Local Time 10:30 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DHCP Ethernet device
Posted: 05:55pm 13 Apr 2017
Hi all,
I am needing to build a `pinger' or other `responder' for testing ethernet connectivity (could be 2km from host over a combination of copper and fibre)
I am thinking that the WIZNET (I think mine is a 5100) module but I am asking for advice on other possible modules (cheap is preferred but not a killer if a more pricey module is a better fit).
What I need is the ability to ask for and accept a DHCP IP address. (an know what this address is to display on a TFT/LCD screen)
And a method of either doing a ping to a known IP Address or accepting a ping (the latter requiring some one else to initiate this ping) but I am thinking a bit of fun as well like the remote (laptop/PC) asking for a web page that shows an image of BIGMIK with a Thumbs up to show the connection is capable of sending data etc..
Anyway open to suggestions for those that have `gone before'...
Kind Regards,
Posted: 08:20pm 13 Apr 2017
I suppose any cheap Linux-capable device - RPi (Zero / Zero W) springs to mind.
Or an esp8266.
CaptainBoing
Posted: 10:32pm 13 Apr 2017
Hi BigMik
is/will the pinger on wifi (i.e. locally after your ethernet wire/fibre spur)?
if so, the ESP8266 is a good option as it will handle the DHCP config to your router and it has a built in PING command.
I use exactly this option (as part of functionality on my LAN to SMS gateway) on my network here to ping one of my ISPs DNS boxes to confirm I have internet connectivity to them. The box monitors connectivity every minute and sends a SMS (M590E but a SIM800 will do just as well) after 3 consecutive time-outs. It then continues to text every 10 minutes while the condition continues and then sends a text when the network comes back up. I have the mains power for the router going through a realy controlled by the uM and I can send a text to the box to bounce the power to the router... as that has been the source of my worries. Did this from Madeira while on holiday last year, but just having the ability to bounce remotely is a real boon. This is all run by a 28pin MX with MMBasic 5.3
One slight problem is that it is fooled by wifi outage/congestion as well but I can live with that.
The ping to the pinger is easy from a server on the main network - my ESP8266 is set to static IP address so it is always a known quantity.
it runs in a "lights out" environment so doesn't have a display (although one was always planned) but it produces rich logs to the console while running but it is completely stand-alone. Months go by with out me connecting to it... oh, and it sends me a heartbeat text every day.
with this option you can be up and running in an hour and around $10 + $8 a month for the SIM.
published everything here http://www.fruitoftheshed.com/MMBasic.Micromite-SMS-Text-Gateway.ashx
hth
h
Edited by CaptainBoing 2017-04-15
Posted: 01:12am 14 Apr 2017
Hi Captn,
Unfortunately it has to be wired,
The purpose of this is in our business has, in our busy period, remote terminals (betting terminals at race tracks). Often these are setup in areas that run on generators, which often are not set up until the day before a race meeting which gives us no time to debug any issues. Currently our system is run on an RS485 network and I use a micro mite to emulate a terminals protocol (software written by Peter Carnegie) this runs from a Xioami battery pack and works well, enabling us to test our network when there is no power infrastructure available.. we are over the next 12 months changing entirely to an Ethernet based system.. an expansion of our other existing network..
I want to have a similar hand held, battery powered, tool to do the same on an Ethernet WIRED network..
I will have a read of your article, I might get some ideas.
Thank you,
Posted: 01:35am 14 Apr 2017
How about an Orange Pi?
here
They do a Zero that's about $10
JohnEdited by JohnS 2017-04-15
CaptainBoing
Posted: 02:49am 14 Apr 2017
another way then might be to use a bog standard PIC/Arduino with Great Cow Basic - they support the ENC28J60 on anything with 1K of ram...
https://sourceforge.net/p/gcbasic/discussion/579125/thread/d99324de/
might give you some ideas.
Using this device with a uM is on my long term radar but I haven't got round to doing it yet (or until probably July)
all the bestEdited by CaptainBoing 2017-04-15
CircuitGizmos
Posted: 05:26am 14 Apr 2017
I would think that the lowest effort (and cost) would be made using a Raspberry Pi.
Posted: 05:33am 14 Apr 2017
That was what I thought till it turned out it has to be wired.
