Local Time 12:59 05 Nov 2026 Privacy Policy
Forum Index : Windmills : Can I use old 2stroke geni for mill
TheDarkOne
Posted: 10:09pm 22 Sep 2008
Hi I was wondering whether I could take my el-cheapo 2 stroke generator apart and use it in a wind mill ? The generator is 240v 50hz. Not sure what power the 2 stroke engine but I assume its about 4hp ?
lightgone
windlight
Posted: 12:25am 23 Sep 2008
Simple answer NO. It is designed to turn at 3000rpm well out of the range of a wind turbine without gearing, and gearing on wind turbines is not desirable because of losses.
At lower speed your generator may produce a voltage but if it was asked to supply current it would probally self destruct.
allan
