / 24.0)
END sub
sub tdb2utc (jdtdb, jdutc)
' convert TDB julian day to UTC julian day subroutine
' input
' jdtdb = TDB julian day
' output
' jdutc = UTC julian day
local x1, x2, xroot, froot
jdsaved = jdtdb
' set lower and upper bounds
x1 = jdsaved - 0.1
x2 = jdsaved + 0.1
' solve for UTC julian day using Brent's method
realroot2(x1, x2, 1.0e-8, xroot, froot)
jdutc = xroot
end sub
sub jdfunc (jdin, fx)
' objective function for tdb2utc
' input
' jdin = current value for UTC julian day
' output
' fx = delta julian day
local jdwrk
utc2tdb(jdin, jdwrk)
fx = jdwrk - jdsaved
end sub
sub sun(jd, rsun())
' precision ephemeris of the Sun
' input
' jd = julian ephemeris day
' output
' rsun = eci position of the sun
local u, a1, a2, psi, deps, meps, eps, seps, ceps
local dl, dr, w, srl, crl, srb, crb, sra, cra
u = (jd - 2451545.0) / 3652500.0
' compute nutation in longitude
a1 = 2.18 + u * (-3375.7 + u * 0.36)
a2 = 3.51 + u * (125666.39 + u * 0.1)
psi = 0.0000001 * (-834.0 * sin(a1) - 64.0 * sin(a2))
' compute nutation in obliquity
deps = 0.0000001 * u * (-226938 + u * (-75 + u * (96926 + u * (-2491 - u * 12104))))
meps = 0.0000001 * (4090928.0 + 446.0 * cos(a1) + 28.0 * cos(a2))
eps = meps + deps
obliq = eps
seps = sin(eps)
ceps = cos(eps)
dl = 0.0
dr = 0.0
for i% = 1 to 50
w = xsa(i%) + xsb(i%) * u
dl = dl + xsl(i%) * sin(w)
if (xsr(i%) <> 0.0) then
dr = dr + xsr(i%) * cos(w)
end if
next i%
dl = modulo(dl * 0.0000001 + 4.9353929 + 62833.196168 * u)
dr = aunit * (dr * 0.0000001 + 1.0001026)
rlsun = modulo(dl + 0.0000001 * (-993.0 + 17.0 * cos(3.1 + 62830.14 * u)) + psi)
rb = 0.0
' compute geocentric declination and right ascension
crl = cos(rlsun)
srl = sin(rlsun)
crb = cos(rb)
srb = sin(rb)
decl = asin(ceps * srb + seps * crb * srl)
sra = -seps * srb + ceps * crb * srl
cra = crb * crl
rasc = atan3(sra, cra)
' geocentric equatorial position vector of the Sun (au)
rsun(1) = dr * cos(rasc) * cos(decl)
rsun(2) = dr * sin(rasc) * cos(decl)
rsun(3) = dr * sin(decl)
end sub
sub eci2topo(gast, robj(), azim, elev)
' convert eci position vector to topocentric coordinates
' input
' gast = Greenwich apparent sidereal time (radians)
' robj = eci position vector of object (kilometers)
' output
' azim = topocentric azimuth (radians)
' elev = topocentric elevation (radians)
local rsite(3), rhoijk(3), rhohatijk(3), rhohatsez(3)
local i as integer, tmatrix(3, 3)
LOCAL obslst, srange, sobslat
local cobslat, sobslst, cobslst
' observer local sidereal time
obslst = modulo(gast + obslong)
gsite(obslst, rsite())
' eci vector from observer to moon
for i = 1 to 3
rhoijk(i) = aunit * robj(i) - rsite(i)
next i
' observer-to-object slant range (kilometers)
srange = vecmag(rhoijk())
' compute topocentric unit pointing vector
uvector(rhoijk(), rhohatijk())
' compute eci-to-sez transformation matrix
sobslat = sin(obslat)
cobslat = cos(obslat)
sobslst = sin(obslst)
cobslst = cos(obslst)
tmatrix(1, 1) = sobslat * cobslst
tmatrix(1, 2) = sobslat * sobslst
tmatrix(1, 3) = -cobslat
tmatrix(2, 1) = -sobslst
tmatrix(2, 2) = cobslst
tmatrix(2, 3) = 0.0
tmatrix(3, 1) = cobslat * cobslst
tmatrix(3, 2) = cobslat * sobslst
tmatrix(3, 3) = sobslat
' compute sez coordinates
matxvec(tmatrix(), rhohatijk(), rhohatsez())
' topocentric elevation (radians)
elev = asin(rhohatsez(3))
' topocentric azimuth (radians)
