Local Time 09:48 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX/RPI - system of nonlinear equations
cdeagle
Posted: 12:19am 30 Apr 2017
' program demo_nle.bas April 30, 2017
' this program demonstrates the procedure for calling
' subroutine nlbrent which solves an unconstrained
' system of non-linear equations using brent's method.
' nlbrent requires a subroutine called userfunc which
' returns the function values of a user-defined system
' of non-linear equations.
' this program demonstrates the use of nlbrent to solve
' the system of two non-linear equations which define the
' relationship between geocentric and geodetic coordinates.
' (c + altitude) * cos(lat) - rmag * cos(decl) = 0
' (s + altitude) * sin(lat) - rmag * sin(decl) = 0
Here's a typical user interaction with the software.
please input the geocentric declination (degrees)
(-90 degrees <= declination <= 90 degrees)
? 45
please input the geocentric radius (kilometers)
? 8000
please input the maximum number of iterations
( a value of between 20 and 50 is recommended )
? 20
please input the convergence criteria
( a value of 1.0e-8 is recommended )
? 1e-8
program demo_nle - solution of a non-linear system
geocentric declination 45.000000 degrees
geocentric radius 8000.000000 kilometers
geodetic latitude 45.153156 degrees
geodetic altitude 1632.571960 kilometers
value of residual # 1 2.0645529730245471e-10
value of residual # 2 0.0000000000000000e+00
number of iterations 9
convergence criterion 1.00000e-08
Here's the MMBASIC source code listing.
option default float
option base 1
const dtr = pi / 180.0 ' degrees to radians
const rtd = 180.0 / pi ' radians to degrees
const req = 6378.14 ' equatorial earth radius
const flat = 1.0 / 298.257.0 ' earth flattening factor
const rpolar = req * (1.0 - flat) ' polar earth radius
dim rmag, decl
' define number of variables
nvar% = 2
' dimension solution vector
dim x(nvar%), fvec(nvar%)
do
print " "
print "please input the geocentric declination (degrees)"
print "(-90 degrees <= declination <= 90 degrees)"
input decl_deg
loop until (abs(decl_deg) >= 0.0 and abs(decl_deg) <= 90.0)
decl = decl_deg * dtr
x(1) = decl
do
print " "
print "please input the geocentric radius (kilometers)"
input rmag
loop until (rmag > rpolar)
x(2) = rmag - rpolar
do
print " "
print "please input the maximum number of iterations"
print "( a value of between 20 and 50 is recommended )"
input maxiter%
loop until (maxiter% > 0)
do
print " "
print "please input the convergence criteria"
print "( a value of 1.0e-8 is recommended )"
input tol
loop until (tol > 0.0)
' solve the system of nonlinear equations
nlbrent(nvar%, x(), fvec(), tol, maxiter%, info%, nfev%)
print " "
print "program demo_nle - solution of a non-linear system"
print "=================================================="
print " "
select case info%
case 1, 2, 3
print " "
print "geocentric declination "; str$(decl_deg, 0, 6); " degrees"
print " "
print "geocentric radius "; str$(rmag, 0, 6); " kilometers"
print " "
print "geodetic latitude "; str$(x(1) * rtd, 0, 6); " degrees"
print " "
print "geodetic altitude "; str$(x(2), 0, 6); " kilometers"
print " "
for i% = 1 to nvar%
print " "
print "value of residual #"; i%; " "; str$(fvec(i%), 0, -16)
next i%
print " "
print "number of iterations "; nfev%
print " "
print "convergence criterion "; tol
print " "
case 4
print
print "maximum number of iterations exceeded!"
case 5
print " "
print "approximate jacobian matrix is singular!"
case 6
print " "
print "iteration is not making good progress!"
case 7
print " "
print "iteration is diverging!"
case 8
print " "
print "iteration is converging, but tol is too small,"
print "or the convergence is very slow due to a jacobian"
print "singular near the output x or due to badly scaled"
print "variables!"
