Local Time 15:46 05 Nov 2026 Privacy Policy
Forum Index : Windmills : blade steem alighn
adelaide
Posted: 03:23am 30 Mar 2006
hi has any 1 used steem on section of wood to corect a blade that changed after glued/screw ? 1 has angle bit out so want to steem a foot of it with paint sanded off and re do angle slightly, say with alfoil around it and steem out of steem cleener small 1 for 1/2 hour?
help to make progres or radio and vitamin b
Posted: 05:33am 30 Mar 2006
I dont see why it would not work. I've bent balsa wood with steam. I sprayed the balsa with a water spray, then used a cloths iron on high to turn the water to steam and bend the balsa around a drum to get the curve I wanted. Worked real good.
