Local Time 06:54 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Spaces for INPUT V5.04.04
OA47
Posted: 10:59pm 29 Jun 2017
Not sure if this has been discussed before but I have noticed that when I set up an INPUT statement for a STRING entry a space at the start or the end of the STRING is ignored whereas a space in the middle of the string is OK. Is there a work around on this ?
Graeme
Posted: 11:40pm 29 Jun 2017
You could use LINE INPUT then pull the string apart using the string functions.
OA47
Posted: 11:46pm 29 Jun 2017
Thanks again Geoff, I will give that a try.
