Local Time 11:56 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - model rocket performance
cdeagle
Posted: 07:44am 19 Mar 2017
This post is a short computer program for the MicroMite eXtreme that estimates the flight performance of a single stage model rocket.
Here's a typical user interaction with the software and the calculated results from the program.
program rocket1
please input the launch site altitude (meters)
(sites above sea level are positive, sites below sea level are negative)
? 0
please input the launch site temperature (degrees fahrenheit)
? 59
please input the thrust duration (seconds)
? 1.2
please input the total impulse (newton-seconds)
? 5
please input the initial mass (grams)
? 40
please input the propellant mass (grams)
? 8.33
please input the frontal diameter (millimeters)
? 18
please input the drag coefficient
? .321
program rocket1
burnout altitude 74.0670 meters
burnout velocity 119.3594 meters per second
burnout mass 31.6700 grams
coast time 7.9316 seconds
total flight time 9.1316 seconds
maximum altitude 451.3929 meters
average thrust 4.1667 newtons
Here's the MMBASIC source code.
' program rocket1.bas March 19, 2017
' MicroMite eXtreme version
' determines flight performance
' of single stage model rockets
' altitude at burnout, meters
' velocity at burnout, meters per second
' coast time and total flight time, seconds
' maximum altitude, meters
option default float
dim altsite, tempsite, tduration, impulse, massi, mprop, fd, cd
' surface gravity (meters/second^2)
const gravity = 9.80665
' sea level atmospheric density (kilograms/cubic meter)
const rhosl = 1.22557
print " "
print "program rocket1"
print "---------------"
do
print " "
print "please input the launch site altitude (meters)"
print "(sites above sea level are positive, sites below sea level are negative)"
input altsite
loop until (abs(altsite) >= 0.0)
print " "
print "please input the launch site temperature (degrees fahrenheit)"
input tempsite
do
print " "
print "please input the thrust duration (seconds)"
input tduration
loop until (tduration > 0.0)
do
print " "
print "please input the total impulse (newton-seconds)"
input impulse
loop until (impulse > 0.0)
do
print " "
print "please input the initial mass (grams)"
input massi
loop until (massi > 0.0)
do
print " "
print "please input the propellant mass (grams)"
input mprop
loop until (mprop > 0.0)
do
print " "
print "please input the frontal diameter (millimeters)"
input fd
loop until (fd > 0.0)
do
print " "
print "please input the drag coefficient"
input cd
loop until (cd > 0.0)
' convert mass to kilograms and diameter to square meters
massi = 0.001 * massi
mprop = 0.001 * mprop
fd = pi * fd * fd / 4000000.0
' compensate for launch site altitude and temperature
rho = rhosl * density(altsite) / (1.0 + (tempsite - 59.0) / 518.67)
' determine altitude performance
thrust = impulse / tduration
mass = (massi - 0.5 * mprop)
k2 = 0.5 * rho * fd * cd
weight = mass * gravity
b = tduration * sqr(k2 * (thrust - weight)) / mass
c = exp(b)
d = exp(-b)
e = 0.5 * (c + d)
f = (c - d) / (c + d)
' calculate burnout conditions
altbo = (mass / k2) * log(e)
velbo = f * sqr((thrust - weight) / k2)
massbo = massi - mprop
weightbo = massbo * gravity
' compute coast conditions
tcoast = sqr(massbo / (k2 * gravity)) * atn(velbo * sqr(k2 / weightbo))
altcoast = (massbo / (2.0 * k2)) * log(k2 * velbo * velbo / weightbo + 1.0)
' calculate total flight time and maximum altitude
tflight = tduration + tcoast
altmax = altbo + altcoast
' print results
print " "
print
print "burnout altitude ", str$(altbo, 0, 4), " meters"
print " "
print "burnout velocity ", STR$(velbo, 0, 4), " meters per second"
print " "
print "burnout mass ", STR$(1000.0 * massbo, 0, 4), " grams"
print " "
print "coast time ", str$(tcoast, 0, 4), " seconds"
print " "
print "total flight time ", str$(tflight, 0, 4), " seconds"
print " "
print "maximum altitude ", str$(altmax, 0, 4), " meters"
print " "
print "average thrust ", str$(thrust, 0, 4), " newtons"
print " "
end
function density(x) as float
' atmospheric density function
' input
' x = altitude (meters)
' output
' density = atmospheric density (kilograms/cubic meter)
density = (1.0 - 0.000022556913 * x) ^ 4.256116
end function
Here's a scanned PDF document for the first QuickBASIC version written in 1982. Those who remember will probably snicker at the dot matrix printout.
