Forum Index : Microcontroller and PC projects : Fonts
| vk4cuz Newbie Joined: 10/08/2017 Location: AustraliaPosts: 4 |
Hi all, Using MM+ LCD backpack, and various programs. Firmware v5.04.05 Had running the clock program for a trial. This overwrites some of the fonts installed. Went back to try something else with the GUI's. Had an issue with the fonts in the Gui Numberbox. Letters were oversized. Deleted the fonts in the library. Now the Gui Numberbox doesn't display anything sensible at all. Is there a way to restore the MM+ to original or do I have to reflash the MM+. Gary |
LIBRARY DELETE and NEW should clear everything in program memory. or Send a stream of exclamation marks (!) to the console Rx pin at 38400 baud while powering up the Micromite. This will reset everything including options. See page 16 of the Micromite User Manual. Geoff Geoff Graham - http://geoffg.net |
Thanks Geoff Library delete and New did not work. Full reset worked. Fonts now displaying correctly in numberbox. Gary |
