Local Time 07:41 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with Invoke full screen editor
kermess
Posted: 07:13am 15 Jun 2017
Hi.
Maybe it's a problem that nobody has but I can not go back.
When i Invoke the full screen editor.
In "Edit" mode I have this end of line.
Page 1.-
" EDIT MODE Ln: 1 Col: 1 INS"
But I want this when I run "Edit"
Page 2.-
ESC:Exit F1:Save F2:Run F3:Find F4:Mark F5:Paste Ln: 1 Col: 1 INS"
Sorry for my simple question. It is possible that it is documented but I have not found it in the manuals.
I need to know how to switch from page 1 to page 2
I have a 78-key keyboard
Muchas gracias, un saludo.
David
Posted: 09:58am 15 Jun 2017
Hi David,
A few questions so that we can help answer your 'issue'
1> What Micromite setup have you got there? 28/44/64/100/144/Pi
2> What 'console are you using? TFT (size?), TeraTerm
3> What is displayed when you type OPTION LIST at the command prompt?
I believe you have a shortened 'footer' in the EDITor screen from what you are stating. This is often caused if the FONT size is too big. At the command prompt, type FONT 1, and then type EDIT. Does this 'fix' things?
WW
kermess
Posted: 06:14am 17 Jun 2017
Thank you WW
Problem solved.
The problem is directly related to the number of lines defined in
"OPTION DISPLAY lines, chars"
Varies the problem in number of lines depending on the dimensions of the monitor in use-
I tried in a portable u the normal screen allows me at most 43 lines and an external monitor with a higher definition allows me more lines without giving me the problem.
Saludos.
David
