Local Time 06:53 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with touch(y)
flip
Posted: 12:17am 19 Jun 2017
Hi all,
Hoping someone can confirm what I'm doing is OK. I had something like the following in a program and it worked fine as a routine, but when I test a cut down version in command mode it always returns 0 for the x parameter(stored in variable a). the y parameter is correct.
Do a=Touch(x):b=Touch(y):If a>-1 And b>-1 Then print a,b ELSE b=b:EndIf:Loop
Same problem evident with 5.04.04 on a standard uMite and 5.03.o on a uMite+
eg. output like
0 162
0 163
Hope it's nothing like x being treated as a variable rather than a literal parameter?
PhilEdited by flip 2017-06-20
flip
Posted: 12:22am 19 Jun 2017
...interestingly when i try
Do b=Touch(y):a=Touch(x):If a>-1 And b>-1 Then print a,b ELSE b=b:EndIf:Loop
then the y variable gets lost...
e.g.
234 0
235 0
Phil
Posted: 01:32am 19 Jun 2017
You are missing the colon after "DO"
flip
Posted: 01:54am 19 Jun 2017
Hi Matherp thanks for that.
genius... fixed
