Local Time 11:57 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - three dimensional interpolation
cdeagle
Posted: 03:20am 30 Mar 2017
This post describes an MMBASIC program for the Micromite eXtreme that can be used to first "fit" and then interpolate three-dimensional data provided by the user. The degree of the surface fit, up to order 10, can also be specified by the user.
Here's a typical user interaction with the software. It uses an analytic three-dimensional surface to demonstrate how to use the software. The difference between the analytic equation and the interpolated value is printed at the end of the scientific simulation.
program demo_sfit
this program demonstrates the procedure for calling
the subroutine surfit.bas which calculates fitting
coefficients for 3-dimensional surfaces of the form
z = f(x,y) from x, y and z data points input by the
user.
this program demonstrates the use of surfit to find
fitting coefficients for the surface defined by
z = -cos(3*pi*x/10)*cos(pi*y/10)
for -5 <= x <= +5 and -5 <= y <= +5
please input the degree of the surface fit (degree <= 10)
? 10
please wait, computing coefficients
coef( 0, 0) =-0.999206
coef( 1, 0) = 5.38498e-16
coef( 0, 1) =-5.79029e-16
coef( 2, 0) = 0.442671
coef( 1, 1) = 5.07139e-16
coef( 0, 2) = 0.0490698
coef( 3, 0) = 5.18700e-16
coef( 2, 1) = 7.06358e-17
coef( 1, 2) =-5.34561e-16
coef( 0, 3) = 1.45522e-16
coef( 4, 0) =-0.0323963
coef( 3, 1) =-3.35196e-17
coef( 2, 2) =-0.0215217
coef( 1, 3) =-1.86050e-16
coef( 0, 4) =-0.000388245
coef( 5, 0) =-1.31389e-16
coef( 4, 1) =-3.18267e-18
coef( 3, 2) = 3.92482e-17
coef( 2, 3) =-1.27874e-17
coef( 1, 4) = 6.00305e-17
coef( 0, 5) =-9.04811e-18
coef( 6, 0) = 0.000913117
coef( 5, 1) = 6.27277e-19
coef( 4, 2) = 0.00152308
coef( 3, 3) = 7.99553e-18
coef( 2, 4) = 0.000161127
coef( 1, 5) = 2.06673e-17
coef( 0, 6) = 9.80403e-07
coef( 7, 0) = 9.10733e-18
coef( 6, 1) = 7.74537e-20
coef( 5, 2) =-1.25844e-18
coef( 4, 3) = 2.39623e-19
coef( 3, 4) =-1.91547e-18
coef( 2, 5) = 7.44808e-19
coef( 1, 6) =-2.70286e-18
coef( 0, 7) = 8.51186e-20
coef( 8, 0) =-1.19697e-05
coef( 7, 1) =-1.01718e-21
coef( 6, 2) =-3.85934e-05
coef( 5, 3) =-1.01276e-19
coef( 4, 4) =-9.76504e-06
coef( 3, 5) =-4.96569e-19
coef( 2, 6) =-3.28361e-07
coef( 1, 7) =-9.21900e-19
coef( 0, 8) =-2.18460e-10
coef( 9, 0) =-1.88583e-19
coef( 8, 1) =-6.91317e-22
coef( 7, 2) = 1.67106e-20
coef( 6, 3) =-2.32910e-21
coef( 5, 4) = 1.77301e-20
coef( 4, 5) =-4.51179e-21
coef( 3, 6) = 3.39661e-20
coef( 2, 7) =-1.39360e-20
coef( 1, 8) = 4.20262e-20
coef( 0, 9) = 3.24655e-21
coef( 10, 0) = 6.02420e-08
coef( 9, 1) = 1.26586e-23
coef( 8, 2) = 3.58607e-07
coef( 7, 3) = 2.94099e-23
coef( 6, 4) = 1.57525e-07
coef( 5, 5) = 3.16482e-21
coef( 4, 6) = 1.16010e-08
coef( 3, 7) = 9.07642e-21
coef( 2, 8) = 6.38069e-11
coef( 1, 9) = 1.44452e-20
coef( 0, 10) =-4.43318e-13
would you like to interpolate an x, y data point
(y = yes, n = no)
? y
please input the x data point (-5 <= x <= +5)
? -3.45675
please input the y data point (-5 <= y <= +5)
? 3.45675
x data point = -3.45675
y data point = 3.45675
z data point = 0.462422
z_analytic - z_fit = 0.000483485
Here's the MMBASIC source code for this numerical method.