azim = atan3(rhohatsez(2), -rhohatsez(1))
END sub
sub broot(x1in, x2in, factor, dxmax, x1out, x2out)
' bracket a single root of a nonlinear equation
' input
' x1in = initial guess for first bracketing x value
' x2in = initial guess for second bracketing x value
' factor = acceleration factor (non-dimensional)
' dxmax = rectification interval
' output
' xout1 = final value for first bracketing x value
' xout2 = final value for second bracketing x value
LOCAL f1, f2
local x3, dx
' evaluate objective function at initial value
rsfunc(x1in, f1)
' save initial value
x3 = x1in
' save initial delta-x
dx = x2in - x1in
' perform bracketing until the product of the
' two function values is negative
do
' geometrically accelerate the second point
x2in = x2in + factor * (x2in - x3)
' evaluate objective function at x2
rsfunc(x2in, f2)
' check to see if rectification is required
if (abs(x2in - x3) > dxmax) then
x3 = x2in - dx
end if
' is the root bracketed?
if ((f1 * f2) < 0.0) then exit do
loop
x1out = x1in
x2out = x2in
END sub
sub realroot1(x1, x2, tol, xroot, froot)
' real root of a single non-linear function subroutine
' input
' x1 = lower bound of search interval
' x2 = upper bound of search interval
' tol = convergence criter%ia
' output
' xroot = real root of f(x) = 0
' froot = function value
' note: requires sub rsfunc
local eps, a, b, c, d, e, fa, fb, fcc, tol1
local xm, p, q, r, s, xmin, tmp
eps = 2.23e-16
e = 0.0
a = x1
b = x2
rsfunc(a, fa)
rsfunc(b, fb)
fcc = fb
for iter% = 1 to 50
if (fb * fcc > 0.0) then
c = a
fcc = fa
d = b - a
e = d
end if
if (abs(fcc) < abs(fb)) then
a = b
b = c
c = a
fa = fb
fb = fcc
fcc = fa
end if
tol1 = 2.0 * eps * abs(b) + 0.5 * tol
xm = 0.5 * (c - b)
if (abs(xm) <= tol1 or fb = 0.0) then exit for
if (abs(e) >= tol1 and abs(fa) > abs(fb)) then
s = fb / fa
if (a = c) then
p = 2.0 * xm * s
q = 1.0 - s
else
q = fa / fcc
r = fb / fcc
p = s * (2.0 * xm * q * (q - r) - (b - a) * (r - 1.0))
q = (q - 1.0) * (r - 1.0) * (s - 1.0)
end if
if (p > 0.0) then q = -q
p = abs(p)
min = abs(e * q)
tmp = 3.0 * xm * q - abs(tol1 * q)
if (min < tmp) then min = tmp
if (2.0 * p < min) then
e = d
d = p / q
else
d = xm
e = d
end if
else
d = xm
e = d
end if
a = b
fa = fb
if (abs(d) > tol1) then
b = b + d
else
b = b + sgn(xm) * tol1
end if
rsfunc(b, fb)
next iter%
froot = fb
xroot = b
end sub
sub realroot2(x1, x2, tol, xroot, froot)
' input
' output
' note: requires sub jdfunc
eps = 2.23e-16
e = 0.0
a = x1
b = x2
jdfunc(a, fa)
jdfunc(b, fb)
fcc = fb
for iter% = 1 to 50
c = a
fcc = fa
d = b - a
e = d
end if
a = b
b = c
c = a
fa = fb
fb = fcc
fcc = fa
end if
xm = 0.5 * (c - b)
if (abs(xm) <= tol1 or fb = 0) then exit for
s = fb / fa
if (a = c) then
p = 2.0 * xm * s
q = 1.0 - s
else
q = fa / fcc
r = fb / fcc
end if
if (p > 0) then q = -q
p = abs(p)
xmin = abs(e * q)
if (xmin < tmp) then xmin = tmp
if (2.0 * p < xmin) then
e = d
d = p / q
else
d = xm
e = d
end if
else
d = xm
e = d
end if
a = b
fa = fb
b = b + d
else
end if
jdfunc(b, fb)
next iter%
froot = fb
xroot = b
end sub
sub nut2000_lp(jdate, dpsi, deps)
' low precison nutation based on iau 2000a
' this function evaluates a short nutation series and returns approximate
' values for nutation in longitude and nutation in obliquity for a given
' tdb julian date. in this mode, only the largest 13 terms of the iau 2000a
' nutation series are evaluated.
