Local Time 06:04 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : OPTION RTC
busa
Posted: 07:41pm 03 Jul 2017
In the MM+ manual on page 40 it says the I/O pins for the RTC can be set with the OPTION RTC command to define a private I2C interface. However when I try to set pins other than 67,66, I get "RTC not responding". Am I doing something wrong or is it not possible to set I/O pins other than 67,66 with the RTC?
This is with the Explore 100 by the wayEdited by busa 2017-07-05
Posted: 09:01pm 03 Jul 2017
It works (last time I checked).
"RTC not responding" means just that. Do you have the connections right? Pullups in place? Battery in the RTC? Etc
Are you running the latest firmware? Versions earlier than 5.2 had a bug in the OPTION RTC command.