2017-03-19_174232_rocket1.pdf
cdeagle
Posted: 06:33am 02 Apr 2017
ROCKET2 is an MMBASIC program which determines the flight performance of a single
stage model rocket by numerically integrating the equations of motion. The
user can specify a launch angle and the program solves the problem of
non-vertical motion. The user can also display and print the results at each
integration step. The information displayed includes the flight time, vertical
altitude, horizontal range, velocity, mass, thrust and aerodynamic drag. This
program models the variation of density with altitude and the changes in
thrust and mass with time. Aerodynamic drag is updated as a function of
altitude and velocity.
Here's a typical user interaction with the software.
program rocket2
? 0
please input the launch site temperature (degrees f)
? 59
please input the maximum thrust (newtons)
? 13
please input the sustainer thrust (newtons)
? 3.5
please input the time of maximum thrust (seconds)
? .14
please input the time of sustainer thrust (seconds)
? .22
? 1.2
? 40
? 8.33
? 18
please input the drag coefficient (non-dimensional)
? .321
please input the launch angle
(degrees [ 0 to 90 ] - measured from the ground)
(for example, a vertical launch is an angle of 90 degrees)
? 90
please input the boost step size (seconds)
(a value of 0.01 seconds is recommended)
? .01
please input the coast step size (seconds)
(a value of 0.1 seconds is recommended)
? .1
integrating equations of motion ...
program rocket2
burnout altitude 80.8596 meters
burnout velocity 118.7054 meters per second
coast time 8.0000 seconds
total flight time 9.2000 seconds
maximum altitude 459.0167 meters
Here's the source code listing.
' program rocket2.bas April 2, 2017
' determines flight performance of model rockets
' altitude at burnout (meters)
' velocity at burnout (meters per second)
' coast time and total flight time (seconds)
' maximum altitude (meters)
' numerical integration method
option base 1
const dtr = pi / 180.0
const rtd = 180.0 / pi
' integrator coefficients
const a0 = 0.045
const b0 = 0.3
const c0 = 13.0 / 126.0
const d0 = 5.0 / 18.0
const e0 = 5.0 / 42.0
const f0 = 7.0 / 600.0
const g0 = 7.0 / 30.0
const h0 = 7.0 / 15.0
const i0 = 7.0 / 6.0
const j0 = 25.0 / 63.0
const k0 = 0.7
const l0 = 19.0 / 78.0
const m0 = 35.0 / 312.0
const n0 = 15.0 / 104.0
const o0 = 64.0 / 39.0
const p0 = 70.0 / 39.0
const q0 = 15.0 / 13.0
' global arrays and variables
dim d1(2), d2(2), d3(2), d4(2)
dim acc(2), xp(2), xs(2), vp(2), vs(2)
dim langle, fltflg%, f5, maxthr, susthr, vex, vex2
dim massi, mprop, tt, tp, dt, tsus, tmax, tdur, t6, t7
dim thrust, mass, drag, ffactor
' begin simulation
print " "
print "program rocket2"
do
print " "
input altsite
loop until (altsite >= 0.0)
do
print " "
print "please input the launch site temperature (degrees f)"
input tempsite
loop until (tempsite >= 0.0)
do
print " "
print "please input the maximum thrust (newtons)"
input maxthr
loop until (maxthr > 0.0)
do
print " "
print "please input the sustainer thrust (newtons)"
input susthr
loop until (susthr > 0.0)
do
print " "
print "please input the time of maximum thrust (seconds)"
input tmax
loop until (tmax > 0.0)
do
print " "
print "please input the time of sustainer thrust (seconds)"
input tsus
loop until (tsus > 0.0)
do
print " "
input tdur
loop until (tdur > 0.0)
do
print " "
input massi
do
print " "
input mprop
do
print " "
input fdia
loop until (fdia > 0.0)
fdia = pi * fdia * fdia / 4000000.0
do
print " "
print "please input the drag coefficient (non-dimensional)"
input cd
do
print " "
print "please input the launch angle"
print "(degrees [ 0 to 90 ] - measured from the ground)"
print "(for example, a vertical launch is an angle of 90 degrees)"
input langle
loop until (langle >= 0.0 and langle <= 90.0)
langle = langle * dtr
do
print " "
print "please input the boost step size (seconds)"
print "(a value of 0.01 seconds is recommended)"
input dtboost
loop until (dtboost > 0.0)
do
print " "
print "please input the coast step size (seconds)"
print "(a value of 0.1 seconds is recommended)"
input dtcoast
loop until (dtcoast > 0.0)
print " "
print "integrating equations of motion ..."