' input
' jdate = tdb julian date
' output
' dpsi = nutation in longitude in arcseconds
' deps = nutation in obliquity in arcseconds
LOCAL rev = 360.0 * 3600.0
LOCAL el, elp, f, d, omega
LOCAL i%, arg
LOCAL t = (jdate - 2451545.0) / 36525.0
' computation of fundamental (delaunay) arguments from simon et al. (1994)
' mean anomaly of the moon
el = (485868.249036 + t * (1717915923.2178 + t * (31.8792 + t * (0.051635 + t * (-0.00024470)))) mod rev) / seccon
' mean anomaly of the sun
elp = (1287104.79305 + t * (129596581.0481 + t * (-0.5532 + t * (0.000136 + t * (- 0.00001149)))) mod rev) / seccon
' mean argument of the latitude of the moon
f = (335779.526232 + t * (1739527262.8478 + t * (-12.7512 + t * (-0.001037 + t * (0.00000417)))) mod rev) / seccon
' mean elongation of the moon from the sun
d = (1072260.70369 + t * (1602961601.2090 + t * (- 6.3706 + t * (0.006593 + t * (- 0.00003169)))) mod rev) / seccon
' mean longitude of the ascending node of the moon (from simon section 3.4(b.3), precession = 5028.8200 arcsec/cy)
omega = (450160.398036 + t * (- 6962890.5431 + t * (7.4722 + t * (0.007702 + t * (- 0.00005939)))) mod rev) / seccon
dpsi = 0.0
deps = 0.0
' sum nutation series terms
for i% = 13 to 1 step -1
arg = xnut(1, i%) * el + xnut(2, i%) * elp + xnut(3, i%) * f + xnut(4, i%) * d + xnut(5, i%) * omega
dpsi = (xnut(6, i%) + xnut(7, i%) * t) * sin(arg) + xnut(10, i%) * cos(arg) + dpsi
deps = (xnut(8, i%) + xnut(9, i%) * t) * cos(arg) + xnut(11, i%) * sin(arg) + deps
next i%
dpsi = 1.0e-7 * dpsi
deps = 1.0e-7 * deps
' add in out-of-phase component of principal (18.6-year) term
' (to avoid small but long-term bias in results)
dpsi = dpsi + 0.0033 * cos(omega)
deps = deps + 0.0015 * sin(omega)
END sub
sub getdate (month, day, year)
' request calendar date subroutine
do
print " "
print "please input the calendar date"
print " "
print "(month [1 - 12], day [1 - 31], year [yyyy])"
print "< for example, october 21, 1986 is input as 10,21,1986 >"
print "< b.c. dates are negative, a.d. dates are positive >"
print "< the day of the month may also include a decimal part >"
print " "
input month, day, year
loop until (month >= 1 and month <= 12) and (day >= 1 and day <= 31)
end sub
sub observer(obslat, obslong, obsalt)
' interactive request of latitude, longitude and altitude subroutine
' output
' obslat = latitude (radians)
' obslong = longitude (radians)
