Local Time 23:51 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite eXtreme V5.4.06: Audio bug fix
Posted: 05:14am 07 Nov 2017
Attached is the latest release 5.4.06 for the 100 and 144-pin parts
2017-11-07_145919_MMX5.4.06.zip
and for the 64-pin parts
2017-11-07_150005_MMX645.4.06.zip
This fixes bugs that affected both WAV playback and FLAC playback
Previously due to buffering MMBasic would stop processing the main program for a period between reading the last of the sound data from file and the sound output completing. A fix for this was included in 5.4.05 but stopped the completion interrupt working properly. This is finally fixed in this release - I hope.
Also PAUSE statements in the sound completion interrupt routine (why would you ) caused MMBasic to lock up. This is fixed. Edited by matherp 2017-11-08
