Local Time 06:05 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : COM port CLOSE question....
Posted: 05:22pm 03 Jul 2017
Hi folks.
QUESTION: When you CLOSE a com port, exactly what state does the MM leave the pin in?
Can I assume inactive high-impedance?
Zonker
Posted: 06:32pm 03 Jul 2017
Back to "NUL" not defined... So it's like you never assigned it...
So, for the TX out pin you would need a pull-up resistor if you are going to release the pin by closing the port... (or assign it a DOUT HI state) Edited by Zonker 2017-07-05
Posted: 07:15pm 03 Jul 2017
OK then. I think this is where my HC-12 com port problem is(other thread), you see.
