Local Time 06:46 09 Aug 2026 Privacy Policy
Forum Index : Windmills : Simple yaw ’brushes’
KiwiJohn
Posted: 11:00pm 07 Aug 2008
If you feel you really must have a means of allowing your small (e.g. stepper motor?)mill to rotate about the mast without the wires twisting you could use one of these:
This is a 1/4" stereo phono jack which you can buy just about anywhere and you need its matching socket. Mount them so that they are aligned with the axis of your yaw bearing and the jack will turn in the socket as the mill yaws.
OK, it wont last forever but it will last quite a while and they are not expensive!
Gill
Posted: 09:59am 08 Aug 2008
Now that's not a bad idea John.
Very clever.
Why are all the good ideas so simple?
I see in Jcar they sell a 4 wire plug though I can't seem to find a socket to match.
Cheers Gill _Cairns, FNQ
KiwiJohn
Posted: 08:57pm 08 Aug 2008
Even better if you can find some WWII radio bits as some field sets had very robust jacks and sockets with 3 or 4 contacts. Old manual telephone exchanges had really heavy jacks and sockets for the operators' headsets too but some had multiple pins so are not the ones to look for.
KiwiJohn
Posted: 08:58pm 08 Aug 2008
'Cos they come from simple minds?
Posted: 11:17pm 08 Aug 2008
The old Telecom gear had all silver coated contacts. Silver is harder than gold so would last longer. I remember I had to manually clean and adjust relay contacts as part of my apprentiship. They would go green with time, that was ok, the important thing was to get the contact pressure and wipe correct. When the contacts closed where were designed to wipe against eachother, keeping the contact area clean. Some of the gear was over 50 years old and worked like new.
Good idea John. The whole thing could be housed in an upturned plastic cup/cap to keep the water out.
