Local Time 07:41 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SuperClock.bas
Sreckovuka
Posted: 02:12pm 03 Jun 2017
Gents
anyone interested in making some modification to the super clock.bas
I happing to pay for the time and labour. or give me a Price.
all i need is to add a new menu and a on off time to control a relay
if interested please call me on 0466537205. (Australia)
regards
srecko Vuka
palcal
Posted: 08:23pm 03 Jun 2017
I don't think what you ask would be too difficult, but when I run the code as is, I get an error message
[425] Text MM.HRes/2, 172, "Setting date and time will also adjust",C ,1 ,1 , c.entry
Error: Array dimensions
c.entry is a constant for RGB(Yellow)
I can't see anything wrong.
Paul.
Sreckovuka
Posted: 09:30pm 03 Jun 2017
is the just on the unmodified super clock.bas?
palcal
Posted: 09:53pm 03 Jun 2017
I'm using the code from Geoff's web site, no modifications.
Paul.
Posted: 03:19am 04 Jun 2017
I don't know what you are doing Paul but I just checked it and it works fine.
I used a 28-pin Micromite V5.04.04 loaded with SuperClockFontsV2.bas and SuperClockV2.bas from my website.
palcal
Posted: 11:05am 04 Jun 2017
I'm using a 170 Backpack with MM V5.04.01. I had another clock running on it OK.
I will reload the code and see what happens.
Paul.
edit. The article says you can use one of 3 sources for the time, so I don't have an RTC or GPS connected, just using the internal oscillator.
Edited by palcal 2017-06-05
Phil23
Posted: 11:41am 04 Jun 2017
Very interesting thought; changing the Super Clock....
I'm so over Plug in timers & their inconsistent menu's.
I've played with the Super Clock in the past, but had no real use for it.
But with all those spare I/O pins; plenty of relay outputs...
Even the possibility for using a few as inputs as well;
So those garden sprinklers don't run when it's raining....
Phil
palcal
Posted: 12:21pm 04 Jun 2017
OK I started from scratch and re flashed the chip with V5.04.01 loaded and saved the font, loaded the clock file and the same as before. I grabbed another identical Backpack did the same thing and the same error. So I re flashed with V5.04.04. Now I get a different error. I get to the stage of entering the time and date, but as soon as I touch any number I get the error.
  Quote  [649] str = Left$(str, digit-1) + SCap(b) + Mid$(str, digit+1, 9)
Error: 0 is invalid (valid is 1 to 255)
It always happens to me.
Paul.
palcal
Posted: 01:35pm 04 Jun 2017
Connected a GPS and the clock works OK. Set to SYDNEY (EST) time which is the correct zone for me but tried to change SYDNEY to TOWNSVILLE. When I try to delete SYDNEY I get back to the 'S' and it throws the error
  Quote  [770] str = Left$(str, Len(str) - 1)
and won't delete the 'S'.
Paul.
Posted: 04:50pm 04 Jun 2017
Ah, damn. You have found a bug in MMBasic V5.04.04. The Left$() function will not allow zero characters to be selected.
This is an updated version of SuperClock.bas which works around that issue: 2017-06-05_031115_Super_Clock_BASIC_Program.zip
BTW The workaround for the Left$() bug is to use the MID$() function.
Ie, instead of s$ = Left$(st$, 0) use s$ = Mid$(st$, 1, 0)
  palcal said  It always happens to me.
Don't worry, it has to be someone (and thanks for finding the bug).
GeoffEdited by Geoffg 2017-06-06
