Local Time 13:06 05 Nov 2026 Privacy Policy
Forum Index : Windmills : Drill windmill
ienciu
Posted: 01:20pm 30 Aug 2008
Hi i have a new idea what do you mean to make a wind mill from a 12 volt drill.i have a small video and foto.
http://i537.photobucket.com/albums/ff336/ienciu/Motor0066.jp g
http://s537.photobucket.com/albums/ff336/ienciu/?action=view ¤t=Motor.flv
I onli try what hapend i got transmision propeler case all in one i think i will need a tower(this is just one idea maybe will work)Thanks for any sugestion.
I fixed those links for you.
GlennEdited by Gizmo 2008-09-01
Dodgeman
Posted: 11:07pm 04 Sep 2008
Hello,
Your idea is very interesting, I would imagine that you may see a few volts for a short time from your contraption, If it does not have too much gear resistance to get started that is.
I would try to rotate the drill with another drill and see what kind of restrictive rotational forces are at work in a cordless drill, some have brake and shaft lock devices, I am not sure about yours.
Also the bushings and gears are mostly plastic and will most likely fail in a very strong wind.
On the bright side, at least your trying and that is commendable. If at first you dont succeed , try, try again