' program demo_sfit.bas March 30, 2017
' this program demonstrates the procedure for calling
' the subroutine surfit.bas which calculates fitting
' coefficients for 3-dimensional surfaces of the form
' z = f(x,y) from x, y and z data points input by the
' user. It also illustrates how to interpolate an x-y
' data pair provided by the user.
' this program demonstrates the use of surfit to find
' fitting coefficients for the surface defined by
' z = -cos(3*pi*x/10)*cos(pi*y/10)
' for -5 <= x <= +5 and -5 <= y <= +5
option default float
option base 1
' dimension data and coefficient arrays
dim xdata(121), ydata(121), zdata(121), coef(11, 11)
print " "
print "program demo_sfit"
print "-----------------"
print " "
print "this program demonstrates the procedure for calling"
print "the subroutine surfit.bas which calculates fitting"
print "coefficients for 3-dimensional surfaces of the form"
print "z = f(x,y) from x, y and z data points input by the"
print "user."
print " "
print "this program demonstrates the use of surfit to find"
print "fitting coefficients for the surface defined by"
print " "
print " z = -cos(3*pi*x/10)*cos(pi*y/10)"
print " "
print " for -5 <= x <= +5 and -5 <= y <= +5"
' generate data points for the surface defined by
ndata% = 0
for i% = -5 to 5 step 1
for j% = -5 to 5 step 1
ndata% = ndata% + 1
x = i%
xdata(ndata%) = i%
y = j%
ydata(ndata%) = j%
z = -cos(3.0 * pi * x / 10.0) * cos(pi * y / 10.0)
zdata(ndata%) = z
next j%
next i%
do
print " "
print "please input the degree of the surface fit (degree <= 10)"
input ndeg%
loop until (ndeg% >= 0 and ndeg% <= 10)
print " "
print "please wait, computing coefficients";
print " "
surfit(ndeg%, ndata%, xdata(), ydata(), zdata(), coef())
' print fitting coefficients
for i% = 1 to ndeg% + 1
print " "
print "fitting coefficients"
print " "
i1% = i% + 1
for j% = 1 to i%
print "coef("; i1% - j% - 1; ","; j% - 1; ") =";
print coef(j%, i1% - j%)
next j%
next i%
do
print " "
print "would you like to interpolate an x, y data point"
print "(y = yes, n = no)"
input fit$
loop until (fit$ = "y" or fit$ = "n")
if (fit$ = "y") then
do
print
print "please input the x data point (-5 <= x <= +5)"
input x
loop until (abs(x) <= 5.0)
do
print
print "please input the y data point (-5 <= y <= +5)"
input y
loop until (abs(y) <= 5.0)
' perform interpolation
sfunction(ndeg%, coef(), x, y, z)
' print results of interpolation
print " "
print "x data point = ", x
print " "
print "y data point = ", y
print " "
print "z data point = ", z
print " "
' analytic z-value
za = -cos(3.0 * pi * x / 10.0) * cos(pi * y / 10.0)
print "za = ", za
print "z_analytic - z_fit = ", za - z
print " "
end if
end
sub surfit (ndeg%, ndata%, xdata(), ydata(), zdata(), coef())
' surface fit subroutine
' input
' ndeg% = degree of surface fit (ndeg% <= 10)
' ndata% = number of x, y and z data points
' xdata() = vector of x data values (ndata% rows)
