Local Time 10:30 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Multiline IF. Where have I gone wrong?
GoodToGo!
Posted: 09:19pm 23 Apr 2017
Howdy all,
Long time lurker, first time poster and have finally thrown my hat into the MM ring. Own one of the absolutely brilliant Explore28 jobs and a Silicon Chip MM+ LCD backpack.
Been a huge admirer of Geoff's work ever since I built my GPS synchronised clock back in the long long ago. That sucker is still going strong, especially after helping squash the daylight saving bug in it.
Anyway, I've been playing around with the MM+ LCD backpack. Great bit of kit but of course there are some minor coding differences between it and a 'normal' LCD backpack.
So, the problem.
With the Boat computer, there are a couple of lines associated with the touch interrupt side of things that are not applicable to the MM+. So I modified it accordingly, however the following Multiline IF refuses to work.
'Get MM device type
if MM.Device$ = "Micromite MkII" then DeviceType = 1
elseif MM.Device$ = "Micromite Plus" then DeviceType = 2
elseif MM.Device$ = "Micromite eXtreme" then DeviceType = 2
Else DeviceType = 1
endif
print DeviceType
Print MM.Device$
When I run it, the Touchscreen doesn't respond and it produces the following from the two PRINT statements:-
  Quote   0
Micromite Plus
However if I recode it to the following:-
'Get MM device type
if MM.Device$ = "Micromite Plus" Then DeviceType = 2
It works as advertised with DeviceType = 2. FYI DeviceType is used to select one of the following statements:-
' this interrupt is used to detect touch on the main screen
If DeviceType = 1 then
SetPin Peek(Byte Peek(Word &H9D000090) + 23), INTL, TouchDown
elseif DeviceType = 2 then
gui interrupt TouchDown
endif
Where have I gone wrong with the Multiline IF statement? Why doesn't it at the very least change DeviceType to '1' as per the last 'ELSE' statement?
It's bugging (ha!) me because I can't figure it out.
Any thoughts?
Cheers,
GTG!
Posted: 09:29pm 23 Apr 2017
Try (untested)
'Get MM device type
DeviceType = 1
DeviceType = 2
DeviceType = 2
Else
DeviceType = 1
endif
GoodToGo!
Posted: 10:07pm 23 Apr 2017
Thanks matherp!
That sorted it. Can't believe I stared at the screen for hours trying to work it out... especially when you consider I had formatted the second Multiline statement correctly. Ah well, live and learn!
Cheers,
GTG!
Posted: 12:35am 24 Apr 2017
@GoodToGo
Just making you aware that there is also a SELECT CASE command that some people find easier to read.
Using the same example as above:
SELECT CASE MM.Device$
CASE "Micromite MkII"
DeviceType = 1
CASE "Micromite Plus", "Micromite eXtreme"
DeviceType = 2
CASE ELSE
DeviceType = 1
END SELECT
In fact if these are the values you need, it can be shortened further:
DeviceType = 2
CASE ELSE
DeviceType = 1
END SELECT
WW
GoodToGo!
Posted: 04:10pm 25 Apr 2017
Hi WW,
Thanks for the tip, I like it, it reads well and works a charm.
It's going straight to the poolroom. (Gratiuitous "The Castle" reference, hopefully not lost on most people......)
Cheers!
GTG!
