Local Time 13:17 05 Nov 2026 Privacy Policy
Forum Index : Windmills : stepper mini windmill
feix62k
Posted: 11:57am 30 Jul 2008
has anyone built one of these as I have found a hp printer moter and I dont think the blades on the plan are big enough as the moter seems tight to turn you may think this is a dumb question but what sort of moter is best to use. also I picked up a 24 volt scooter moter and batteries could that be used for a wind generator thanks felix
dont the days seem lank and long when nothing gos right and everthing gos wrong
CraziestOzzy
Posted: 11:31pm 30 Jul 2008
You can rig up a stepper motor to be a generator...issues with starting and residual torque will make these motors rate low when compared to other motor conversions.
I have a 24volt scooter motor too and a pair of batteries that came with it....go with this setup if you wish to play with things.
Here is a few links that may help you on your journey...
Basic motor conversion overview
In depth and simple description of stepper motors and use
A good guide for converting motors with calculators to go
A quick guide to finding out which wire is which on a stepper motor
...hope you have fun, cheers
http://cr4.globalspec.com/member?u=25757
http://www.instructables.com/member/OzzyRoo/
