Local Time 03:44 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX/RPI/DOS - sun-synchronous satellites
cdeagle
Posted: 10:13am 02 Aug 2017
This post describes one of the computer programs I wrote for designing sun-synchronous Earth orbits. These are special orbits that use "natural" perturbations to our advantage. The main perturbation is due to the non-spherical shape of the Earth. Like me as I get older, the Earth too has an equatorial bulge and somewhat flat at the poles. We can also account for the gravitational perturbations due to the Sun and Moon during the orbit design. The mission objective is to design an Earth orbit that maintains a fixed orientation with respect to the Sun.
This MMBASIC version of sunsync1.bas was ported from versions written in FORTRAN, MATLAB and QuickBASIC.
Here's a typical user interaction with the software and the numerical results.
program sunsync1
sun-synchronous orbits - j2 solution
<1> input mean semimajor axis and eccentricity
<2> input mean perigee and apogee altitudes
? 2
please input the mean perigee altitude (kilometers)
? 350
please input the mean apogee altitude (kilometers)
? 1000
program sunsync1
mean perigee altitude 350.0000 kilometers
mean apogee altitude 1000.0000 kilometers
mean semimajor axis 7053.1400 kilometers
mean orbital eccentricity 0.0460787678
mean orbital inclination 98.0571 degrees
number of iterations 3
Here's the MMBASIC source code listing for sunsync1.bas.
' program sunsync1.bas August 2, 2017
' mean orbital inclination of sun-synchronous orbits
' Kozai j2 perturbations
' MMX/RasPi/DOS versions of MMBASIC
option default float
option base 1
' astrodynamic and utility constants
const pi2 = 2.0 * pi
' conversion factor - degrees to radians
const dtr = pi / 180.0
' conversion factor - radians to degrees
const rtd = 180.0 / pi
' Earth gravitational constant (km**3/sec**2)
const xmu = 398600.4415
' equatorial radius of the Earth (kilometers)
const req = 6378.14
' Earth oblateness coefficient
const xj2 = 0.00108263
' begin main program
print " "
print "program sunsync1"
print " "
print "sun-synchronous orbits - j2 solution"
print "------------------------------------"
do
print " "
print "<1> input mean semimajor axis and eccentricity"
print " "
print "<2> input mean perigee and apogee altitudes"
print " "
input iselect%
if (iselect% = 1 or iselect% = 2) then exit do
loop
if (iselect% = 1) then
print " "
print "please input the mean semimajor axis (kilometers)"
print " "
input sma
print " "
print "please input the mean orbital eccentricity"
print " "
input ecc
' compute perigee and apogee altitudes (kilometers)
hp = sma * (1.0 - ecc) - req
ha = sma * (1.0 + ecc) - req
elseif (iselect% = 2) then
print " "
print "please input the mean perigee altitude (kilometers)"
input hp
print " "
print "please input the mean apogee altitude (kilometers)"
input ha
' compute perigee and apogee geocentric radii
rp = req + hp
ra = req + ha
' compute semimajor axis and eccentricity
sma = 0.5 * (rp + ra)
ecc = (ra - rp) / (ra + rp)
end if
' required nodal regression rate (radians/second)
drdt = dtr * (360.0 / 365.2422) / 86400.0
' Keplerian mean motion (radians/second)
xmm = sqr(xmu / (sma * sma * sma))
' orbital semiparameter (kilometers)
slr = sma * (1.0 - ecc * ecc)
' inclination initial guess
xipar0 = - (2.0 / 3.0) * slr * slr * drdt / (xj2 * req * req * xmm)
' check for possible solution
if (abs(xipar0) > 1.0) then
print " "
print "no sun-synchronous solution !!"
print " "
end
else
' perform iteration
xinc0 = acos(xipar0)
niter% = 0
do
niter% = niter% + 1
' perturbed mean motion (radians/second)
pmm = xmm * (1.0 + 1.5 * xj2 * req * req * sqr(1.0 - ecc * ecc) * (1.0 - 1.5 * sin(xinc0) * sin(xinc0)) / (slr * slr))
' updated inclination
xinc1 = acos(-(2.0 / 3.0) * slr * slr * drdt / (xj2 * req * req * pmm))
' check for convergence or more than 100 iterations
if (abs(xinc1 - xinc0) < 1.0e-9 or niter% > 100) then exit do
' reset inclination
xinc0 = xinc1
loop
end if
' print results
print " "
print " "
print " "
print " "
print "mean perigee altitude ", str$(hp, 0, 4) + " kilometers"
print " "
print "mean apogee altitude ", str$(ha, 0, 4) + " kilometers"
print " "
print "mean semimajor axis ", str$(sma, 0, 4) + " kilometers"
print " "
print "mean orbital eccentricity ", str$(ecc, 0, 10)
print " "
print "mean orbital inclination ", str$(xinc1 * rtd, 0, 4) + " degrees"
print " "
print "number of iterations ", niter%
print " "
end
Here's the PDF document that describes this and other computer programs in the sun-sync series.