print " "
rhosite = rhosl * fna(altsite) / (1.0 + (tempsite - 59.0) / 518.67)
f5 = maxthr - susthr
ffactor = 0.5 * rhosite * fdia * cd
t6 = tsus - tmax
' calculate exhaust velocity
vex = (maxthr * 0.5 * tsus + susthr * (tdur - 0.5 * tmax - 0.5 * tsus)) / mprop
vex2 = 2.0 * vex
tp = 0.0
xp(1) = 0.0
xp(2) = 0.0
vp(1) = 0.0
vp(2) = 0.0
fltflg% = 0
' powered flight
np% = tdur / dtboost
dt = dtboost
for ii% = 1 to np%
integrate
tt = tp
plmass
plthrust
' un-comment the following line to display the
' flight conditions during the thrusting flight
' pdata
next ii%
' burnout conditions
xbo = xp(2)
vbo = sqr(vp(1) ^ 2 + vp(2) ^ 2)
' coasting flight
dt = dtcoast
fltflg% = 1
do
if (vp(2) > 0.0) then
integrate
tt = tp
plmass
plthrust
' flight conditions during the coasting flight
' pdata
else
exit do
end if
loop
tcoast = tp - tdur
' print final conditions
print " "
print " "
print "burnout altitude ", str$(xbo, 0, 4), " meters"
print " "
print "burnout velocity ", str$(vbo, 0, 4), " meters per second"
print " "
print " "
print " "
print "total flight time ", str$(tp, 0, 4), " seconds"
print " "
print " "
print "maximum altitude ", str$(xp(2), 0, 4), " meters"
print " "
end
function fna(x) as float
fna = (1.0 - 0.000022556913 * x) ^ 4.256116
end function
sub diffeq
' two-dimensional equations of motion subroutine
vmag = sqr(vs(1) ^ 2 + vs(2) ^ 2)
if (xp(2) < 1.0) then
uvx = cos(langle)
uvy = sin(langle)
else
uvx = vs(1) / vmag
uvy = vs(2) / vmag
end if
drag = vmag ^ 2 * ffactor * fna(xs(2))
mass = massi - mprop
thrust = 0.0
if (fltflg% = 0) then
t7 = tt - tmax
plmass
plthrust
end if
tacc = (thrust - drag) / mass
acc(1) = tacc * uvx
acc(2) = tacc * uvy - gravity
end sub
sub integrate
' numerical integration subroutine
tt = tp
for i% = 1 to 2
xs(i%) = xp(i%)
vs(i%) = vp(i%)
next i%
diffeq
tt = tp + b0 * dt
for i% = 1 to 2
d1(i%) = dt * acc(i%)
xs(i%) = xp(i%) + dt * (b0 * vp(i%) + a0 * d1(i%))
vs(i%) = vp(i%) + b0 * d1(i%)
next i%
diffeq
tt = tp + k0 * dt
for i% = 1 to 2
d2(i%) = dt * acc(i%)
xs(i%) = xp(i%) + dt * (k0 * vp(i%) + f0 * d1(i%) + g0 * d2(i%))
vs(i%) = vp(i%) - h0 * d1(i%) + i0 * d2(i%)
next i%
diffeq
tt = tp + dt
