Local Time 12:59 05 Nov 2026 Privacy Policy
Forum Index : Windmills : Low Starting Torque &Friction Alternator!
mechamz
Posted: 07:24am 19 Sep 2008
Hi, I'm currently doing a VAWT prototype.
I'm happened to find these 2 alternators, but not sure which is better?
http://www.ginlong.com/wind-turbine-pmg-pma-permanent-magnet -generator-alternator-GL-PMG-500A.htm
http://www.windbluepower.com/DC_540_Low_Wind_Permanent_Magne t_Alternator_p/dc-540.htm
the dimension of the Savonius turbine, height is 0.8m and width is 0.43m
My system require a low starting torque and low friction alternator. Previously, I've purchased one from http://energistar.com, but the performance was far from the information given.
I hope the alternator able to generate 12V and more than 1 or 2Ampere at low rpm, and low torque required. Any better suggestion than these 2 alternators are welcomed.
or something like this, http://www.gotwind.org/diy/Axial_Flux_Alternator.htm
Any idea??
Fixed those links for you. Gizmo.
http://www.windbluepower.com/DC_540_Low_Wind_Permanent_Magne t_Alternator_p/dc-540.htmEdited by Gizmo 2008-09-20
I'm looking for an alternator(low rpm) pm me please
Posted: 09:28am 19 Sep 2008
Both of those altenators are way way to big for that size turbine. A 0.8m X 0.43m sav will only give a frontal area of 0.344m ,and that will only be good for a few watts.
Using Power = 0.615 x Swept Area x (Velocity)³
I get about 13 watts in 4ms wind.
( See http://www.small-farm-permaculture-and-sustainable-living.co m/windmill_power.html )
13 watts isnt a lot of power to drive those big alternators, most of that would be lost in just the bearings alone.
What about a stepper motor? A sav' windmill has lots of startup torque, it should work well on a large stepper motor.
GlennEdited by Gizmo 2008-09-20
GWatPE
Posted: 09:31am 19 Sep 2008
Hi mechamz,
The power levels that you are talking about are very low. The current will determine the wire thickness. The rpm will determine the number of poles[magnets] and the number of turns needed to generate the required EMF. An iron cored alternator will sap much of the power you are trying to capture. Low rpm usually means a large number of poles and this would require a large iron mass to complete the magnetic field.
I would opt for an ironless design. If you do not want to build your own, Maxon[Switzerland] do make a range of basket wound ironless motors, that could be used as a generator. They make a wide variety of types and operating power ranges. They are reasonably expensive. They have very low inertia.
Good luck.
Gordon.
become more energy aware
Posted: 09:36am 19 Sep 2008
We keep doing this Gordon, posting at the same time. I beat you today by 3 minutes!
GWatPE
Posted: 10:24am 19 Sep 2008
No worries Gizmo,
I was busy on another post, so didn't check first.
The maxon motors have the highest efficiency of any small motors that I have tested. I used one in my first model solar car. Approx efficiency is above 80%. The closest iron cored small motor was around 50% efficiency. They are high torque as well. I remember pulling a similar basket wound motor from a VCR.
Gordon.
vawtman
Posted: 01:19pm 19 Sep 2008
http://www.windstuffnow.com/main/3phase_turbine_kit.htm
What about something like this from Ed.May have to beef it up a bit
Dinges
Posted: 12:50am 20 Sep 2008
That generator looks vaguely familiar...
http://www.fieldlines.com/story/2005/11/13/32021/791
Anyway, Mechamz, you can find more construction information in the link above. I don't think I'd go with anything else but an axial flux for your particular application.
Edit: some more pictures can be found here: http://www.anotherpower.com/gallery/album46Edited by Dinges 2008-09-21
mechamz
Posted: 12:53pm 20 Sep 2008
yeah, but where/how can I buy Axial Flux Alternator?? or any dynamo with higher power??
Posted: 02:05pm 20 Sep 2008
Hi mechamz
I'm not sure you realise how little power you will get from that windmill. Remember, based on the sizes you gave us, you only have about 13 watts in average winds.
Using a higher rating alternator wont give you more power.
I doubt there would be a commercial alternator available for such a small windmill, you really need to make your own as suggested above.
mechamz
Posted: 05:05pm 20 Sep 2008
  GWatPE said   Hi mechamz,
Good luck.
Gordon.
could you provide any links? thanks
mechamz
Posted: 05:06pm 20 Sep 2008
  Gizmo said   Hi mechamz
yeah, I know that. I will try this wind turbine under relatively strong wind, around 5-6m/s
Dinges
Posted: 06:08pm 20 Sep 2008
  mechamz said  yeah, but where/how can I buy Axial Flux Alternator?? or any dynamo with higher power??
The best things in life are not for sale... At least I don't know of a place that sells small axial fluxes. Probably the only way to get one would be to build one, just as everyone else here seems to do. Maybe you can get someone to build one for you, but keep in mind it took about 30-40 hours of work to build that small axial flux. Multiply with an applicable hourly rate for someone to do the work for you... And suddenly that Maxon motor Gordon pointed you to actually appears to be dirt cheap in comparison...
Funny thing is: it takes about the same amount of time, effort and material costs to build such a tiny axial flux as it takes a full-sized one. Which is the reason hardly anyone messes with small toy stuff, it's just not economical. Edited by Dinges 2008-09-22
GWatPE
Posted: 12:50am 21 Sep 2008
Hi mechamz,
This link is the maxonmotor shop. You will need to select the type of motor, EC flat type, and the power. Select the 90W version. The 48V motor has 2000rpm speed.
https://shop.maxonmotor.com/ishop/app
The power range would be about 30W@600rpm. These are mini F&P motors.
A simple search found this one. I am sure you could have found this just as easily.
Gordon.
mechamz
Posted: 08:26am 21 Sep 2008
agreed. I'm looking someone do it for me. I'm willing pay for it.
anyone interested?? thanks
mechamz
Posted: 03:10am 22 Sep 2008
but I have to find a suitable one to suit my wind turbine =(