Could be a Pi + external LAN board (ENC28J60 etc) but it's about the price of the board I posted and messier.
CircuitGizmos
Posted: 05:47am 14 Apr 2017
  JohnS said   That was what I thought till it turned out it has to be wired.
I must be confused. A Pi has a wired Ethernet port. Hardware could be Pi, LCD, button(s), battery.
Software possibly Python.
Edited by CircuitGizmos 2017-04-15
Posted: 06:02am 14 Apr 2017
Only some have a wired port. They cost more than what I posted don't they?
CircuitGizmos
Posted: 06:35am 14 Apr 2017
I was thinking the cost of the total solution. I didn't realize that the Orange had the same pinout as the Pi and could take the same LCD/button boards.
Posted: 06:51am 14 Apr 2017
There again, the Great Cow Basic w/ a clone Arduino may be cheaper still. Have to add the ENC but no need for SD/uSD card.
And (a lot) lower power.
I'm amazed a TCP/IP stack (apparently) fits on an Arduino!
jman
Posted: 09:55am 14 Apr 2017
Or this Arduino Lan tester
That will be cheap to put together
Jman
CaptainBoing
Posted: 12:08pm 14 Apr 2017
I reckon that is the one! - good catch
Posted: 12:31pm 14 Apr 2017
Though it seems to need a mega 2560 (plus the LAN board) and they're not that cheap.
Can be done with a STM32F103C8T6 (+ LAN board) very cheaply, as another idea.
jman
Posted: 01:41pm 14 Apr 2017
Cheap as chips $8.60 shipped
Mega2560
Jman
Posted: 07:07pm 14 Apr 2017
Hi All,
  jman said   Or this Arduino Lan tester
Thank you all for your great ideas.. I have been considering buying a Pi and have seen the OrangePi before as well.. I might get one of the OPi's as they seem pretty cheap (not for this project but to play with and learn /.... errr Stuff ..)
@ JMan...
PERFECT That device seems to be more or less all I need and more.. I will look into it as my first option.. I didnt see any link (using iPad isnt easy) to the HEX files and code etc.. but I will spend more time searching when I am on my PC later today.
Kind Regards,
MickEdited by bigmik 2017-04-16
Posted: 07:42pm 14 Apr 2017
@JMan,
It appears that to get the information you have to pay a monthly subscription to Instructables.. @$36US per year.. Is that the case or is the information, re code etc available somewhere with the free acct?
I may join up anyway as it looks good but I am wondering if by paying their subscription you do get all of the code and schematics etc to actually build the project(s), I dont wish to join if all the required information isnt there.
CaptainBoing
Posted: 09:05pm 14 Apr 2017
I think you'll have some work to do on that instructables project - yes it will do what you want out of the box but looking through all the vids, it lacks "polish" - the netmask section in particular evidently accepts settings that won't work and you could end up in an unfathomable mess - it would have been really easy to sanity check it... personally I wouldn't do it with an arbitrary string of octets, but hey, he has a working device and I don't
I have just done a very quick comparison of the ENC28J60 and the Wiznet W5100 (which seems to be a better option for TCP over the W5500). I am very keen to get this sort of thing working with my own code - I don't like to rely on libraries too much.
I think with the W5100 you could be up and running in a very short time - more of the work on the stack is done by the hardware which offloads all/most of the work if you can't be bothered with building mid-level protocols on top of PHY (and it is a LOT of work). The trade off is "only" four open sockets at a time. With the ENC you have no choice, you get MAC and flow control and you have to do everything above that yourself.
The W5100 can be set to handle all the tedious mucking about with the low level stuff and provide sockets out of the box and has "high-level" protocols built in (ICMP,IP,TCP,UDP etc.) so sockets should be a breeze.
I was thinking about making an "adaptor" out of a PIC + GCB to provide an interface module (similar in concept to a USB to Serial mod but with ethernet) but if the wiznet beast is as straightforward as it looks I would really like a pure MMBasic solution. I have one coming for the princely sum of <£4. I will have a concerted push to get something working and publish what I get.Edited by CaptainBoing 2017-04-16
jman
Posted: 09:49pm 14 Apr 2017
@Mick
Code attached but untested
2017-04-
15_074857_Arduino-Network-tester-master.zip
Jman
