Local Time 08:26 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic Quick Reference
Posted: 05:52am 02 Jun 2017
Some time ago a TBS forum member called crackerjack produced a great quick reference for MMBasic. The last update was for MMBasic V3.2 and since then I have really missed having an up to date version - so I thought that I would have a go at creating my own.
If you are interested, this is it: 2017-06-02_153917_Micromite_Quick_Reference.pdf
At this time it just covers the standard 28 and 44-pin Micromites but in the future I might expand it to include the Micromite Plus - that however will require a much smaller font to fit everything in.
MicroBlocks
Posted: 06:45am 02 Jun 2017
Nice overview. This will be very handy to use.
With this overview it shows how much the serial communication is similar.
Would this not offer an opportunity to aggregate the similar functionalities in just a few commands/functions.
Like this:
[code]
OPEN "COM1:...." AS #fnbr
OPEN "I2C1:...." AS #fnbr
OPEN "1WIRE:..." AS #fnbr
OPEN "SPI1:...." AS #fnbr
PRINT #fnbr
INPUT$(#fnbr,...)
etc...
CLOSE #fnbr
[/code]
It will free up keywords and it might be possible to share code between the different devices.
It also allows to add other devices in the future like USB, Displays, keyboards, WiFi modules etc without the need for numerous specific keywords.
Edited by MicroBlocks 2017-06-03
piclover
Posted: 07:44am 02 Jun 2017
Most useful (it saves from opening the big PDF of the manual and browsing several pages to find the syntax of a rarely used function).
Thank you Geoff !
PicFan
Posted: 09:30am 02 Jun 2017
Helle Geoff !
I know that of AIM 65 (6502 CPU), very good, thank you.
Wolfgang
BobD
Posted: 10:06am 02 Jun 2017
It's very good and I like it. It can be used two ways. If you know what you're doing it's a great QR and if you don't then it can be used as a pointer to the full manual.
I found a small error. The unfortunate part about this one is I don't know which one is wrong without reading the full doc and it's too early in the morning for that.
and in the Variables there is a spelling error which wouldn't rate an effort but if you're in there correcting ..
GoodToGo!
Posted: 10:25am 02 Jun 2017
Now that's going to come in handy!
I hope you consider a MM+ version, maybe only do a page with the different commands?
GTG!
Posted: 10:28am 02 Jun 2017
x << y is shift left (obviously), aka up
(same as in C)
The lowest bit (bit 0, with value 1) is defined to be at the far right.
JohnEdited by JohnS 2017-06-03
OA47
Posted: 12:10pm 02 Jun 2017
Thanks Geoff, I have been missing this reference.
Graeme
Posted: 03:50pm 02 Jun 2017
Nice one.
Posted: 10:23pm 02 Jun 2017
I have had another go at this. This version is formatted better and includes the Micromite Plus.
2017-06-03_082009_Micromite_Quick_Reference.pdf
If you print it out it is intended to be folded Z-fold fashion with the title at the top of the folded stack. This format also works well if you want to display it on your tablet/PC, etc.
paceman
Posted: 02:35am 03 Jun 2017
Yes, thanks from me too Geoff, this will get dog-eared pretty quickly and I've made the Z-fold already!
Greg
Posted: 03:00am 03 Jun 2017
This is BRILLIANT
Now I have an excuse to buy that colour laser printer
If you don't mind, I would like to print this out and enclose to 'newbie' customers if thats ok.
WW
Posted: 03:22am 03 Jun 2017
Go for it WW.
Cremo
Posted: 09:05am 03 Jun 2017
Geoff thank you a lot.
Pietro
palcal
Posted: 11:41am 03 Jun 2017
Laminated and on the wall above my monitor. This is great, will save a lot of time.
Paul.
Posted: 03:57pm 04 Jun 2017
@Geoff,
  WhiteWizzard said   This is BRILLIANT
I agree Whole heartedly with that sentiment.. It is really professional looking.. Thanks Geoff and of course crackerjack...
  WhiteWizzard said  Now I have an excuse to buy that colour laser printer
WW,
You don't need a colour laser..
An Ink-jet and then laminated gives a brilliant result. The laminating makes dull plain paper look like a glossy photo.
Kind Regards,
MickEdited by bigmik 2017-06-06
Posted: 04:08pm 04 Jun 2017
I keep finding small things to tweak but I think that I am finally there now... this is the last version (promise).
2017-06-05_074829_Micromite_Quick_Reference.pdf
There are only small changes from the previous version (mostly formatting) so, if you printed the last version you do not need to reprint this.
I am now including this in the Micromite firmware distribution zip file.
GeoffEdited by Geoffg 2017-06-06
CaptainBoing
Posted: 09:52am 12 Jun 2017
Sorry Geoff.
just discovered OPTION CPU [speed] is missing for MMX
Posted: 02:39am 13 Jun 2017
OK, you have got me... what does OPTION CPU speed do?
If you mean CPU speed then that is on the first page under Program Management.
Posted: 02:45am 13 Jun 2017
OPTION CPU 200/252
252 sets MMBASIC up for using some additional MMX features that are available only at this higher rate. For example higher rate WAV files.
WW