for i% = 1 to 2
d3(i%) = dt * acc(i%)
xs(i%) = xp(i%) + dt * (vp(i%) + l0 * d1(i%) + m0 * d2(i%) + n0 * d3(i%))
vs(i%) = vp(i%) + o0 * d1(i%) - p0 * d2(i%) + q0 * d3(i%)
next i%
diffeq
tp = tp + dt
for i% = 1 to 2
d4(i%) = dt * acc(i%)
xp(i%) = xp(i%) + dt * (vp(i%) + c0 * d1(i%) + d0 * d2(i%) + e0 * d3(i%))
vp(i%) = vp(i%) + c0 * (d1(i%) + d4(i%)) + j0 * (d2(i%) + d3(i%))
next i%
end sub
sub pdata
' print flight conditions subroutine
vmag = sqr(vp(1) ^ 2 + vp(2) ^ 2)
rmag = sqr(xp(1) ^ 2 + xp(2) ^ 2)
fpa = rtd * atn(vp(2) / vp(1))
accm = sgn(acc(2)) * sqr(acc(1) ^ 2 + acc(2) ^ 2)
print " "
print "flight time (seconds)"; tp
print " "
print " "
print "altitude (meters)"; xp(2)
print " "
print "horizontal range (meters)"; xp(1)
print " "
print "velocity (meters per second)"; vmag
print " "
print "flight path angle (degrees)"; fpa
print " "
print "acceleration (meters/second/second)"; accm
print " "
print " "
print "mass (grams)"; 1000.0 * mass
print " "
print "thrust (newtons)"; thrust
print " "
print "drag (newtons)"; drag
print " "
end sub
sub plmass
' piecewise-linear mass subroutine
if (tp <= tmax) then
mass = massi - maxthr * tt ^ 2 / (vex2 * tmax)
exit sub
elseif (tp > tmax and tp <= tsus) then
mass = massi - (maxthr / vex) * (tt - 0.5 * tmax) + f5 * t7 ^ 2 / (vex2 * t6)
exit sub
elseif (tp > tsus and tp < tdur) then
mass = massi - (maxthr * tsus + susthr * t6) / vex2 - (susthr / vex) * (tt - tsus)
exit sub
elseif (tp >= tdur) then
exit sub
end if
end sub
sub plthrust
' piecewise-linear thrust subroutine
thrust = maxthr * tt / tmax
exit sub
thrust = maxthr - f5 * (tt - tmax) / t6
exit sub
thrust = susthr
exit sub
thrust = 0.0
exit sub
end if
end sub
cdeagle
Posted: 12:32am 03 Apr 2017
This MMBASIC computer program, rocket3.bas, determines the "best" initial mass of a single stage model rocket that maximizes the final altitude. It assumes a vertical launch and and compensates for non-standard launch conditions.
The following PDF document provides additional information about this technique.
2017-04-03_102438_rocket.pdf
Here's a typical user interaction with the software and the results calculated by the rocket3 program.