end select
end
sub nlbrent(n%, x(), fvec(), tol, maxfev, info%, nfev%)
' brent's solution of a non-linear system subroutine
' input
' n% = number of equations
' x() = initial guess for solution vector
' tol = convergence tolerance
' maxfev = maximum number of function evaluations allowed
' output
' x() = solution vector
' fvec() = residual vector
' info% = information flag
' 1 = all residuals are at most tol in magnitude
' 2 = relative error between two sucessive iterates
' is at most tol
' 3 = conditions for both info% = 1 and info% = 2 hold
' 4 = number of function evaluations >= maxfev
' 5 = approximate jacobian matrix is singular
' 6 = iteration is not making good progress
' 7 = iteration is diverging
' 8 = iteration is converging, but tol is too small,
' or the convergence is very slow due to a jacobian
' singular near the output x or due to badly scaled
' variables
' nfev% = number of actual function evaluations
' note: requires sub userfunc
local sigma(n%), wa1(n%), wa2(n%), q(n%, n%)
' initialization
epsmch = 2.2e-16
p05 = 0.05
scale = 10.0
ftol = tol
xtol = tol
info% = 0
nfev% = 0
nfcall% = 0
nier6% = -1
nier7% = -1
nier8% = 0
fxnorm = 0.0
difit = 0.0
xnorm = 0.0
for i% = 1 to n%
if (abs(x(i%)) > xnorm) then xnorm = abs(x(i%))
next i%
eps = sqr(epsmch)
delta = scale * xnorm
if (xnorm = 0.0) then delta = scale
' estimate number of iterative refinements
emax = 0.0
for i% = 1 to n%
temp = log(i% + 1.0) / (n% + 2.0 * i% + 1.0)
if (temp < emax) then exit for
mopt% = i%
emax = temp
next i%
' principal iteration loop
do
nsing% = n%
fxnorm1 = fxnorm
difit1 = difit
fxnorm = 0.0
' determine divided difference step
h = eps * xnorm
if (h = 0.0) then h = eps
for j% = 1 to n%
for i% = 1 to n%
q(i%, j%) = 0.0
next i%
q(j%, j%) = h
wa1(j%) = x(j%)
next j%
' perform subiteration
for k% = 1 to n%
userfunc(wa1(), fvec())
fky = fvec(k%)
nfcall% = nfcall% + 1
nfev% = nfcall% / n%
if (abs(fky) > fxnorm) then fxnorm = abs(fky)
for j% = k% to n%
for i% = 1 to n%
wa2(i%) = wa1(i%) + q(i%, j%)
next i%
userfunc(wa2(), fvec())
fkz = fvec(k%)
sigma(j%) = fkz - fky
next j%
fvec(k%) = fky
eta = 0.0
for i% = k% to n%
if (abs(sigma(i%)) > eta) then eta = abs(sigma(i%))
next i%
if (eta <> 0.0) then
nsing% = nsing% - 1
sknorm = 0.0
for i% = k% to n%
sigma(i%) = sigma(i%) / eta
sknorm = sknorm + sigma(i%) ^ 2
next i%
sknorm = sqr(sknorm)
if (sigma(k%) < 0.0) then sknorm = -sknorm
sigma(k%) = sigma(k%) + sknorm
for i% = 1 to n%
wa2(i%) = 0.0
next i%
for j% = k% to n%
temp = sigma(j%)
for i% = 1 to n%
wa2(i%) = wa2(i%) + temp * q(i%, j%)
next i%
next j%
for j% = k% to n%
temp = sigma(j%) / (sknorm * sigma(k%))
for i% = 1 to n%
q(i%, j%) = q(i%, j%) - temp * wa2(i%)
next i%
next j%
sigma(k%) = sknorm * eta
temp = fky / sigma(k%)
if (h * abs(temp) > delta) then temp = sgn(temp) * (delta / h)
for i% = 1 to n%
wa1(i%) = wa1(i%) + temp * q(i%, k%)
next i%
end if
next k%
xnorm = 0.0
difit = 0.0
for i% = 1 to n%
if (abs(wa1(i%)) > xnorm) then xnorm = abs(wa1(i%))
if (abs(x(i%) - wa1(i%)) > difit) then difit = abs(x(i%) - wa1(i%))
x(i%) = wa1(i%)
next i%
if ((scale * xnorm) > delta) then delta = scale * xnorm
if ((fxnorm < fxnorm1) and (difit < difit1) and (nsing% = 0)) then iconv = 1
nier6% = nier6% + 1
nier7% = nier7% + 1
nier8% = nier8% + 1
if (iconv = 1) then nier6% = 0
if ((fxnorm < fxnorm1) or (difit < difit1)) then nier7% = 0
if (difit > (eps * xnorm)) then nier8% = 0
' convergence tests
if (fxnorm <= ftol) then info% = 1
if ((difit <= (xtol * xnorm)) and (conv = 1)) then info% = 2
if ((fxnorm <= ftol) and (info% = 2)) then info% = 3
if (info% <> 0) then exit do
' termination tests
if (nfev% >= maxfev) then info% = 4
if (nsing% = n%) then info% = 5
if (nier6% = 5) then info% = 6
if (nier7% = 3) then info% = 7
if (nier8% = 4) then info% = 8
if ((iconv = 0) or (difit > p05 * xnorm) or (mopt% = 1)) then
' null
else
' perform iterative refinement
for m = 2 to mopt%
fxnorm1 = fxnorm
fxnorm = 0.0
for k% = 1 to n%
fky = fvec(k%)
if (fxnorm >= fxnorm1) then
fxnorm = fxnorm1
exit for
end if
for i% = 1 to n%
next i%
next k%
xnorm = 0.0
difit = 0.0
for i% = 1 to n%
x(i%) = wa1(i%)
next i%
' stopping criteria for iterative improvement
if (difit <= (xtol * xnorm)) then info% = 2
if ((nfev% >= maxfev) and (info% = 0)) then info% = 4
next m
end if
loop
end sub
sub userfunc (x(), fx())
' user-defined system of non-linear equations subroutine
' input
' x() = function argument vector
' output
' fx() = array of function values evaluated at x
local xlat, altitude, c, s
xlat = x(1)
altitude = x(2)
c = req / sqr(1.0 - (2.0 * flat - flat ^ 2) * sin(xlat) ^ 2)
s = c * (1.0 - flat) ^ 2
fx(1) = (c + altitude) * cos(xlat) - rmag * cos(decl)
fx(2) = (s + altitude) * sin(xlat) - rmag * sin(decl)
end sub
