Local Time 11:12 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - Chebyshev approximations
cdeagle
Posted: 03:59am 13 Apr 2017
This program demonstrates the procedures for calling several Chebyshev subroutines.
These subroutines can be used to approximate the integral, derivative, and
function value of a user-defined analytic function. This same information can be determined for tabular data of the form y = f(x).
This program demonstrates the use of the Chebyshev subroutines for evaluating information about
y = x^2 * (x^2 - 2.0) * sin(x)
Here's a typical user interaction and the results produced by the software.
chebyshev approximations
please input the maximum degree of the chebyshev approximation
? 20
please input the lower limit of the evaluation interval
? 1
please input the upper limit of the evaluation interval
? 2
please input the number of terms in the chebyshev approximation
? 15
please input the x argument for evaluation
? 1.5
lower limit of interval = 1
upper limit of interval = 2
function argument = 1.5
chebyshev function value = 0.56109093
analytic function value = 0.56109093
error = 1.11022e-15
chebyshev derivative = 7.52100208
analytic derivative = 7.52100208
error = 8.88178e-15
chebyshev integral = -0.23929577
analytic integral = -0.23929577
error = 2.77556e-16
maximum degree of approximation = 20
degree of chebyshev fit = 15
Here's the source code listing.
' program "demo_chebyshev.bas" April 13, 2017
' This program demonstrates the procedures for calling
' the Chebyshev subroutines. These subroutines can be
' used to approximate the integral, derivative, and
' function value of a user-defined analytic function.
' This same information can be determined for tabular
' data of the form y = f(x).
' This program demonstrates the use of the Chebyshev
' subroutines for evaluating information about
' y = x^2 * (x^2 - 2.0) * sin(x)
option default float
option base 1
const pidiv2 = 0.5 * pi
' begin main program
print " "
print "chebyshev approximations"
print "------------------------"
do
print " "
print "please input the maximum degree of the chebyshev approximation"
input nval%
loop until (nval% > 0)
dim c(nval%), cder(nval%), cinq(nval%)
print " "
print "please input the lower limit of the evaluation interval"
input xl
print " "
print "please input the upper limit of the evaluation interval"
input xu
' compute chebyshev coefficients
cheby_fit(xl, xu, c(), nval%)
do
print " "
print "please input the number of terms in the chebyshev approximation"
input n%
loop until (n% > 0 and n% <= nval%)
do
print " "
print "please input the x argument for evaluation"
input x
loop until (x >= xl and x <= xu)
' evaluate chebyshev approximation of user-defined function
cheby_eval(xl, xu, c(), n%, x, fval1)
' compute analytic value of function
user_func(x, fval2)
' compute derivative chebyshev coefficients
cheby_der(xl, xu, c(), n%, cder())
' evaluate chebyshev derivative approximation
cheby_eval(xl, xu, cder(), n%, x, dfdx1)
' compute analytic value of derivative
dfdx(x, dfdx2)
' compute quadrature chebyshev coefficients
cheby_quad(xl, xu, c(), n%, cinq())
' evaluate chebyshev quadrature approximation
cheby_eval(xl, xu, cinq(), n%, x, fint1)
' compute analytic value of quadrature
intx(x, fx)
intx(xl, fl)
fint2 = fx - fl
' print results
print " "
print " "
print "lower limit of interval = "; xl
print "upper limit of interval = "; xu
print " "
print "function argument = "; x
print " "
print "chebyshev function value = "; str$(fval1, 0, 8)
print "analytic function value = "; str$(fval2, 0, 8)
print "error = "; abs(fval1 - fval2)
print " "
print "chebyshev derivative = "; str$(dfdx1, 0, 8)
print "analytic derivative = "; str$(dfdx2, 0, 8)
print "error = "; abs(dfdx1 - dfdx2)
print " "
print "chebyshev integral = "; str$(fint1, 0, 8)
print "analytic integral = "; str$(fint2, 0, 8)
print "error = "; abs(fint1 - fint2)
print " "
print "maximum degree of approximation = "; nval%
print " "
print "degree of chebyshev fit = "; n%
print " "
end
sub cheby_fit (a, b, c(), n%)
' compute chebshev coefficients subroutine
' input
' a = lower limit of evaluation interval
' b = upper limit of evaluation interval
' n% = maximum degree of chebyshev approximation
' output
' c() = array of chebyshev coefficients
' note: user-defined function coded as
' sub user_func(x, fx)
local f(n%), bma, bpa, x, fx, fac, sum
bma = 0.5 * (b - a)
bpa = 0.5 * (b + a)
for k% = 1 to n%
x = cos(pi * (k% - 0.5) / n%) * bma + bpa
user_func(x, fx)
f(k%) = fx
next k%
fac = 2.0 / n%
for j% = 1 to n%
sum = 0.0
for k% = 1 to n%
sum = sum + f(k%) * cos((pi * (j% - 1)) * ((k% - 0.5) / n%))
next k%
c(j%) = fac * sum
next j%
end sub
sub cheby_der (a, b, c(), n%, cder())
' chebyshev coefficients of the derivative subroutine
' input
' n% = size of c() array
' output
' cder() = array of chebyshev derivative coefficients
local con
cder(n%) = 0.0
cder(n% - 1) = 2.0 * (n% - 1) * c(n%)
if (n% >= 3) then
for j% = n% - 2 to 1 step -1
cder(j%) = cder(j% + 2) + 2.0 * j% * c(j% + 1)
next j%
end if
con = 2.0 / (b - a)
for j% = 1 to n%
cder(j%) = cder(j%) * con
next j%
end sub
sub cheby_eval (a, b, c(), m%, x, vcheb)
' evaluate chebshev coefficients subroutine
' input
' c() = array of chebshev coefficients
' m% = size of c() array
' x = argument
' output
' vcheb = function value at x
local d, dd, y, y2, sv
d = 0.0
dd = 0.0
y = (2.0 * x - a - b) / (b - a)
y2 = 2.0 * y
for j% = m% to 2 step -1
sv = d
d = y2 * d - dd + c(j%)
dd = sv
next j%
vcheb = y * d - dd + 0.5 * c(1)
end sub
sub cheby_quad (a, b, c(), n%, cinq())
' chebyshev quadrature coefficients subroutine
' input
' output
' cinq() = array of chebyshev quadrature coefficients
local con, sum, fac
con = 0.25 * (b - a)
sum = 0.0
fac = 1.0
for j% = 2 to n% - 1
cinq(j%) = con * (c(j% - 1) - c(j% + 1)) / (j% - 1)
sum = sum + fac * cinq(j%)
fac = -fac
next j%
cinq(n%) = con * c(n% - 1) / (n% - 1)
sum = sum + fac * cinq(n%)
cinq(1) = 2.0 * sum
end sub
' user-defined function subroutine
fx = (x * x) * (x * x - 2.0) * sin(x)
end sub
sub intx(x, fx)
' test function integral subroutine
fx = 4.0 * x * (x * x - 7.0) * sin(x) - (x * x * x * x - 14.0 * x * x + 28.0) * cos(x)
end sub
sub dfdx(x, fx)
' test function derivative subroutine
fx = 4.0 * x * (x * x - 1.0) * sin(x) + x * x * (x * x - 2.0) * cos(x)
end sub
