Forum Index : Microcontroller and PC projects : ILI9163 SPI LCD driver for 28-pin?
Hi there. I can't remember if there was a driver ever written for this controller or not. matherp? EDIT: I know that the MM+ supports this controller natively, but can you get a loadable C-Function kind of driver to make this controller work on the 28-pin MM2 chip? Smoke makes things work. When the smoke gets out, it stops! |
Yes this is supported on the 28-pin MM via a CFunction driver. The driver is in the Micromite firmware download. Look under: Embedded C Modules\ILI9163 LCD Geoff Geoff Graham - http://geoffg.net |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11890 |
The current version of the driver only supports 128x128 resolution. Shouldn't be difficult to change to 160x128 but won't work properly "out of the box" |
@ Geoff - thanks. Crikey. How did I miss seeing that?!(rhetorical!) @ matherp: You've been reading my other posts. IF I decide to use a 160x128 touch LCD from BuyDisplay, would you be able to change the driver to support that resolution then? No need to do it now, as I am still unsure if I am going to do it that way or not.....Smoke makes things work. When the smoke gets out, it stops! |