' obsalt = altitude (meters)
do
print "please input the geographic latitude of the observer"
print "(degrees [-90 to +90], minutes [0 - 60], seconds [0 - 60])"
print "(north latitudes are positive, south latitudes are negative)"
input obslat.deg$, obslat.min, obslat.sec
loop until (abs(val(obslat.deg$)) <= 90.0 and (obslat.min >= 0.0 and obslat.min <= 60.0) and (obslat.sec >= 0.0 and obslat.sec <= 60.0))
if (left$(obslat.deg$, 2) = "-0") then
obslat = -dtr * (obslat.min / 60.0 + obslat.sec / 3600.0)
elseif (val(obslat.deg$) = 0.0) then
obslat = dtr * (obslat.min / 60.0 + obslat.sec / 3600.0)
else
obslat = dtr * (sgn(val(obslat.deg$)) * (abs(val(obslat.deg$)) + obslat.min / 60.0 + obslat.sec / 3600.0))
endif
do
print
print "please input the geographic longitude of the observer"
print "(degrees [0 - 360], minutes [0 - 60], seconds [0 - 60])"
print "(east longitude is positive, west longitude is negative)"
input obslong.deg$, obslong.min, obslong.sec
loop until (abs(val(obslong.deg$)) >= 0.0 and abs(val(obslong.deg$)) <= 360.0) and (obslong.min >= 0.0 and obslong.min <= 60.0) and (obslong.sec >= 0.0 and obslong.sec <= 60.0)
if (left$(obslong.deg$, 2) = "-0") then
obslong = -dtr * (obslong.min / 60 + obslong.sec / 3600)
elseif (val(obslong.deg$) = 0.0) then
obslong = dtr * (obslong.min / 60.0 + obslong.sec / 3600.0)
else
obslong = dtr * (sgn(val(obslong.deg$)) * (abs(val(obslong.deg$)) + obslong.min / 60.0 + obslong.sec / 3600.0))
endif
print " "
print "please input the altitude of the observer (meters)"
print "(positive above sea level, negative below sea level)"
input obsalt
end sub
sub julian(month, day, year, jday)
' Gregorian date to julian day subroutine
' input
' month = calendar month
' day = calendar day
' year = calendar year (all four digits)
' output
' jday = julian day
' special notes
' (1) calendar year must include all digits
' (2) will report October 5, 1582 to October 14, 1582
' as invalid calendar dates and exit
local a, b, c, m, y
y = year
m = month
b = 0.0
c = 0.0
if (m <= 2.0) then
y = y - 1.0
m = m + 12.0
end if
if (y < 0.0) then c = -0.75
if (year < 1582.0) then
' null
elseif (year > 1582.0) then
a = fix(y / 100.0)
b = 2.0 - a + fix(a / 4.0)
elseif (month < 10.0) then
' null
elseif (month > 10.0) then
a = fix(y / 100.0)
elseif (day <= 4.0) then
' null
elseif (day > 14.0) then
a = fix(y / 100.0)
else
print "this date does not exist!!"