' ydata() = vector of y data values (ndata% rows)
' zdata() = vector of z data values (ndata% rows)
' output
' coef() = array of surface fit coefficients (11 rows by 11 columns)
local ndeg1% = ndeg% + 1
local ndeg2% = ndeg% + 2
local nrow% = ndeg1% * ndeg2% / 2
local ncol% = nrow% + 1
local nalf% = 2 * ndeg%
local nalf1% = nalf% + 1
local nalf2% = nalf% + 2
local xa(ndeg1% * ndeg2% / 2)
local zadd(ndeg1%, ndeg1%)
local hsmg(2 * ndeg1%, 2 * ndeg1%)
local xmatrix(ndeg1% * ndeg2% / 2, ndeg1% * ndeg2% / 2 + 1)
for i% = 1 to nalf1%
for j% = 1 to nalf2% - i%
hsmg(i%, j%) = 0.0
next j%
next i%
for i% = 1 to ndeg1%
for j% = 1 to ndeg2% - i%
zadd(i%, j%) = 0.0
next j%
next i%
z1 = 0.0
for i% = 1 to ndata%
z1 = z1 + zdata(i%)
next i%
if (ndeg% <> 0) then
a = 1.0
xa(1) = 1.0
x = xdata(i%)
y = ydata(i%)
z = zdata(i%)
for j% = 2 to nalf1%
a = a * x
xa(j%) = a
if (j% <= ndeg1%) then zadd(1, j%) = zadd(1, j%) + a * z
hsmg(1, j%) = hsmg(1, j%) + a
next j%
for l% = 2 to nalf1%
for m% = 1 to nalf2% - l%
xa(m%) = xa(m%) * y
hsmg(l%, m%) = hsmg(l%, m%) + xa(m%)
next m%
if (l% <= ndeg1%) then
for n% = 1 to ndeg2% - l%
zadd(l%, n%) = zadd(l%, n%) + xa(n%) * z
next n%
end if
next l%
next i%
end if
hsmg(1, 1) = ndata%
zadd(1, 1) = z1
m% = 0
n% = 0
m% = m% + 1
xmatrix(m%, ncol%) = zadd(i%, j%)
for k% = i% to ndeg% + i%
for l% = j% to ndeg% + i% + j% - k%
n% = n% + 1
xmatrix(m%, n%) = hsmg(k%, l%)
next l%
next k%
next j%
next i%
if (ndeg% = 0) then
xa(1) = xmatrix(1, 2) / xmatrix(1, 1)
return
end if
nr1% = nrow% - 1
for k% = 1 to nr1%
nb% = 0
amax = xmatrix(k%, k%)
i1% = k% + 1
for ki% = i1% to nrow%
if (abs(xmatrix(ki%, k%)) > abs(amax)) then
amax = xmatrix(ki%, k%)
nb% = ki%
end if
next ki%
if (nb% <> 0) then
for nl% = k% to ncol%
xsave = xmatrix(nb%, nl%)
xmatrix(nb%, nl%) = xmatrix(k%, nl%)
xmatrix(k%, nl%) = xsave
next nl%
end if
const1 = xmatrix(k%, k%)
for i% = i1% to nrow%
xa(i%) = -xmatrix(i%, k%) / const1
next i%
for j% = i1% to ncol%
const1 = xmatrix(k%, j%)
xmatrix(i%, j%) = xmatrix(i%, j%) + const1 * xa(i%)
next i%
next j%
next k%
xa(nrow%) = xmatrix(nrow%, ncol%) / xmatrix(nrow%, nrow%)
for i% = 1 to nr1%
k% = nrow% - i%
sum = 0.0
for j% = k% + 1 to i% + k%
sum = sum + xmatrix(k%, j%) * xa(j%)
next j%
xa(k%) = (xmatrix(k%, ncol%) - sum) / const1
next i%
' load coef array
k% = 0
k% = k% + 1
coef(i%, j%) = xa(k%)
next j%
next i%
end sub
sub sfunction(ndeg%, coef(), x, y, z)
' interpolate surface function subroutine
' z = f(x,y)
' input
' coef() = array of surface fit coefficents
' (up to 11 rows by 11 columns)
' x = x data value
' y = y data value
' output
' z = interpolated z data value of surface at x, y
local a, y1
local work(ndeg1% * ndeg2% / 2)
if (ndeg% = 0) then
z = coef(1, 1)
exit sub
end if
a = 1.0
y1 = 0.0
work(1) = 1.0
for i% = 2 to ndeg1%
a = a * x
work(i%) = a
y1 = y1 + a * coef(1, i%)
next i%
work(j%) = work(j%) * y
y1 = y1 + work(j%) * coef(i%, j%)
next j%
next i%
z = y1 + coef(1, 1)
end sub
