Local Time 13:30 05 Nov 2026 Privacy Policy
Forum Index : Windmills : I-beam tower?
imsmooth
Posted: 11:21pm 23 May 2008
I have seen variations of towers using poles. Has anyone considered using I-beams. If one wanted a 30' tower a 20' I-beam could be used and a 10' section of pole could be raised like a flag as it slides up and down the beam. So, what is wrong with this thought?
Posted: 02:42am 24 May 2008
I have a feeling an I-beam will twist along its length, which may be a problem. I-beams are strong when bolted to other beams to form triangles, etc, but not so strong by themselves. A tube is the strongest shape for stand alone use, and tubes resist twist ( which is why tubes are used as prop shafts in vehicles, very thin wall section but lots of strength ).
If you go for a big enough cross section of I-beam, then it will be ok, but heavy compared to tube.
dwyer
Posted: 07:09am 24 May 2008
HI Imsmooth
As l am work in metal trade for many years as l do agree with Gizmo over I-beam as they do twist very easily and when l built my shed l use RHS reason they dont twist as during strong storm many I-beam cannot handle well however If I was you just forget it not worth as wasting too much time and will not pass at any engineering test sorry
dwyer the bushman
