Local Time 21:14 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PWM pins required
G.B.P.
Posted: 08:00pm 29 Sep 2017
I am experimenting with the MM Plus with a project that requires to use 4 out of the 5 PMW connections. Additionally, the use of both the Touch and SD Card access on the LCD screen used (SSD1963) are also required.
Is there any possibility to allocate different pin to either the DB3 or T_DO so that one of the 2 PWM (pins63 or pin47) can be made free?
Posted: 09:21pm 29 Sep 2017
  Quote  Is there any possibility to allocate different pin to either the DB3 or T_DO so that one of the 2 PWM (pins63 or pin47) can be made free?
DB3 No: otherwise the bus for parallel transfer to the display is compromised
T_DO is possible with a CFunction that re-allocates SPI2IN to a different pin using peripheral pin select capability of the MX470. The only possible alternate pins are 51, 32, and 1 (1 would need checking)
G.B.P.
Posted: 09:39pm 29 Sep 2017
Thanks matherp
Unfortunately CFunction are beyond my expertise
Pin 1 is shown as being reserved for the data transfer as DB5, therefore it should also not be available.
Will need to revert to the smaller ILI9341 screen then
Posted: 09:45pm 29 Sep 2017
  Quote  Pin 1 is shown as being reserved for the data transfer as DB5
Sorry - me misreading the datasheet. 13 and 15 would also be OK but not 1. Happy to knock up a CFunction for you if it is important
G.B.P.
Posted: 10:17pm 29 Sep 2017
If not too much of a job, this would be of great help..
I could get away in not using the SD Card, as this is required just to load images but the Touch control is a must for all adjustment's required in the program.
Posted: 10:47pm 29 Sep 2017
Touch and SD both use the SPI2IN pin so both would be affected by the change. Pick one of the pins I identified above and I'll knock something up for you to test
G.B.P.
Posted: 11:01pm 29 Sep 2017
Great!
Probably best is Pin 14..
I am sure that such routine will come handy for many users.
Thank You .
G.B.P.
Posted: 11:03pm 29 Sep 2017
Hoops!
Pin 32
Posted: 12:24am 30 Sep 2017
No promises as completely untested as I don't have a 64-pin MM+
sub MM.STARTUP
remap()
end sub
CSub remap
00000000
27BDFFE8 AFBF0014 AFB00010 3C109D00 8E020010 24040020 24050002 0040F809
00003021 8E020010 24040020 24050064 0040F809 00003021 3C02BF81 8C43FA90
24040002 7C831804 AC43FA90 8FBF0014 8FB00010 03E00008 27BD0018
End CSub
include in the library and then reset and the SPI2IN should be remapped to pin 32.
Posted: 02:57am 30 Sep 2017
  matherp said   No promises as completely untested as I don't have a 64-pin MM+
Why not
Would it prove useful if I send you one for testing these kind of things on?
Posted: 09:01am 30 Sep 2017
Forgot to free up pin 47 to be re-allocated in the previous version. Try:
CSub remap
00000000
24040002 7C831804 AC43FA90 8E020088 AC4000BC 8FBF0014 8FB00010 03E00008
27BD0018
End CSub
This is now tested and seems to work.
panky
Posted: 03:05pm 30 Sep 2017
@matherp
Very interesting Peter - would it be possible to post the C code for us to peruse and learn?
Thanks,
Doug.
G.B.P.
Posted: 05:51pm 30 Sep 2017
Thank you motherp.
I have the SSD1963 on order.. waiting for it to arrive now
Posted: 08:27pm 30 Sep 2017
  G.B.P. said   Thank you motherp.
Quite an appropriate Typo..
Posted: 09:21pm 30 Sep 2017
  Quote  Very interesting Peter - would it be possible to post the C code for us to peruse and learn?
#define Version 101 //Version 1.01
#define _SUPPRESS_PLIB_WARNING // required for XC1.33 Later compiler versions will need PLIB to be installed
#include <plib.h> // the pre Harmony peripheral libraries
#include "../cfunctions.h"
#define SPI_INP_PIN_NEW 32
#define SPI_PPS_OPEN { PPSInput(2, SDI2, RPF5);}
void remap (void) {
ExtCfg(SPI_INP_PIN, EXT_DIG_IN, 0); ExtCfg(SPI_INP_PIN, EXT_RESERVED, 0);
SPI_PPS_OPEN
ExtCurrentConfig[47]=EXT_NOT_CONFIG; 'pin 47 is F5
void main(void){
Edited by matherp 2017-10-02
panky
Posted: 10:30pm 30 Sep 2017
Thanks Peter,
Doug.
G.B.P.
Posted: 09:37am 13 Dec 2017
Hi matherp (<- this time correct... apologies Peter! )
I finally received the SSD1963 display and after setting up the LCD with the MM+ Explore 64, I ran the program including your CSub and with the connection to pin 47 transferred to pin 32..
The program hangs immediately after searching for the starting BMP image..
Option autorun on
SetPin 22, ain
CLS
LCDLight = 100
VAR restore
Load Image "HUD2.BMP"
Do:Loop Until Touch(down)=1
Load Image "HUD3.BMP"
etc.......
The following message received:
[6] Load Image "HUD2.BMP"
Error: SD card not found
LCD options set as below:
> Micromite Plus MMBasic Ver 5.04.05
Copyright 2011-2017 Geoff Graham
> option list
OPTION AUTORUN ON
OPTION LCDPANEL SSD1963_4, LANDSCAPE, 50, 49
OPTION TOUCH 18, 21
OPTION SDCARD 12, 14
> memory
Flash:
3K ( 2%) Program (107 lines)
1K ( 1%) 3 Saved Variables (52 bytes)
4K ( 4%) Library
92K (93%) Free
RAM:
1K ( 0%) 9 Variables
0K ( 0%) General
102K (100%) Free
When the pin is relocated to pin 47 and the MM reset, the program still requires to be reloaded before it can find the SD Card and run smoothly.
With the SD Card and Touch screen back to normal functions.
I have tried with the CSub saved under both the Library and in the program, but with similar results.
Is there any possible reason for this?
Thanks again.
Posted: 10:55am 13 Dec 2017
You need to call the CFunction from MM.STARTUP and save this routine and the Cfunction in the library. Then it will be called every time the Micromite boots.
sub MM.STARTUP
remap
end sub
CSub remap
00000000
27BD0018
End CSub
Once you have done this you need to test that basic SDcard handling is working with the new pin i.e. "FILES" from the command promptEdited by matherp 2017-12-14
G.B.P.
Posted: 09:02am 14 Dec 2017
Hi matherp
Done this, tested the SD card reading and "FILES" did report what on the SD card.
> files
A:/
0 directories, 1 files
Problem now is that the Touch does not respond.
Done a GUI TOUCH TEST, no response.
Relocate the jumper to pin 47 and TOUCH working again ..
It appears that the OPTION TOUCH is not affected by this subroutine ...
Any possible further suggestion.. please
Thank you.
G.B.P.
Posted: 04:37am 27 Dec 2017
Hi matherp
I have tested the Pump program (Geoff) as this uses only one opening screen and no files are required to be loaded... but same results, swop pins and touch working again...
if of any help, is the below listing correct..?
> library list
CSub remap
End CSub
SD card reading still working
> files
A:/
If not possible to use both the SDcard and the Touch.. then to free the required extra PWM pin, will need to revert to the smallest LED ILI9341
