Local Time 04:25 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - lunar occultation of a star
cdeagle
Posted: 02:11am 24 Jul 2017
This post describes a MMBASIC program for the MicroMite MMX, Raspberry Pi and DOS platforms which can be used to predict occultations of a star by the Moon. A lunar occultation occurs whenever the Moon moves across the location of another celestial object.
Here is a typical user interaction with the program, star_occult.bas, and the results provided.
Spica
please input the calendar date
(month [1 - 12], day [1 - 31], year [yyyy])
< for example, october 21, 1986 is input as 10,21,1986 >
< b.c. dates are negative, a.d. dates are positive >
< the day of the month may also include a decimal part >
? 2,1,1987
please input the geographic latitude of the observer
(degrees [-90 to +90], minutes [0 - 60], seconds [0 - 60])
(north latitudes are positive, south latitudes are negative)
? 40,0,0
please input the geographic longitude of the observer
(degrees [0 - 360], minutes [0 - 60], seconds [0 - 60])
(east longitude is positive, west longitude is negative)
? -105,0,0
please input the altitude of the observer (meters)
(positive above sea level, negative below sea level)
? 0
please input the number of days to simulate
? 30
searching for occultation conditions ...
begin occultation conditions
calendar date February 18 1987
utc time 12 hours 26 minutes 13.32 seconds
utc julian day 2446845.01820969
topocentric coordinates
lunar azimuth angle 213 deg 43 min 59.35 sec
lunar elevation angle 32 deg 45 min 24.36 sec
lunar phase 79.27
end occultation conditions
utc time 13 hours 15 minutes 56.89 seconds
utc julian day 2446845.05274173
lunar azimuth angle 225 deg 34 min 30.72 sec
lunar elevation angle 26 deg 37 min 43.62 sec
lunar phase 78.97
event duration 0 hours 49 minutes 43.57 seconds
The celestial coordinates of the star of interest are defined by the user in a subroutine called star_data. The following illustrates the coordinates for the star Spica. Note that the value for the star's declination in degrees is input as a string. This allows the software to compute the correct "sign" for declination.
sub star_data
' star coordinates subroutine
local rasc_hr, rasc_min, rasc_sec
local decl_deg$ as string, decl_min, decl_sec
local decl.deg
' star name
star_name$ = "Spica"
' j2000 right ascension (hours, minutes, seconds)
rasc_hr = 13.0
rasc_min = 25.0
rasc_sec = 11.587.0
' j2000 right ascension (radians)
rasc_star = (15.0 * dtr) * (rasc_hr + rasc_min / 60.0 + rasc_sec / 3600.0)
' j2000 declination (degrees, minutes, seconds)
' (note: input declination in degrees as a string)
decl_deg$ = "-11.0"
decl_min = 9.0
decl_sec = 40.71
decl.deg = val(decl_deg$)
' j2000 declination (radians)
if (left$(decl_deg$, 1) = "-" and decl.deg = 0.0) then
decl_star = -dtr * (decl_min / 60.0 + decl_sec / 3600.0)
elseif (decl.deg = 0.0) then
decl_star = dtr * (decl_min / 60.0 + decl_sec / 3600.0)
else
decl_star = dtr * sgn(decl.deg) * (abs(decl.deg) + decl_min / 60.0 + decl_sec / 3600.0)
end if
end sub
Here is a zip archive of the MMBASIC source code, the PDF document for the MATLAB version and several data files for other stars.
2017-07-24_120438_star_occult.zip
