Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1165
Posted: 12:45pm 16 Feb 2023
First: I have NEVER worked with Telnet.
- I have WLAN enabled (can see the neighbor's network). - Under Windows Features I have enabled Telnet - Raspberry Pico W was flashed with "2023-02-15_193513_PicoMiteWebV5.07.07a16" and "OPTION TELNET CONSOLE ON" was executed - Raspberry Pico W hangs on separate power supply and flashes - When I enter "telnet 192.168.1.111" in the console, I get the error message: "Could not connect to host, on port 23: connection error"
Also when I start TeraTerm (with the INI from Peter) I get the error message: "Connection timed out".
What am I doing wrong???
THANKS!!!
Frank
Double Post... Edited 2023-02-16 22:50 by Frank N. Furter