exit
end if
jday = fix(365.25 * y + c) + fix(30.6001 * (m + 1.0)) + day + b + 1720994.5
end sub
sub gdate (jday, month, day, year)
' Julian day to Gregorian date subroutine
' input
' jday = julian day
' output
local a, b, c, d, e, f, z, alpha
z = fix(jday + 0.5)
f = jday + 0.5 - z
if (z < 2299161) then
a = z
else
alpha = fix((z - 1867216.25) / 36524.25)
a = z + 1.0 + alpha - fix(alpha / 4.0)
end if
b = a + 1524.0
c = fix((b - 122.1) / 365.25)
d = fix(365.25 * c)
e = fix((b - d) / 30.6001)
day = b - d - fix(30.6001 * e) + f
if (e < 13.5) then
month = e - 1.0
else
month = e - 13.0
end if
if (month > 2.5) then
year = c - 4716.0
else
year = c - 4715.0
end if
end sub
sub utc2tdb (jdutc, jdtdb)
' convert UTC julian date to TDB julian date
' input
' output
' Reference Frames in Astronomy and Geophysics
' J. Kovalevsky et al., 1989, pp. 439-442
local corr, jdtt, t, leapsecond
' find current number of leap seconds
findleap(jdutc, leapsecond)
' compute TDT julian date
corr = (leapsecond + 32.184) / 86400.0
jdtt = jdutc + corr
' time argument for correction
t = (jdtt - 2451545.0) / 36525.0
' compute correction in microseconds
corr = 1656.675 * sin(dtr * (35999.3729 * t + 357.5287))
corr = corr + 22.418 * sin(dtr * (32964.467 * t + 246.199))
corr = corr + 13.84 * sin(dtr * (71998.746 * t + 355.057))
corr = corr + 4.77 * sin(dtr * ( 3034.906 * t + 25.463))
corr = corr + 4.677 * sin(dtr * (34777.259 * t + 230.394))
corr = corr + 10.216 * t * sin(dtr * (35999.373 * t + 243.451))
corr = corr + 0.171 * t * sin(dtr * (71998.746 * t + 240.98 ))
corr = corr + 0.027 * t * sin(dtr * ( 1222.114 * t + 194.661))
corr = corr + 0.027 * t * sin(dtr * ( 3034.906 * t + 336.061))
corr = corr + 0.026 * t * sin(dtr * ( -20.186 * t + 9.382))
corr = corr + 0.007 * t * sin(dtr * (29929.562 * t + 264.911))
corr = corr + 0.006 * t * sin(dtr * ( 150.678 * t + 59.775))
corr = corr + 0.005 * t * sin(dtr * ( 9037.513 * t + 256.025))
corr = corr + 0.043 * t * sin(dtr * (35999.373 * t + 151.121))
' convert corrections to days
corr = 0.000001 * corr / 86400.0
' TDB julian date
jdtdb = jdtt + corr
end sub
sub findleap(jday, leapsecond)
' find number of leap seconds for utc julian day
' input
' jday = utc julian day
' input via global
' jdleap = array of utc julian dates
' leapsec = array of leap seconds
' output
' leapsecond = number of leap seconds
if (jday <= jdleap(1)) then
' date is <= 1972; set to first data element
leapsecond = leapsec(1)
exit sub
end if
if (jday >= jdleap(28)) then
' date is >= end of current data
' set to last data element
leapsecond = leapsec(28)
exit sub
end if
' find data within table
for i% = 1 to 27
if (jday >= jdleap(i%) and jday < jdleap(i% + 1)) then
leapsecond = leapsec(i%)
exit sub
end if
next i%
end sub
function modulo(x) as float
' modulo 2 pi function
local a
a = x - pi2 * fix(x / pi2)
if (a < 0.0) then
a = a + pi2
end if
modulo = a
end function
function atan3(a, b) as float
' four quadrant inverse tangent function
' input
' a = sine of angle
' b = cosine of angle
' output
' atan3 = angle (0 =< atan3 <= 2 * pi; radians)
local c
if (abs(a) < 1.0e-10) then
atan3 = (1.0 - sgn(b)) * pidiv2
exit function
else
c = (2.0 - sgn(a)) * pidiv2
endif
if (abs(b) < 1.0e-10) then
atan3 = c
exit function
else
atan3 = c + sgn(a) * sgn(b) * (abs(atn(a / b)) - pidiv2)
