Local Time 04:26 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : OPTION ERROR CONTINUE gone from 5.4 DOS.
Paul_L
Posted: 11:11pm 02 Aug 2017
The OPTION ERROR [CONTINUE | ABORT] commands, which were used to check for file i/o errors, are not in the DOS V 5.4 documentation. Instead I find ON ERROR [ABORT | IGNORE | SKIP [nn] | CLEAR]. I was going to use this generic FIO%() function to open all my files but I'm not sure how to use the new error checking commands. Help please.
Paul in NY
' in the mainline I use this statement to open any file
if FIO%(FIlblN$,FIlblB%,"R")=0 then CRAsh*t("UBLEWIT! Can't open file "+FIlblN$)
' then I do something with the file
FUNCTION FIO%(fn$,bf%,rwa$) '^1=open, 0=fail, where rwa$= [R|W|A]
SELECT CASE rwa$
CASE "R"
OPEN fn$ for input as #bf%
CASE "W"
OPEN fn$ for output as #bf%
CASE "A"
OPEN fn$ for append as #bf%
END SELECT
if MM.ERRNO <> 0 then FIO%=0 else FIO%=1
OPTION ERROR ABORT
END FUNCTION 'FIO%(fn$,bf%,rwa$)
SUB CRAsh*t(st$) ' close all open files and crash
LOCAL i%
for i%=1 to 10:close #i%:next i%
OPTION ERROR ABORT
ERROR st$ ' crash the program
END SUB 'CRAsh*t(st$) ' close all open files and crash
Paul_L
Posted: 11:16pm 02 Aug 2017
Hey, look at that!! The web site doesn't like the vernacular term referring to the ubiquitous product of defecation. It cleaned up my procedure name. In the future I'll substitute CRASHtheWHOLEdarnedTHING(st$) for my usual CRASH_IT(st$).
Paul in NY
Posted: 03:20am 03 Aug 2017
This should work (not tested):
ON ERROR IGNORE
SELECT CASE rwa$
CASE "R"
CASE "W"
CASE "A"
END SELECT
ON ERROR ABORT
LOCAL i%
ON ERROR IGNORE
ON ERROR ABORT
Paul_L
Posted: 09:24am 03 Aug 2017
Thanks Geoff, I kind of figured that was what you intended.
BTW, in several places in the various manuals you use the variable name STR for an array sort of like this:
DIM AS STRING str (5, 10) LENGTH 20
This looks funny as heck. I figured that str would be a reserved word. Will it conflict with the function str$()? Is the space allowed between the variable name and its array dimension brackets?
Paul in NY
CaptainBoing
Posted: 09:59am 03 Aug 2017
this was touched on in this thread
Posted: 01:59am 05 Aug 2017
  Paul_L said  BTW, in several places in the various manuals you use the variable name STR for an array sort of like this:
Thanks, yes that is a poor choice of a variable name.
I will change it forthwith.
