Forum Index : Microcontroller and PC projects : eof(0)
| crez Senior Member Joined: 24/10/2012 Location: AustraliaPosts: 157 |
under 5.0404 on mm+, i am checking for input characters on the console. The eof(0) function reads 1 until the console buffer is empty, when it reads 0. Is this the opposite of what is should be or am I having a 'short between the earphones'? |
Damn, now that you have pointed it out I can see the bug. It is not you that had the 'short between the earphones', it was me. I will fix it in the next release. Geoff Geoff Graham - http://geoffg.net |