2017-08-02_195758_sunsync1.zip
cdeagle
Posted: 06:23am 06 Aug 2017
This version, sunsync2.bas, uses a slightly more sophisticated gravity for the orbit design.
program sunsync2
sun-synchronous orbits - j2 + j4 solution
? 2
? 350
? 1000
program sunsync2
mean orbital inclination 98.0306 degrees
' program sunsync2.bas August 6, 2017
' Kozai j2 + j4 iterative solution
option base 1
' global constants
dim xmm, drdt0, req2, req4, slr2, slr4, ecc2
const pidiv2 = 0.5 * pi
const req = 6378.14
' Earth gravity coefficients (non-dimensional)
const xj4 = 0.0000016109876
const xj22 = 0.0000015747419
print " "
print "program sunsync2"
print " "
print "sun-synchronous orbits - j2 + j4 solution"
print "-----------------------------------------"
do
print " "
print " "
print " "
input iselect%
loop
print " "
print " "
input sma
print " "
print " "
input ecc
print " "
input hp
print " "
input ha
rp = req + hp
ra = req + ha
end if
drdt0 = dtr * (360.0 / 365.2422) / 86400.0
print " "
print " "
else
' perform iteration
slr2 = slr * slr
slr4 = slr2 * slr2
req2 = req * req
req4 = req2 * req2
ecc2 = ecc * ecc
' compute inclination bounds
xinc1 = xinc0 - 1.0 * dtr
if (xinc1 < pidiv2) then xinc1 = pidiv2
xinc2 = xinc0 + 1.0 * dtr
if (xinc2 > pi) then xinc2 = pi
' solve nonlinear equation
tol = 1.0e-10
root(xinc1, xinc2, tol, xroot, froot)
end if
' print results
print " "
print " "
print " "
print " "
print " "
print " "
print " "
print " "
print "mean orbital inclination ", str$(xroot * rtd, 0, 4) + " degrees"
print " "
end
sub ss2_func(x, fx)
' delta-raan rate objective function
' input
' x = current orbital inclination (radians)
' output
' fx = objective function
local sinc, cinc
local pmm, pmm1, pmm2, pmm3, pmm4, pmm5, pmm6
local drdt, drdt1, drdt2, drdt3, drdt4, drdt5
sinc = sin(x)
cinc = cos(x)
' Kozai j2 + j4 perturbed mean motion (radians/second)
pmm1 = 1.0 + 1.5 * xj2 * req2 * sqr(1.0 - ecc2) * (1.0 - 1.5 * sinc^2) / slr2
pmm2 = (3.0 / 128.0) * xj22 * req4 * sqr(1.0 - ecc2) / slr4
pmm3 = 16.0 * sqr(1.0 - ecc2) + 25.0 * (1.0 - ecc2) - 15.0
pmm4 = (30.0 - 96.0 * sqr(1.0 - ecc2) - 90.0 * (1.0 - ecc2)) * cinc^2
pmm5 = (105.0 + 144.0 * sqr(1.0 - ecc2) + 25.0 * (1.0 - ecc2)) * cinc^4
pmm6 = - (45.0 / 128.0) * xj4 * req4 * sqr(1.0 - ecc2) * ecc2 * (3.0 - 30.0 * cinc^2 + 35.0 * cinc^4) / slr4
pmm = xmm * (pmm1 + pmm2 * (pmm3 + pmm4 + pmm5) + pmm6)
' raan time rate of change
drdt1 = -1.5 * req2 * xj2 * pmm * cinc / slr2
drdt2 = 1.5 * req2 * xj2 / slr2
drdt3 = 1.5 + ecc2 / 6.0 - 2.0 * sqr(1.0 - ecc2)
drdt4 = - ((5.0 / 3.0) - (5.0 / 24.0) * ecc2 - 3.0 * sqr(1.0 - ecc2)) * sinc * sinc
drdt5 = - (35.0 / 8.0) * req4 * xj4 * xmm * (1.0 + 1.5 * ecc2) * ((12.0 - 21.0 * sinc * sinc) / 14.0) * cinc / slr4
drdt = drdt1 * (1.0 + drdt2 * (drdt3 + drdt4)) - drdt5
' calculate the objective function as the difference
' between the desired and current raan rate
fx = drdt - drdt0
end sub
sub root(x1, x2, tol, xroot, froot)
' real root of a single non-linear function subroutine
' input
' x1 = lower bound of search interval
' x2 = upper bound of search interval
' tol = convergence criter%ia
' output
' xroot = real root of f(x) = 0
' froot = function value
' note: requires subroutine ss2_func
local eps, a, b, c, d, e, fa, fb, fcc, tol1
local xm, p, q, r, s, xmin, tmp
eps = 2.23e-16
e = 0.0
a = x1
b = x2
ss2_func(a, fa)
ss2_func(b, fb)
fcc = fb
for iter% = 1 to 50
if (fb * fcc > 0.0) then
c = a
fcc = fa
d = b - a
e = d
end if
if (abs(fcc) < abs(fb)) then
a = b
b = c
c = a
fa = fb
fb = fcc
fcc = fa
end if
tol1 = 2.0 * eps * abs(b) + 0.5 * tol
xm = 0.5 * (c - b)
if (abs(xm) <= tol1 or fb = 0.0) then exit for
if (abs(e) >= tol1 and abs(fa) > abs(fb)) then
s = fb / fa
if (a = c) then
p = 2.0 * xm * s
q = 1.0 - s
else
q = fa / fcc
r = fb / fcc
p = s * (2.0 * xm * q * (q - r) - (b - a) * (r - 1.0))
q = (q - 1.0) * (r - 1.0) * (s - 1.0)
end if
if (p > 0.0) then q = -q
p = abs(p)
min = abs(e * q)
tmp = 3.0 * xm * q - abs(tol1 * q)
if (min < tmp) then min = tmp
if (2.0 * p < min) then
e = d
d = p / q
else
d = xm
e = d
end if
else
d = xm
e = d
end if
a = b
fa = fb
if (abs(d) > tol1) then
b = b + d
else
b = b + sgn(xm) * tol1
end if
ss2_func(b, fb)
next iter%
froot = fb
xroot = b
end sub
