Local Time 10:26 14 Nov 2026 Privacy Policy
Forum Index : PCB Manufacturing : tinning the PCB tracks
Posted: 12:38am 01 Dec 2016
Many years ago I came across a tinning solution in a bottle.
This was just wiped over the tracks of an etched board, tinning the tracks and preventing oxidization.
Is that stuff still available? What is it called so I can search for it?
I normally use PCB laquer on my simple boards but now have made one where I need to connect (screw on) something to the tracks.
Thanks.
Posted: 03:39am 02 Dec 2016
Hi Klaus,
Liquid Tin
But it is not cheap.
Kind Regards,
brucedownunder2
Posted: 02:19pm 02 Dec 2016
I,ve used a tinning paste many years ago . worked magic on copper pipe and any copper or brass surface,just steel wool (stainless) the surface area ,heat with either propane torch or similar and wipe it off with a clean rag for perfect coating.
used it every day at work on copper air pipes .
You can tell if it's good --the small tin of the stuff is heavy.
Bruce
Bushboy
Posted: 12:21am 03 Dec 2016
Thanks guys, good tips.
I did some more googling on the subject and found a kind of metal bristle brush that fitted into a soldering iron. Loading that with solder and flux paste coat the tracks apparently is the cat's meouw on tinning tracks - but its expensive (to me).
So, rummaging in my odds & ends box I found small a brass cleaning brush (works a bit like a lip stick - you twist one end and the bristles come out the other).
So I'm modifying this, just pull out the bristle bundle and fit them into a copper 3/8" pipe which suits my old Weller soldering iron.
I think it should work, I'll let you know.
greybeard
Posted: 10:24pm 03 Dec 2016
If it's only a small area that needs to be tinned and the rest can be covered with pcb lacquer then use a 'pre-loved' piece of soderwick. Just hit it with some solder then apply it over the track to be tinned. It will leave a neat thin coating of solder on the pcb.
