Local Time 06:04 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Explore-28 pinout
CircuitGizmos
Posted: 07:21am 02 Jul 2017
The image and PDF below is a 1-page pinout reference for the Explore-28. If you see anything wrong, please let me know.
2017-07-02_172000_CGEXPLORE28.pdf
Posted: 07:30am 02 Jul 2017
Very nice overview sheet
I have not checked it for errors though as I will need a bit of time for that!
Posted: 07:32am 02 Jul 2017
Is it not worth labelling Pin 1 as 'Reset' instead of '10K to +3.3V'
CircuitGizmos
Posted: 07:33am 02 Jul 2017
I'll be making one for the Ex64, plain 28 pin chip, and others, too.
It is a more colorful version of the info in Geoff's fine manual. It fits a 'style' that seems to be popular wth the Arduino and Raspberry Pi.
CircuitGizmos
Posted: 07:34am 02 Jul 2017
  WhiteWizzard said   Is it not worth labelling Pin 1 as 'Reset' instead of '10K to +3.3V'
It is RESET on the inside of the board graphic.
Phil23
Posted: 11:40am 02 Jul 2017
Great reference sheet to be able print on demand, my usual practice, & scribble on them.
Hoping you might see fit to update the one for the CGMicroboard2.
From memory the pinout are still for an earlier version of MMbasic & a couple have moved.
I find it a very versatile & swappable module for testing things out,
Mostly because it has a display & the SD card, to do very rough test result logging.
Currently it's the best value Plus device available assembled ready to accept a screen.
$39.00Aud Vs $76.00Aud for the alternative.
Phil.
CircuitGizmos
Posted: 12:36pm 02 Jul 2017
  Phil23 said   Great reference sheet to be able print on demand, my usual practice, & scribble on them.
Phil.
Thank you for the kind words! Yes - I'll be updating. It is unfortunate (but understandable) that the pinout changed a bit.
I hope to make a few pinout sheets and hopefully make them consistant in the way that they look.
Posted: 05:17pm 02 Jul 2017
Awesome work there, CG.
Zonker
Posted: 06:29pm 03 Jul 2017
Tip of the Hat CG..! Good looking Doc..
CircuitGizmos
Posted: 06:29am 04 Jul 2017
Thanks Grogster and Zonker!
cdeagle
Posted: 07:10am 04 Jul 2017
Thanks CG. Grey beards like me need all the help they can get.
CircuitGizmos
Posted: 07:14am 04 Jul 2017
  cdeagle said   Thanks CG. Grey beards like me need all the help they can get.
Posted: 02:17pm 04 Jul 2017
strictly speaking, AVcc should be described as "10ohm to +3.3v".
rob :-)
CircuitGizmos
Posted: 03:12pm 04 Jul 2017
  robert.rozee said   strictly speaking, AVcc should be described as "10ohm to +3.3v".
rob :-)
Thank you! I'll make that change.
Probably after I get my new monitors. I have 2 25" monitors and a 19" with my desktop stretched across them. The middle monitor (25") went kablooey yesterday and the right 25" monitor has been intermittent for a few months. Apparently, I can't get any work done without a lot of monitors. I'm a creature of habit and I like certain programs open on certain monitors. My setup right now is driving me to distraction.
So much so that I've actually spent time away from my desk!
