f1fco Senior Member Joined: 18/03/2012 Location: FrancePosts: 155
Posted: 10:54am 02 Sep 2017
hello to all, does anybody can sell to me a PRINTER-Mite PCB or ready made ? like this : http://www.thebackshed.com/forum/forum_posts.asp?TID=7425&PN=0&TPN=1
I want to try a parallel printer EPSON FX80
thank you for answer or proposition
Pierre, from Nimes, south of France 73s de F1FCO
Grogster Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10043
Posted: 12:58pm 02 Sep 2017
I think I still have some of those sitting around. I never got around to writing the MMBASIC code for it though. But I am pretty sure I have the PCB's. Will look and let you know.
EDIT: I never finished this one at a code level, cos I moved on to thermal printers with a serial interface.
EDIT: Upon re-reading that thread again, I see that I did write enough code to get the dot-matrix stuff up and running, but not the laser-printer options. I also built a prototype, so I will see if I can find that, and if I can, you are welcome to have that fully assembled one to tinker with - I will PM you about that. You would be able to XMODEM S the code from the assembled board to your PC to use as a starting point etc....Edited by Grogster 2017-09-03Smoke makes things work. When the smoke gets out, it stops!
