Local Time 04:26 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX/RPI/DOS - multi-variable extrema
cdeagle
Posted: 09:41am 28 Jul 2017
This post describes a MMBASIC program that demonstrates how to compute the extrema of an unconstrained multi-variable function. The program is compatible with double precision MMBASIC on the MMX, Raspberry Pi and Windows/DOS platforms.
The example implemented in this program, ipto.bas, is concerned with determining the minimum energy required to transfer a space vehicle from Earth to Mars in 2003. For this example, the launch date at Earth and the arrival date at Mars are the two "control" variables and the total "delta-v" of the mission is the "objective" function.
Here's the source code for the extrema main subroutine along with the user-coded "objective" subroutine.
sub qnopt (n%, tol, maxiter%, x(), f, niter%, ier%, nsig%)
' quasi-newton multi-dimensional minimization subroutine
' input
' n% = number of variables
' tol = convergence criteria
' maxiter% = maximum number of function evaluations
' x() = current guess for solution
' (n% rows by 1 column)
' output
' x() = solution vector (n% rows by 1 column)
' f = current objective function value
' niter% = number of function evaluations
' ier% = error indicator
' nsig% = number of significant digits
' note: requires function log10 and subroutines
' utility and usr_func
sub usr_func (n%, x(), f)
' objective function subroutine
local i%, jdate1, jdate2, tof
local ri(3), vi(3), rf(3), vf(3)
local sv1(6), sv2(6)
local dvm1, dvm2
jdate1 = x(1) + jdate0
jdate2 = x(2) + jdate0
' compute initial state vector
planet(ip1%, jdate1, oevi(), ri(), vi())
' compute final state vector
planet(ip2%, jdate2, oevf(), rf(), vf())
'svprint(rf(), vf())
tof = (jdate2 - jdate1) * 86400.0
' set up for Gooding's method
for i% = 1 to 3
sv1(i%) = ri(i%)
sv2(i%) = rf(i%)
sv1(i% + 3) = vi(i%)
sv2(i% + 3) = vf(i%)
next i%
' solve Lambert's TPBVP using Gooding's method
glambert(xmu, sv1(), sv2(), tof, vito(), vfto())
' calculate departure delta-v (kilometers/second)
dv1(1) = vito(1) - vi(1)
dv1(2) = vito(2) - vi(2)
dv1(3) = vito(3) - vi(3)
dvm1 = vecmag(dv1())
' calculate arrival delta-v (kilometers/second)
dv2(1) = vf(1) - vfto(1)
dv2(2) = vf(2) - vfto(2)
dv2(3) = vf(3) - vfto(3)
dvm2 = vecmag(dv2())
' load scalar objective function
select case otype%
case 1
' launch delta-v
f = dvm1
case 2
' arrival delta-v
f = dvm2
case 3
' launch + arrival delta-v
f = dvm1 + dvm2
end select
end sub
Here's the data computed and displayed by the software for this example.
program ipto - interplanetary trajectory optimization
initial orbital elements and state vector
(heliocentric ecliptic and equinox of J2000)
Earth
calendar date June 7 2003
UTC time 20 hours 36 minutes 49.43 seconds
semimajor axis 1.0000010180 AU
eccentricity 0.0167071774
orbital inclination 0.0004 degrees
argument of perigee 288.0835 degrees
RAAN 174.8649 degrees
true anomaly 153.6979 degrees
position vector x-component -3.506686626636e+07 kilometers
position vector y-component -1.477252709901e+08 kilometers
position vector z-component 1.174872460684e+03 kilometers
position vector magnitude 1.518303026416e+08 kilometers
velocity vector x-component 2.849840251725e+01 kilometers/second
velocity vector y-component -6.991575298582e+00 kilometers/second
velocity vector z-component 3.450069449798e-05 kilometers/second
velocity vector magnitude 2.934350134514e+01 kilometers/second
final orbital elements and state vector
Mars
calendar date December 28 2003
UTC time 12 hours 56 minutes 32.04 seconds
semimajor axis 1.5236793420 AU
eccentricity 0.0934042294
orbital inclination 1.8494 degrees
argument of perigee 286.5316 degrees
RAAN 49.5463 degrees
true anomaly 72.9019 degrees
position vector x-component 1.443324368932e+08 kilometers
position vector y-component 1.659191955418e+08 kilometers
position vector z-component -7.016935399128e+04 kilometers
position vector magnitude 2.199114292449e+08 kilometers
velocity vector x-component -1.735727441052e+01 kilometers/second
velocity vector y-component 1.796707126749e+01 kilometers/second
velocity vector z-component 8.028848351405e-01 kilometers/second
velocity vector magnitude 2.499470441817e+01 kilometers/second
initial delta-v vector and magnitude
delta-v vector x-component 2895.449599 meters/second
delta-v vector y-component -653.699580 meters/second
delta-v vector z-component -21.760090 meters/second
delta-v magnitude 2700.672241 meters/second
orbital energy 7.293631 km^2/sec^2)
final delta-v vector and magnitude
delta-v vector x-component -2019.677630 meters/second
delta-v vector y-component 1609.283132 meters/second
delta-v vector z-component 790.405355 meters/second
total deltav magnitude 5401.344482 meters/second
total orbital energy 14.587261 km^2/sec^2)
total time of flight 203.680354 days
transfer orbital elements and state vector after first delta-v
semimajor axis 1.2598682075 AU
eccentricity 0.1945049751
orbital inclination 0.0385 degrees
argument of perigee 177.2951 degrees
RAAN 77.3056 degrees
true anomaly 2.0456 degrees
transfer orbital elements and state vector prior to second delta-v
true anomaly 154.3793 degrees
Here's a zipped archive with the MMBASIC source code
2017-07-28_193858_ipto.zip
and another zipped PDF file with the MATLAB version of a user's manual.
2017-07-28_193953_ipto_matlab.zip
It's another 3000 liner Zeke!