endif
end function
function vecmag(a())
' vector magnitude function
' input
' { a } = column vector ( 3 rows by 1 column )
' output
' vecmag = scalar magnitude of vector { a }
vecmag = sqr(a(1) * a(1) + a(2) * a(2) + a(3) * a(3))
end function
sub uvector (a(), b())
' unit vector subroutine
' input
' a = column vector (3 rows by 1 column)
' output
' b = unit vector (3 rows by 1 column)
local i as integer, amag
amag = vecmag(a())
for i = 1 to 3
if (amag <> 0.0) then
b(i) = a(i) / amag
else
b(i) = 0.0
end if
next i
end sub
function vdot(a(), b())
' vector dot product function
' c = { a } dot { b }
' input
' n% = number of rows
' { a } = column vector with n rows
' { b } = column vector with n rows
' output
' vdot = dot product of { a } and { b }
local c = 0.0
for i% = 1 to 3
c = c + a(i%) * b(i%)
next i%
vdot = c
end function
sub vcross(a(), b(), c())
' vector cross product subroutine
' { c } = { a } x { b }
' input
' { a } = vector a ( 3 rows by 1 column )
' { b } = vector b ( 3 rows by 1 column )
' output
' { c } = { a } x { b } ( 3 rows by 1 column )
c(1) = a(2) * b(3) - a(3) * b(2)
c(2) = a(3) * b(1) - a(1) * b(3)
c(3) = a(1) * b(2) - a(2) * b(2)
end sub
sub matxvec(a(), b(), c())
' matrix/vector multiplication subroutine
' { c } = [ a ] * { b }
' input
' a = matrix a ( 3 rows by 3 columns )
' b = vector b ( 3 rows )
' output
' c = vector c ( 3 rows )
local s, i%, j%
for i% = 1 to 3
s = 0.0
for j% = 1 to 3
s = s + a(i%, j%) * b(j%)
next j%
c(i%) = s
next i%
end sub
sub transpose (a(), b())
' matrix traspose subroutine
' input
' m = number of rows in matrix [ a ]
' n = number of columns in matrix [ a ]
' output
' b = matrix transpose ( 3 rows by 3 columns )
local i%, j%
for i% = 1 to 3
for j% = 1 to 3
b(i%, j%) = a(j%, i%)
next j%
next i%
end sub
sub jd2str(jdutc)
' convert julian day to calendar date and UTC time
gdate (jdutc, cmonth, day, year)
print "calendar date ", month$(cmonth), " ", STR$(int(day)), " ", str$(year)
print " "
thr0 = 24.0 * (day - int(day))
thr = int(thr0)
tmin0 = 60.0 * (thr0 - thr)
tmin = int(tmin0)
tsec = 60.0 * (tmin0 - tmin)
' fix seconds and minutes for rollover
if (tsec >= 60.0) then
tsec = 0.0
tmin = tmin + 1.0
end if
' fix minutes for rollover
if (tmin >= 60.0) then
tmin = 0.0
thr = thr + 1.0
end if
print "UTC time ", str$(thr) + " hours " + str$(tmin) + " minutes " + str$(tsec, 0, 2) + " seconds"
end sub
sub deg2str(dd, dms$)
' convert decimal degrees to degrees,
' minutes, seconds string
' input
' dd = angle in decimal degrees
' output
' dms$ = string equivalent
local d1, d, m, s
d1 = abs(dd)
d = fix(d1)
d1 = (d1 - d) * 60.0
m = fix(d1)
s = (d1 - m) * 60.0
if (dd < 0.0) then
if (d <> 0.0) then
d = -d
elseif (m <> 0.0) then
m = -m
else
s = -s
end if
end if
dms$ = str$(d) + " deg " + str$(m) + " min " + str$(s, 0, 2) + " sec"
end sub
sub hrs2str(hours)
' convert hours to equivalent string
local thr, tmin0, tmin, tsec
thr = fix(hours)
tmin0 = 60.0 * (hours - thr)
tmin = fix(tmin0)
tsec = 0.0
tmin = tmin + 1.0
end if
tmin = 0.0
thr = thr + 1
end if
print "event duration ", str$(thr) + " hours " + str$(tmin) + " minutes " + str$(tsec, 0, 2) + " seconds"
end sub
2017-03-17_181702_riseset.pdf
Frank N. Furter
Posted: 09:35am 17 Mar 2017
Thank you very much! It's very useful for me!
Frank