program rocket3
? 100
? 70
? 1.2
? 5
? 8.33
? 18
? .321
program rocket3
initial mass 24.8724 grams
burnout altitude 125.1150 meters
burnout velocity 190.3544 meters per second
burnout mass 16.5424 grams
coast time 7.5214 seconds
total flight time 8.7214 seconds
maximum altitude 546.2455 meters
' program rocket3.bas April 3, 2017
' for a given model rocket engine and aerodynamic characteristics,
' this program determines the optimal launch mass of a single-stage
' model rocket which maximizes total altitude (Bengen's maxima)
option base 1
' global constants
' global variables
dim rho, tduration, impulse, mprop, fd, cd
dim altbo, velbo, massbo, weightbo
dim tcoast, altcoast, tflight
' begin simulation
print " "
print "program rocket3"
do
print " "
print "launch site altitude (meters)"
input altsite
do
print " "
print "launch site temperature (degrees fahrenheit)"
input tempsite
do
print
print "thrust duration (seconds)"
input tduration
do
print
print "total impulse (newton-seconds)"
input impulse
do
print
print "propellant mass (grams)"
input mprop
do
print
print "frontal diameter (millimeters)"
input fd
do
print
print "drag coefficient (non-dimensional)"
input cd
fd = pi * fd ^ 2 / 4000000.0
rho = rhosl * fna(altsite) / (1.0 + (tempsite - 59.0) / 518.67)
' determine "best" initial launch mass
m1 = 1.001 * mprop
m2 = 10.0 * mprop
tolm = 1.0e-8
minima(m1, m2, tolm, massi, altmax)
' print results
print " "
print " "
print "initial mass ", str$(1000.0 * massi, 0, 4), " grams"
print " "
print " "
print "burnout velocity ", str$(velbo, 0, 4), " meters per second"
print " "
print "burnout mass ", str$(1000.0 * (massi - mprop), 0, 4), " grams"
print " "
print " "
print " "
print " "
print " "
print "maximum altitude ", str$(-altmax, 0, 4), " meters"
print " "
end
end function
sub alt_func(massi, altmax)
' calculate maximum altitude subroutine
mass = massi - 0.5 * mprop
c = exp(b)
d = exp(-b)
e = 0.5 * (c + d)
' coast conditions
' total flight time and maximum altitude
altmax = -(altbo + altcoast)
end sub
sub minima(a, b, tolm, xmin, fmin)
' one-dimensional minimization
' Brent's method
' input
' a = initial x search value
' b = final x search value
' tolm = convergence criterion
' output
' xmin = minimum x value
' note
' user-defined objective subroutine
' coded as alt_func(x, fx)
' remember: a maximum is simply a minimum
' with a negative attitude!
' machine epsilon
LOCAL epsm = 2.23e-16
' golden number
LOCAL c = 0.38196601125
LOCAL d, e, t2, p, q
local r, u, fu
LOCAL x, xm, w
local v, fx, fw
LOCAL tol1, fv
x = a + c * (b - a)
w = x
v = w
e = 0.0
p = 0.0
q = 0.0
r = 0.0
alt_func(x, fx)
fw = fx
fv = fw
for iter% = 1 to 100
if (iter% > 50) then
print ("error in subroutine minima!")
print ("(more than 50 iterations)")
end if
xm = 0.5 * (a + b)
tol1 = tolm * abs(x) + epsm
t2 = 2.0 * tol1
if (abs(x - xm) <= (t2 - 0.5 * (b - a))) then
xmin = x
fmin = fx
exit sub
end if
if (abs(e) > tol1) then
r = (x - w) * (fx - fv)
q = (x - v) * (fx - fw)
p = (x - v) * q - (x - w) * r
q = 2.0 * (q - r)
if (q > 0.0) then
p = -p
end if
q = abs(q)
r = e
e = d
end if
if ((abs(p) >= abs(0.5 * q * r)) or (p <= q * (a - x)) or (p >= q * (b - x))) then
if (x >= xm) then
e = a - x
else
e = b - x
end if
d = c * e
else
d = p / q
u = x + d
if ((u - a) < t2) or ((b - u) < t2) then
d = sgn(xm - x) * tol1
end if
end if
if (abs(d) >= tol1) then
u = x + d
else
u = x + sgn(d) * tol1
end if
alt_func(u, fu)
if (fu <= fx) then
if (u >= x) then
a = x
else
b = x
end if
v = w
fv = fw
w = x
fw = fx
x = u
fx = fu
else
if (u < x) then
a = u
else
b = u
end if
if ((fu <= fw) or (w = x)) then
v = w
fv = fw
w = u
fw = fu
elseif ((fu <= fv) Or (v = x) Or (v = w)) then
v = u
fv = fu
end if
end if
next iter%
end sub
Posted: 01:43pm 03 Apr 2017
Thanks cdeagle, nice work.
Speaking of rockets and software, it would be fascinating to talk to the software engineers who work on the SpaceX Falcon 9 first stage. That thing is a engineering masterpiece.
