Local Time 09:04 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Losing saved array data
Quazee137
Posted: 09:02pm 16 May 2017
I am losing the last few parts of the array
The 1st run fills dummy data then saves
the 2nd run shows data is missing
it does this on a 170 backpack, Micks backpack
and a breadboard setup.
Print MM.Ver,MM.Device$
Print " very basic pump house var test"
Option base 1
'VAR restore ' gives error if used
Dim pump$(2,7,2) length 5
Input "1st run y/n ";k$
If k$="n" Then GoTo here
blank
show
fill
show
here:
Print " restored "
VAR restore
show
Print " run a 2nd time"
Sub blank
Print "fill blank enteries"
For p=1 To 2
For d=1 To 7
pump$(p,d,1)="--:--"
pump$(p,d,2)="---"
Next d
Next p
End Sub
Sub fill
Print "fill with data"
For p=1 To 2
For d=1 To 7
pt=Int(Rnd*1440)
ph=Int(pt\60)
pm=pt-(ph*60)
pump$(p,d,1)=Str$(ph,2)+":"+Str$(pm,2)
pump$(p,d,2)=Str$(Int(Rnd*720),3)
Next d
Next p
VAR save pump$()
End Sub
Sub show
Print
For d=1 To 7
Print pump$(1,d,1);" ";pump$(1,d,2);" | ";
Print pump$(2,d,1);" ";pump$(2,d,2)
Next d
Print
End Sub
GoodToGo!
Posted: 10:58pm 16 May 2017
Interesting.....
I could get it to reliably work but I had to extend the array LENGTH to 31.
Anything less and it would drop some of the variables.
I don't understand that one.
Bug perhaps?
GTG!
Posted: 01:12am 17 May 2017
Thanks for the demo. It is a bug and I have found it, the fix will be in the next version due in a few weeks.
BTW. The following will give an error because the array must be declared before VAR RESTORE.
The following will work OK:
VAR restore ' will not give an error
GoodToGo!
Posted: 02:31am 17 May 2017
Nice work once again Geoff
GTG!
Posted: 12:08pm 17 May 2017
BTW the workaround is to make the array slightly larger but not use the extra elements. Ie:
Dim pump$(2,10,2) length 5
Quazee137
Posted: 02:12am 18 May 2017
Thank You So Very Much.Now I can keep working on this. I have 5 of the new backpacks coming. I can use one to reprogram the 15 chips I have here.
I had miss pasted the var restore. LOL
Funny I had the array larger but cut the code down to simplify
the output to the LCD.
These are replacing very old water treatment controllers.
Thanks You! With MMBasic I have done 8 so far. And in much less time.
I started over a year ago with PIC's trying c and forth but the pin
settings was always a bugger to get right. I have plans for 6 different
versions even going to try ladder logic PLC with one of the bigger chips.
I never would have tried that before MMBasic and the backpacks.
Thanks Again
