Local Time 22:31 08 Aug 2026 Privacy Policy
Forum Index : Windmills : F&P startup
dazz
Posted: 01:12am 02 May 2008
Hi All,
Could somebody tell me how fast you would expect the blades to spin(ie RPM) in a typical application with say 2m blades at the min wind speed to keep the blades rotating, like 15km/h?
I just have no concept of how fast they would spin. I can imagine them trundling around at about 20RPM but i can also imagine 100RPM. In other words, I have no clue.
Cheers, Daryl
Posted: 10:37am 02 May 2008
Daryl, think about what LOAD there is on the blades.
Like, turn your bike upside down and spin a wheel. Then try the same with the brake on. Got it?
dazz
Posted: 11:57am 02 May 2008
Hi Klaus,
Well I was assuming very low load. At the lowest speeds I would assume the voltage produced would be well below cut in and hence the load would be small. Am I wrong?
If you consider a slowly increasing wind starting from dead calm then presumably the force on the rotors would increase with no movement of the blades until the force was great enough to overcome cogging. Once it does so the cogging is reduced so the same force will drive the blades faster.
So at that point, roughly what is that speed. I'd be surprised if people hadn't noticed this sort of thing staring at their windwill on low wind days.
Daryl
PS. Just because it's a simple question, doesn't mean I'm simple, got it?
