Local Time 10:16 14 Nov 2026 Privacy Policy
Forum Index : PCB Manufacturing : Diptrace pattern
lew247
Posted: 07:26am 09 Aug 2016
Does anyone have a mini USB B pattern for Diptrace please?
Ideally one where the actual part number is available as well
I've found out through experience, not all footprints are the same, you have to have the footprint for the actual socket you want to use
This way I can order the correct usb socket to match the pattern
MicroBlocks
Posted: 09:58pm 09 Aug 2016
Here is a Component/Pattern and 3d model.
2016-08-10_075644_Lew.zip
Watch out! The 3d model is very, very close but the two pins on the front which connect the metal case to the pcb are a bit offset to the back.
The pattern is correct and i have test fitted it.
The pattern also has all the dimensions so you can check it with the part you are going to order.
lew247
Posted: 12:49am 10 Aug 2016
Thanks Jean
